AT45DB041B丢程序
2052|4
 楼主| weilj123 发表于 2009-4-20 23:23 | 显示全部楼层 |阅读模式
ST, TE, spi, pi, se
我有一个单片机读AT45DB041B程序,经常里面的数据丢失,是怎么一回事呀.可以帮我看看吗?
#include<AT45DB.h>
void SPI_MasterSend(uchar SData)
    SPDAT = SData;
    while(!(SPSTAT & 0x80))
    SPSTAT = 0xc0;
uchar AT45DB_SPI_Read(void)
    uchar R_Data;
    SPI_MasterSend(0x00);
    R_Data = SPDAT;
    return R_Data;
uchar AT45DB_Read_State(void)
    uchar m_nBusy;
    AT45DB_CS = 0;
    SPI_MasterSend(0xd7);
    m_nBusy =AT45DB_SPI_Read();
    AT45DB_CS = 1;
    return m_nBusy;
void AT45DB_ContinuousArrayRead(uint Page_Addr,uint Page_InAddr,uchar *R_Data,uchar Length)
    uchar i;
    while(!(AT45DB_Read_State() & 0x80))
    AT45DB_CS = 0;
    SPI_MasterSend(0xe8);
    SPI_MasterSend((uchar)(Page_Addr >> 7));
    SPI_MasterSend((uchar)((Page_Addr << 1) | (Page_InAddr >> 8)));
    SPI_MasterSend((uchar)(Page_InAddr));
    for(i=0;i<Length;i++)
        R_Data = AT45DB_SPI_Read();
    AT45DB_CS = 1;
    return;
void AT45DB_Write_To_Page_AutoErase(uchar Buffer,uint Buffer_Addr,uint Page_Addr,uchar *W_Data,uchar Length)
    uchar i;
    AT45DB_CS = 0;
    switch (Buffer)
        case 1:
            SPI_MasterSend(0x82);
            break;
        case 2:
            SPI_MasterSend(0x85);
            break;
        default :
            AT45DB_CS = 1;
            return;
    SPI_MasterSend((uchar)((Page_Addr << 1) | (Buffer_Addr >> 8)));
    SPI_MasterSend((uchar)(Buffer_Addr));
        SPI_MasterSend(W_Data);
    AT45DB_CS = 1;
    return;
 楼主| weilj123 发表于 2009-4-21 11:56 | 显示全部楼层
没有人回答哦,有没有哪个同仁遇到相同的问题吗
主要是在雷击时会掉程序,
 楼主| weilj123 发表于 2009-4-23 19:44 | 显示全部楼层
晕,还是没有人回答一下
123
jxb163 发表于 2009-6-23 09:14 | 显示全部楼层
这个问题问的我心寒,加在电阻上的电压是多少?把电阻放在冰箱里,你测一下温度是多少?放在火星上你再测下温度?
bioe 发表于 2009-9-27 16:42 | 显示全部楼层
