[Atmel]
用SAM-BA或JLINK跑ATSAM4E16的程序(7)ili93XX显示屏
824|0
这个是个驱动彩色显示屏ili93XX_LCD的例程。
这个例程使用了一个高难的东东----SMC
至于SMC是什么东东,数据手册上有说明。这个我想在以后好好研究一下。
从字面上看应是静态存贮控制
以下是运行效果:
这个程序先是初使化静态存贮,然后通过静态存贮控制显示屏。
程序如下:
#include "asf.h"
#include "stdio_serial.h"
#include "conf_board.h"
#include "conf_clock.h"
#include "smc.h"
/** Chip select number to be set */
#define ILI93XX_LCD_CS      1
struct ili93xx_opt_t g_ili93xx_display_opt;
*  Configure UART console.
static void configure_console(void)
        const usart_serial_options_t uart_serial_options = {
                .baudrate = CONF_UART_BAUDRATE,
                .paritytype = CONF_UART_PARITY
        /** Configure console UART. */
        sysclk_enable_peripheral_clock(CONSOLE_UART_ID);
        stdio_serial_init(CONF_UART, &uart_serial_options);
* \brief Application entry point for smc_lcd example.
* \return Unused (ANSI-C compatibility).
int main(void)
        sysclk_init();
        board_init();
        /** Initialize debug console */
        configure_console();
        /** Enable peripheral clock */
        pmc_enable_periph_clk(ID_SMC);
        /** Configure SMC interface for Lcd */
        smc_set_setup_timing(SMC, ILI93XX_LCD_CS, SMC_SETUP_NWE_SETUP(2)
                        | SMC_SETUP_NCS_WR_SETUP(2)
                        | SMC_SETUP_NRD_SETUP(2)
                        | SMC_SETUP_NCS_RD_SETUP(2));
        smc_set_pulse_timing(SMC, ILI93XX_LCD_CS, SMC_PULSE_NWE_PULSE(4)
                        | SMC_PULSE_NCS_WR_PULSE(4)
                        | SMC_PULSE_NRD_PULSE(10)
                        | SMC_PULSE_NCS_RD_PULSE(10));
        smc_set_cycle_timing(SMC, ILI93XX_LCD_CS, SMC_CYCLE_NWE_CYCLE(10)
                        | SMC_CYCLE_NRD_CYCLE(22));
#if ((!defined(SAM4S)) && (!defined(SAM4E)))
        smc_set_mode(SMC, ILI93XX_LCD_CS, SMC_MODE_READ_MODE
                        | SMC_MODE_WRITE_MODE
                        | SMC_MODE_DBW_8_BIT);
#else
                        | SMC_MODE_WRITE_MODE);
#endif
        /** Initialize display parameter */
        g_ili93xx_display_opt.ul_width = ILI93XX_LCD_WIDTH;
        g_ili93xx_display_opt.ul_height = ILI93XX_LCD_HEIGHT;
        g_ili93xx_display_opt.foreground_color = COLOR_BLACK;
        g_ili93xx_display_opt.background_color = COLOR_WHITE;
        /** Switch off backlight */
        aat31xx_disable_backlight();
        /** Initialize LCD */
        ili93xx_init(&g_ili93xx_display_opt);
        /** Set backlight level */
        aat31xx_set_backlight(AAT31XX_AVG_BACKLIGHT_LEVEL);
        ili93xx_set_foreground_color(COLOR_WHITE);
        ili93xx_draw_filled_rectangle(0, 0, ILI93XX_LCD_WIDTH,
                        ILI93XX_LCD_HEIGHT);
        /** Turn on LCD */
        ili93xx_display_on();
        ili93xx_set_cursor_position(0, 0);
        /** Draw text, image and basic shapes on the LCD */
        ili93xx_set_foreground_color(COLOR_BLACK);
        ili93xx_draw_string(10, 20, (uint8_t *)"ili93xx_lcd example");
        ili93xx_set_foreground_color(COLOR_RED);
        ili93xx_draw_circle(60, 160, 40);
        ili93xx_set_foreground_color(COLOR_GREEN);
        ili93xx_draw_circle(120, 160, 40);
        ili93xx_set_foreground_color(COLOR_BLUE);
        ili93xx_draw_circle(180, 160, 40);
        ili93xx_set_foreground_color(COLOR_VIOLET);
        ili93xx_draw_line(0, 0, 240, 320);
        while (1) {
至于SMC的具体分析下一帖说明。
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2400
