[ZLG-ARM] 用EASYARM2100 的KEIL版编译过不去?求救!
4039|2
 楼主| sunlong 发表于 2008-9-23 11:25 | 显示全部楼层 |阅读模式
用周工网上提供的EasyARM_Keil模板里的EasyARM2100在编译时,总是提示如下信息:<br />src\Startup.s(168):&nbsp;warning:&nbsp;A1608W:&nbsp;MOV&nbsp;pc,&ltrn&gt&nbsp;instruction&nbsp;used,&nbsp;but&nbsp;BX&nbsp;&ltrn&gt&nbsp;is&nbsp;preferred<br />src\Startup.s(210):&nbsp;warning:&nbsp;A1608W:&nbsp;MOV&nbsp;pc,&ltrn&gt&nbsp;instruction&nbsp;used,&nbsp;but&nbsp;BX&nbsp;&ltrn&gt&nbsp;is&nbsp;preferred<br />compiling&nbsp;main.c...<br />src\main.c(105):&nbsp;warning:&nbsp;&nbsp;#111-D:&nbsp;statement&nbsp;is&nbsp;unreachable<br />linking...<br />Project.axf:&nbsp;Warning:&nbsp;L6305W:&nbsp;Image&nbsp;does&nbsp;not&nbsp;have&nbsp;an&nbsp;entry&nbsp;point.&nbsp;(Not&nbsp;specified&nbsp;or&nbsp;not&nbsp;set&nbsp;due&nbsp;to&nbsp;multiple&nbsp;choices.)<br />Project.axf:&nbsp;Error:&nbsp;L6238E:&nbsp;startup.o(vectors)&nbsp;contains&nbsp;invalid&nbsp;call&nbsp;from&nbsp;'~PRES8'&nbsp;function&nbsp;to&nbsp;'REQ8'&nbsp;function&nbsp;FIQ_Exception.<br />Project.axf:&nbsp;Error:&nbsp;L6238E:&nbsp;startup.o(vectors)&nbsp;contains&nbsp;invalid&nbsp;call&nbsp;from&nbsp;'~PRES8'&nbsp;function&nbsp;to&nbsp;'REQ8'&nbsp;function&nbsp;TargetResetInit.<br />Target&nbsp;not&nbsp;created<br />不知道什么问题?用keil-ads模板也一样
zlg_lly 发表于 2008-9-23 12:35 | 显示全部楼层
RE:sunlong
您好!<br />如果您使用的是我公司代理的正版Keil的话,您可以致电020-28267808(郑工)进行咨询。
xinhard 发表于 2020-4-4 17:13 | 显示全部楼层
你好,我也出现了同样的问题。你的问题解决了吗?能否说下解决方法
