[技术问答] N79E8132如何用ISP写掉电**
2967|24
天灵灵地灵灵 发表于 2015-11-19 22:53 | 显示全部楼层
void Flash_Page_Erase(unsigned int address)
        Enable_ISP();
        ISPCN=0x22;
        ISPAH=address/256;
        ISPAL=address%256;
        Trigger_ISP();
        Disable_ISP();
页面擦除。
ivanchowst 发表于 2015-12-3 16:35 | 显示全部楼层
bit EA_Save_bit = 1;
void Clear_BOF(void)
    EA_Save_bit = EA;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    PMCR &= 0xF3;
    EA = EA_Save_bit;
void Enable_ISP_Mode(void)
    /* Enable ISP  */
ISPCN=0x30;
    EA_Save_bit = EA;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    CHPCON |= 0x01;
    EA = 1;
Trigger_ISP();
void Disable_ISP_Mode(void)
    /* Disable ISP */
ISPCN=0x30;
Trigger_ISP();
    EA_Save_bit = EA;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    CHPCON &= 0xFE;
    EA = 1;//EA_Save_bit;
void Trigger_ISP(void)
    EA_Save_bit = EA;
    EA = 0;
    EA = 0;
    TA = 0xAA;
    TA = 0x55;
    ISPTRG |= 0x01;//start
void Erase_DATA(void)
    static uint u16Count;
    Enable_ISP_Mode();
    ISPCN = ERASE_ALL_DATA;
    for(u16Count=96;u16Count<128;u16Count++)
        ISPAL = LOBYTE(u16Count*128);               // 96*128=12288=0x3000
        ISPAH = HIBYTE(u16Count*128);               // 96*128=12288=0x3000
        Trigger_ISP();
    Disable_ISP_Mode();
void Read_DATA(void)
uchar j = 0;
Enable_ISP_Mode();
    ISPAL = 0x00;
    ISPAH = 0x30;
    ISPCN = FLASH_READ_DATA;
if(j < 4)
        Trigger_ISP();
  status_buff.flash_value[j] = ISPFD;
        ISPAL++;
        if(ISPAL == 0)
            ISPAH++;
j++;
Disable_ISP_Mode();
void Program_DATA(void)
uchar j = 0;
    Enable_ISP_Mode();
    ISPAL = 0x00;
    ISPAH = 0x30;
    ISPCN = BYTE_PROGRAM_DATA;
if(j < 4)
     ISPFD = status_buff.flash_value[j];
        Trigger_ISP();
        ISPAL++;
        if(ISPAL == 0)
            ISPAH++;
j++;
Disable_ISP_Mode();
有大神可以帮我指点上面的程序在N79E815芯片中为什么没办法工作呢?
本人想要将键值保存到下次开机显示,请问我该怎么修改?@版主
QQ715209572 发表于 2016-5-10 16:19 | 显示全部楼层
WWW 这个有限制的吗?
598330983 发表于 2016-5-11 10:52 | 显示全部楼层
有寄存器可以通过ISP方式在Flash写数据的。
