[8/16-bit MCU] MC9S12HY64单片机的看门狗设置
1556|0
 楼主| tao180539 发表于 2015-11-2 16:10 | 显示全部楼层 |阅读模式
/* COP macros */
#if defined(_HCS12) || defined(HCS12) || defined(__HCS12__) || defined(__XGATE__)
#define _COPCTL_ADR  (0x34+0x08)
#define _COP_RST_ADR (0x34+0x0B) /* ARMCOP */
#else
#define _COPCTL_ADR  0x16
#define _COP_RST_ADR 0x17
#endif
/* Note COPCTL is write once. */
#define _ENABLE_COP(period)   ((*(volatile unsigned char*)_COPCTL_ADR)= (period)) /* Note: 7 longest possible COP duration. 0 == COP disabled. */
#define _ENABLE_COP_X() _ENABLE_COP(7) /* as long as possible */
#define _DISABLE_COP() _ENABLE_COP(0x00) /* COP is disabled if period is 0 */
#define _FEED_COP()   ((*(volatile unsigned char*)_COP_RST_ADR)= 0x55,(*(volatile unsigned char*)_COP_RST_ADR)= 0xAA)
关闭看门狗的时候 写入的寄存器是  _COPCTL_ADR  (0x34+0x08)   在数据手册上 这个地址对吗  找不到这个地址啊
