[STM32F0] 板子接收PC端发送的数据
3483|33
 楼主| wu93111 发表于 2015-11-17 10:31 | 显示全部楼层 |阅读模式
pc, IO, pi, gp, GPIO
刚接触这个,用的NUCLEO-F030R8的板子,我现在能做的都改了,板子就是接收不到数据,我把小程序图了,哪位大哥有时间帮我看一下的,万分感谢
#include "main.h"
/** @addtogroup IO_Toggle
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static __IO uint32_t TimingDelay;
uint8_t __IO BlinkSpeed = 0;
/* Private function prototypes -----------------------------------------------*/
RCC_ClocksTypeDef RCC_Clocks;
USART_InitTypeDef USART2_InitStruct;
NVIC_InitTypeDef NVIC_InitStructure;
/* Private functions ---------------------------------------------------------*/
  * @brief   Main program
  * @param  None
  * @retval None
void USART2_IRQHandler (void)//Öжϴ¦Àíº¯Êý
        if (USART_GetFlagStatus(USART2,USART_FLAG_RXNE) ==SET)
                 USART_SendData(USART2,USART_ReceiveData(USART2));
                 while (!USART_GetFlagStatus(USART2,USART_FLAG_TC));
        USART_ClearITPendingBit(USART2,USART_IT_RXNE);//Öжϱê־λ
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f030.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f0xx.c file
  /* SysTick end of count event each 1ms */
  RCC_GetClocksFreq(&RCC_Clocks);
  SysTick_Config(RCC_Clocks.HCLK_Frequency / 1000);
  /* Initialize LED2 */
  STM_EVAL_LEDInit(LED2);
  /* Initialize User_Button on STM32NUCLEO */
  STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_EXTI);
  /* Initiate Blink Speed variable */
  BlinkSpeed = 0;
  USART_StructInit(&USART2_InitStruct);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_1);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_1);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_1);
  GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_1);
//nvic
  //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  //NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  //NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelPriority= 0x03;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
USART_DeInit(USART2);
USART_Init(USART2, &USART2_InitStruct);
USART_ITConfig(USART2,USART_IT_RXNE,ENABLE);
USART_ClearFlag (USART2,USART_FLAG_TC);
USART_Cmd(USART2, ENABLE);
  /* Infinite loop */
  while (1)
    /* Test on blink speed */
    if(BlinkSpeed == 0)
      /*LED2 Toggle each 50ms*/
      STM_EVAL_LEDToggle(LED2);
      Delay(50);
    else if(BlinkSpeed == 1)
      /*LED2 Toggle each 200ms */
      Delay(200);
  //USART_SendData(USART2, 0x5555);
* @brief  Inserts a delay time.
* @param  nTime: specifies the delay time length, in 1 ms.
* @retval None
void Delay(__IO uint32_t nTime)
  TimingDelay = nTime;
  while(TimingDelay != 0);
* @brief  Decrements the TimingDelay variable.
* @param  None
* @retval None
void TimingDelay_Decrement(void)
  if (TimingDelay != 0x00)
    TimingDelay--;
#ifdef  USE_FULL_ASSERT
* @brief  Reports the name of the source file and the source line number
*         where the assert_param error has occurred.
* @param  file: pointer to the source file name
* @param  line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
  ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
 楼主| wu93111 发表于 2015-11-17 10:32 | 显示全部楼层
其中那个NVIC的设置不知道怎么搞,我杠掉的那个NVIC那里改怎么弄
 楼主| wu93111 发表于 2015-11-17 10:34 | 显示全部楼层
单独让板子循环发送0x5555是可以的,就是接不到
jjjkkk00 发表于 2015-11-17 10:53 | 显示全部楼层
这里面的USART2_InitStruct结构体未配置!
简单来说,就是你连串口的参数都没设置,怎么能够通讯的起来。
jjjkkk00 发表于 2015-11-17 10:55 | 显示全部楼层
最简单的是用STM32 CUBE软件,自动生成。
好久不用3.0的库了,看着有点陌生了
jjjkkk00 发表于 2015-11-17 10:57 | 显示全部楼层
  1. void connectUsart1ToExt(uint32_t baudrate, uint8_t parity, uint8_t length, uint8_t stopbits)
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         USART_InitTypeDef USART_InitStructure;
  5.
  6. #if defined  (STM32F051) || defined (STM32F042)
  7.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  8.
