- /* --COPYRIGHT--,BSD
- * Copyright (c) 2014, Texas Instruments Incorporated
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * * Neither the name of Texas Instruments Incorporated nor the names of
- * its contributors may be used to endorse or promote products derived
- * from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
- * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
- * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
- * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
- * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
- * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
- * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
- * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
- * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
- * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- * --/COPYRIGHT--*/
- * MSP430i2xx GPIO - Input Interrupt
- * Description: In this example, P1.4 is setup as an output pin. P2.0 is set up
- * as an input pin that interrupts when the voltage applied goes from high to
- * low. When the voltage transition happens the ISR is fired and P1.4 is
- * toggled to show that an interrupt happened. If P2.0 is still low then the
- * interrupt edge is switched to trigger when P2.0 goes from low to high. This
- * way an interrupt occurs on every voltage change of P2.0.
- * MSP430i2041
- * --|RST P2.0|<--Input Signal
- * | P1.4|-->LED
- * Author: Zack Lalanne
- #include "driverlib.h"
- int main(void) {
- WDT_hold(WDT_BASE);
- // Set P1.4 as output pin to drive the LED
- GPIO_setAsOutputPin(GPIO_PORT_P1, GPIO_PIN4);
- // Setup P2.0 to interrupt on High to Low transition
- GPIO_setAsInputPin(GPIO_PORT_P2, GPIO_PIN0);
- GPIO_selectInterruptEdge(GPIO_PORT_P2, GPIO_PIN0,
- GPIO_HIGH_TO_LOW_TRANSITION);
- GPIO_clearInterrupt(GPIO_PORT_P2, GPIO_PIN0);
- GPIO_enableInterrupt(GPIO_PORT_P2, GPIO_PIN0);
- // Go into LPM0 with interrupts enabled
- __bis_SR_register(LPM0_bits | GIE);
- #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
- #pragma vector=PORT2_VECTOR
- __interrupt
- #elif defined(__GNUC__)
- __attribute__((interrupt(PORT2_VECTOR)))
- #endif
- void PORT2_ISR(void) {
- switch(__even_in_range(P2IV, 0x10))
- case 0x00: break; // No interrupt
- case 0x02: // P2.0 interrupt
- // Check current state of P2.0 and set correct interrupt edge to occur
- if(GPIO_getInputPinValue(GPIO_PORT_P2,
- GPIO_PIN0) == GPIO_INPUT_PIN_HIGH)
- else
- GPIO_LOW_TO_HIGH_TRANSITION);
- // Toggle 1.4 to indicate an interrupt occurred
- GPIO_toggleOutputOnPin(GPIO_PORT_P1, GPIO_PIN4);
- break;
- case 0x04: break; // P2.1 interrupt
- case 0x06: break; // P2.2 interrupt
- case 0x08: break; // P2.3 interrupt
- case 0x0A: break; // P2.4 interrupt
- case 0x0C: break; // P2.5 interrupt
- case 0x0E: break; // P2.6 interrupt
- case 0x10: break; // P2.7 interrupt
