STM32 Forth
2425|1
 楼主| yjmwxwx 发表于 2015-12-26 17:33 | 显示全部楼层 |阅读模式
MbedForth                Table of Contents
here is an implementation of Forth language for mbed evaluation board. Forth is a rather old programming tool that should have a new birth for embedded systems.
this riscy-cortex forth is a tethered forth (host computer run a tcl script) but you can easily generate new kernel, including new words, that would be standalone.
all original work and credits to Frank Sergeantthis is only a cutomization of riscy pygness cortex forth  :http://pygmy.utoh.org/riscy/cortex/
see manual section for more informations
mbed port use CMSIS code and uart.c from coookbook
you need an arm-eabi tool chain (CodeSourcery, developed with version arm-2010.09) but it should be doable with online compiler.
Files Description
  • make.bin : build script, with comments
  • c2forth.c : main C files
  • uart.c : uart0 (usb bridge) driver
cmsis files
  • core_cm3.c  : cortex-m3 specific
  • core_cm3.h
  • LPC17xx.ld : linker script
  • system_LPC17xx.h : lpc1768 specific
  • system_LPC17xx.c : clock selection/PLL init/...
  • startup_LPC17xx.s : startup file (C runtime : executed before c2forth main() entry point)
  • LPC17xx.h
forth
  • riscy-lpc17xx.asm : forth VM (uses specific macros, parsed by preasm.tcl)
  • kernel.fth : Forth high level WORDS
Tcl application to build/execute forth
  • preasm.tcl : tcl tool used to create riscy.s from ricy-lpc17xx.asm
  • riscy.tcl (& util.tcl) : flashing kernel utility / interactive console to mbedforth
intermediate files (see make.bin)
  • riscy.s
  • riscy.elf
  • riscy.bin
  • riscy.lnkt riscy.lst map
  • kernel.dictionary
  • kernel.bin : ready to flash arm executable
zipped filesall you need is here /media/uploads/raph38130/forthcortex.zip
for the impatient
./riscy.tcl -image kernel.dictionary -port /dev/ttyACM0
wait for > prompt, then try following examples (end line with ENTER, forth should answer ok) :
9 8 + .
ledOn
ledOff
WORDS
TODO
  • some specific low level words (gpio...)
  • a Java implementation instead of Tcl tools sets
你瞅啥 发表于 2019-1-27 14:20 | 显示全部楼层
CodeSourcery早就不对外开放了。
