用KEIL编译KE02的UART的demo出现的问题
2150|1
 楼主| ldysucc2017 发表于 2015-10-29 18:38 | 显示全部楼层 |阅读模式
环境是:KEIL5
pmc.h(35): warning:  #21-D: type qualifiers are meaningless in this declaration
定位:
const enum {
  PMC_LVW_INT_DISABLE = 0,
  PMC_LVD_RESET_DISABLE = 0,
  PMC_LVD_STOP_DISABLE = 0,
  PMC_LVD_DISABLE = 0,
  PMC_BANDGAP_DISABLE = 0,
crc.c(141): warning:  #14-D: extra text after expected end of preprocessing directive
定位:
#ifdef  defined(BYTE_ENABLES_1_2_4_8)                     /*write single byte */
        for(;j<sizeBytes;j++)
            *pCRCBytes++ = msg[j];
"UART_demo_Flash.axf": Error: Q0122E: Could not open file 'UART_demo_Flash.axf': No such file or directory
皛柒 发表于 2017-3-6 10:54 | 显示全部楼层
这个问题解决了吗?我也遇到了