  9.         // GPIOµÄ¹«¹²ÌØÐÔ
  10.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  11.         //COM1
  12.         //USARTx_TX   GPIO_Mode_AF_PP
  13.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  14.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  15.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  16.         GPIO_InitStructure.GPIO_Pin = GetPinOf(ST_COM1_Tx);
  17.         GPIO_Init(GetPortOf(ST_COM1_Tx) , &GPIO_InitStructure);
  18.         SetAF_COM1_Tx;//±ØÐëÑ¡Ôñ¸´Óù¦ÄÜ
  19.         //USARTx_RX   GPIO_Mode_AF_PP & IPU
  20.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  21.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  22.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  23.         GPIO_InitStructure.GPIO_Pin = GetPinOf(ST_COM1_Rx);
  24.         GPIO_Init(GetPortOf(ST_COM1_Rx), &GPIO_InitStructure);
  25.         SetAF_COM1_Rx;//±ØÐëÑ¡Ôñ¸´Óù¦ÄÜ
  26.
  27.         //RS485-DE
  28.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  29.         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  30.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  31.         GPIO_InitStructure.GPIO_Pin = GetPinOf(ST_COM1_DE);
  32.         GPIO_Init(GetPortOf(ST_COM1_DE), &GPIO_InitStructure);
  33.         GPIO_SetBits(RS485_DE);
  34.
  35. #else
  36.         #warning "Make sure needn't define STM32F051 etc. ?"
  37. #endif
  38.   USART_Cmd(USART1, DISABLE); //ÓÃ×÷ÖØÐÂÅäÖÃUSART1£¬Ïȹش®¿Ú
  39.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  40.   RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1, ENABLE);
  41.   RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1, DISABLE);
  42.
  43.   USART_InitStructure.USART_BaudRate = baudrate;
  44.
  45.   switch (parity)
  46.   {
  47.   case 1://Ææ
  48.     USART_InitStructure.USART_Parity = USART_Parity_Odd;
  49.     if (length == 7)
  50.       USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  51.     else
  52.       USART_InitStructure.USART_WordLength = USART_WordLength_9b;
  53.     break;
  54.   case 2://ż
  55.     USART_InitStructure.USART_Parity = USART_Parity_Even;
  56.     if (length == 7)
  57.       USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  58.     else
  59.       USART_InitStructure.USART_WordLength = USART_WordLength_9b;
  60.     break;
  61.   default://0ÎÞ8λÊý¾Ýλ
  62.     USART_InitStructure.USART_Parity = USART_Parity_No;
  63.     USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  64.     break;
  65.   }
  66.   switch (stopbits)
  67.   {
  68.   case 2:
  69.     USART_InitStructure.USART_StopBits = USART_StopBits_2;
  70.     break;
  71.   case 3:
  72.     USART_InitStructure.USART_StopBits = USART_StopBits_1_5;
  73.     break;
  74. #if defined  (STM32F051) || defined (STM32F042)
  75.   //null
  76. #elif defined (STM32F100) || defined (STM32F101) || defined (STM32F103)
  77.   case 0://±£ÁôSTM32F05²»Ö§³Ö,STM32F10Ö§³Ö
  78.         USART_InitStructure.USART_StopBits = USART_StopBits_0_5;
  79.         break;
  80. #else
  81.         #warning "Make sure needn't define STM32F051 etc. ?"
  82. #endif
  83.   default://1
  84.     USART_InitStructure.USART_StopBits = USART_StopBits_1;
  85.     break;
  86.   }
  87.
  88.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  89.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  90.   USART_Init(USART1, &USART_InitStructure);
  91.
  92.   USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  93.   USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
  94.   USART_Cmd(USART1, ENABLE);
  95. }
jjjkkk00 发表于 2015-11-17 10:59 | 显示全部楼层
NVIC是配置中断优先级的。如果要用中断接收,必须配置。
 楼主| wu93111 发表于 2015-11-17 11:00 | 显示全部楼层
简单来说,就是你连串 ...
串口参数在usart.c里面有,它原先就写在那,应该没事吧,毕竟我的循环发送是可以的,就是这个接收不到
jjjkkk00 发表于 2015-11-17 11:02 | 显示全部楼层
上传一份很久之前的STM32 API使用手册。貌似是2.0版本的库。
使用3.0版本可以参考,大致没怎么变化。 stm32固件数据库.pdf (2.79 MB, 下载次数: 2)
jjjkkk00 发表于 2015-11-17 11:06 | 显示全部楼层
串口参数在usart.c里面有,它原先就写在那,应该没事吧,毕竟我的循环发送是可以的,就是这个接收不到 ...
