| R: The stray capacitance might relatively increase, as the line-distance in between VOUT and A/D gets longer. If it will be totally 15pF or over, a series resistor ”R” should be used to effectively reduce such
 a stray capacitance. R should better be mounted as closely as possible to VOUT, and must be one
 thousandth or less of input impedance of A/D. For the reference, R=2k ohm is recommended.
 串联电阻可以减小寄生电容吗?为什么?
