我在用FSMC+EMWIN驱动ILI9486的屏时例子里对RS的口不能更改,只能在G0口(A10),换到其它的地址口不行,如G1(A11), 地址也从0X800改到0X1000都不行,又试了F0(A0)都不行,两天了。。。郁闷。故障的代码:RS一直输出低电平,只是在复位后开始有几个脉冲。不知有知道问题的前辈吗?
我刚才又打开以前的一个工程,在里面不论如何修改RS对应的口,只要写入的BACK1地址跟着改变,RS都会有正常的波形,就这个问题工程只能用G0口.而且别的地方也没用到这个口啊。
#define ILI9486_BASE ((uint32_t)(0x60000000 | 0x0C000000))
#define ILI9486_REG *(__IO uint16_t *)(ILI9486_BASE)
#define ILI9486_RAM *(__IO uint16_t *)(ILI9486_BASE + 0x1000)
void LCD_GPIOInit(void)
// LCD_CtrlLinesConfig();
// LCD_FSMCConfig();
FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure;
FSMC_NORSRAMTimingInitTypeDef readWriteTiming;
FSMC_NORSRAMTimingInitTypeDef writeTiming;
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE); //使能FSMC时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE
|RCC_APB2Periph_GPIOG|RCC_APB2Periph_GPIOF|RCC_APB2Periph_AFIO,ENABLE);//使能PORTB,D,E,G以及AFIO复用功能时钟
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //PB0 推挽输出 背光
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
// GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
// GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //PF8复液晶屏位
GPIO_Init(GPIOF, &GPIO_InitStructure);
//PORTD复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_14|GPIO_Pin_15; //PORTD复用推挽输出
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
GPIO_Init(GPIOD, &GPIO_InitStructure);
//PORTE复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15; //PORTD复用推挽输出
GPIO_Init(GPIOE, &GPIO_InitStructure);
//PORTG12复用推挽输出 片选
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_Init(GPIOG, &GPIO_InitStructure);
// PG0复用推挽输出 RS脚 REG RAM的选择
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //只能用PG0,不能用PG1
readWriteTiming.FSMC_AddressSetupTime = 0x01; //地址建立时间(ADDSET)为2个HCLK 1/36M=27ns
readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到
readWriteTiming.FSMC_DataSetupTime = 0x0f; // 数据保存时间为16个HCLK,因为液晶驱动IC的读数据的时候,速度不能太快,尤其对1289这个IC。
readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
readWriteTiming.FSMC_CLKDivision = 0x00;
readWriteTiming.FSMC_DataLatency = 0x00;
readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A
writeTiming.FSMC_AddressSetupTime = 0x02; //0x01 地址建立时间(ADDSET)为1个HCLK
writeTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(A
writeTiming.FSMC_DataSetupTime = 0x05; ////0x03 数据保存时间为4个HCLK
writeTiming.FSMC_BusTurnAroundDuration = 0x00;
writeTiming.FSMC_CLKDivision = 0x00;
writeTiming.FSMC_DataLatency = 0x00;
writeTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A
FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;// 这里我们使用NE4 ,也就对应BTCR[6],[7]。
FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // 不复用数据地址
FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM; //SRAM
FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; // 存储器写使能
FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable; // 读写使用不同的时序
FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //读写时序
FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming; //写时序
FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); //初始化FSMC配置
FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE); // 使能BANK1