那就是中断未使能的问题了NVIC。
yklstudent 发表于 2015-11-17 11:08 | 显示全部楼层
刚好在弄STM32F070,跟030差不多,发个我设置的USART初始化函数;
static void xMBPortUsartInit(uint32_t ulBaudRate)
        USART_DeInit(cCOM1);
        /* Enable GPIO clock */
        RCC_AHBPeriphClockCmd(cCOM1_TX_GPIO_CLK | cCOM1_RX_GPIO_CLK, ENABLE);
        /* Enable USART clock */
        RCC_APB2PeriphClockCmd(cCOM1_CLK, ENABLE);
        /* Connect PXx to USARTx_Tx */
        GPIO_PinAFConfig(cCOM1_TX_GPIO_PORT, cCOM1_TX_SOURCE, cCOM1_TX_AF);
        /* Connect PXx to USARTx_Rx */
        GPIO_PinAFConfig(cCOM1_RX_GPIO_PORT, cCOM1_RX_SOURCE, cCOM1_RX_AF);
        /* Configure USART Tx as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = cCOM1_TX_PIN;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_Init(cCOM1_TX_GPIO_PORT, &GPIO_InitStructure);
        /* Configure USART Rx as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = cCOM1_RX_PIN;
        GPIO_Init(cCOM1_RX_GPIO_PORT, &GPIO_InitStructure);
        USART_InitStructure.USART_BaudRate = ulBaudRate;
        /* USART configuration */
        USART_Init(cCOM1, &USART_InitStructure);
        //USART_ClearITPendingBit(cCOM1, USART_IT_RXNE);
        //USART_ClearITPendingBit(cCOM1, USART_IT_TC);
        //USART_ClearITPendingBit(cCOM1, USART_IT_TXE);
        /* Enable USART RX Interrupt */
        //USART_ITConfig_Boot(cCOM1, USART_IT_RXNE, ENABLE);
        /* Disable USART TX Interrupt */
        //USART_ITConfig_Boot(cCOM1, USART_IT_TC, DISABLE);
        /* Enable USART */
        USART_Cmd(cCOM1, ENABLE);
        /* Enable the USART Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
/* ----------------------- Start implementation -----------------------------*/
void
vMBPortSerialEnable( BOOL xRxEnable, BOOL xTxEnable )
    if( xRxEnable )
                USART_ITConfig(cCOM1, USART_IT_RXNE, ENABLE);
    else
                USART_ITConfig(cCOM1, USART_IT_RXNE, DISABLE);
    if( xTxEnable )
                USART_ITConfig(cCOM1, USART_IT_TXE, ENABLE);
    else
                USART_ITConfig(cCOM1, USART_IT_TXE, DISABLE);
jjjkkk00 发表于 2015-11-17 11:13 | 显示全部楼层
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);//分组任意选
  /* Enable the PPPInterrupts */
注意:不同版本的库,结构体的成员有变化(依实际为准)
jjjkkk00 发表于 2015-11-17 11:15 | 显示全部楼层
static void xMBPortUsartInit(uint32_t  ...
都是CM0的,初始化函数是通用的。
jjjkkk00 发表于 2015-11-17 11:16 | 显示全部楼层
刚开始入手STM32的话,还是建议使用官网的STM32Cube工具自动生成。配置起来很方便,外设(比如USART)的三种通讯方式(轮询、中断、DMA)的驱动都是直接可以用,省去了自己摸索的时间。
可以自动生成KEIL / IAR的工程文件。
STM32Cube.pdf (1.48 MB, 下载次数: 3)
 楼主| wu93111 发表于 2015-11-17 12:38 | 显示全部楼层
我的只有三个成员,那两个preemption和sub我可以不用吗,还是自己在加,但我好像加了错的
刚开始入手STM32的话,还是建议使用官网的STM32Cube工具自动生成。配置起来很方便,外设(比如USART)的三 ...
好,先看看
 楼主| wu93111 发表于 2015-11-17 14:49 | 显示全部楼层
大哥,基于我上面的代码,我的中断处理函数应该放在哪里让他调用
 楼主| wu93111 发表于 2015-11-17 14:50 | 显示全部楼层
你的这个没有中断处理函数吗,大哥,基于我上面的代码,我的中断处理函数应该放在哪里让他调用
exson_2006 发表于 2015-11-17 14:56 | 显示全部楼层
学习了
jjjkkk00 发表于 2015-11-17 17:39 | 显示全部楼层
放在类似"stm32f10x_it.c"文件中,同时在头文件(类似"stm32f10x_it.h")中申明。
重点是申明,可以在头文件中“void USART2_IRQHandler (void);”,或者在源文件中“extern void USART2_IRQHandler (void);”来获取。只要编译器能够找到,其他的不重要!
