用移植到stm32的ucos写串口中断为什么一直死机
11112|9
 楼主| 高密度 发表于 2008-6-26 11:54 | 显示全部楼层 |阅读模式
用移植到stm32的ucos写串口中断为什么一直死机啊,研究快两天了,请大侠指点一二。谢谢
中断处理函数
void USART1_IRQHandler(void)
    OS_CPU_SR  cpu_sr;
UCOS_II_REENTRANT_ISR_PROLOG UCOS_II_REENTRANT_ISR_EPILOG
    OS_ENTER_CRITICAL();;
    OSIntNesting++;
   OS_EXIT_CRITICAL();
  if(USART_GetITStatus(USART1, USART_IT_RXNE) == SET)
     data = (USART_ReceiveData(USART1) & 0x7F);
     USART_ClearITPendingBit(USART1, USART_IT_RXNE);
    OSIntExit();
向量表
;                             INTERRUPT VECTORS
;                                    ARM
;                             KEIL's uVision3
;                   (RealView Microprocessor Developer Kit)
; Filename      : vectors.s
                PRESERVE8
                AREA   VECT, CODE, READONLY                     ; Name this block of code                                   ;
                THUMB
                ENTRY
;                                  IMPORTS
                IMPORT    Tmr_TickISR_Handler
;                IMPORT  ProbeRS232_RxTxISRHandler
                IMPORT    USART1_IRQHandler
                IMPORT    OSPendSV
                IMPORT  ResetHndlr
                IMPORT  ||Image$$ARM_LIB_STACK$$ZI$$Limit||     ; Import stack limit from scatter-loading file              ;
;                                  EXPORTS
                ;EXPORT    USART1_IRQHandler
;                                DEFINITIONS
;                      INITIALIZE EXCEPTION VECTORS
Vectors
        DCD     ||Image$$ARM_LIB_STACK$$ZI$$Limit||         ;  0, SP start value.
        DCD     ResetHndlr                                  ;  1, PC start value.
        DCD     App_NMI_ISR                                 ;  2, NMI
        DCD     App_Fault_ISR                               ;  3, Hard Fault
        DCD     App_Spurious_ISR                            ;  4, Memory Management
        DCD     App_Spurious_ISR                            ;  5, Bus Fault
        DCD     App_Spurious_ISR                            ;  6, Usage Fault
        DCD     0                                           ;  7, Reserved
        DCD     0                                           ;  8, Reserved
        DCD     0                                           ;  9, Reserved
        DCD     0                                           ; 10, Reserved
        DCD     App_Spurious_ISR                            ; 11, SVCall
        DCD     App_Spurious_ISR                            ; 12, Debug Monitor
        DCD     App_Spurious_ISR                            ; 13, Reserved
        DCD     OSPendSV                                    ; 14, PendSV Handler
        DCD     Tmr_TickISR_Handler                         ; 15, uC/OS-II Tick ISR Handler
        DCD     App_Spurious_ISR                            ; 16, INTISR[  0], Window Watchdog
        DCD     App_Spurious_ISR                            ; 17, INTISR[  1]  PVD through EXTI Line Detection
        DCD     App_Spurious_ISR                            ; 18, INTISR[  2]  Tamper Interrupt
        DCD     App_Spurious_ISR                            ; 19, INTISR[  3]  RTC Global Interrupt
        DCD     App_Spurious_ISR                            ; 20, INTISR[  4]  FLASH Global Interrupt
        DCD     App_Spurious_ISR                            ; 21, INTISR[  5]  RCC Global Interrupt
        DCD     App_Spurious_ISR                            ; 22, INTISR[  6]  EXTI Line0 Interrupt
        DCD     App_Spurious_ISR                            ; 23, INTISR[  7]  EXTI Line1 Interrupt
        DCD     App_Spurious_ISR                            ; 24, INTISR[  8]  EXTI Line2 Interrupt
        DCD     App_Spurious_ISR                            ; 25, INTISR[  9]  EXTI Line3 Interrupt
        DCD     App_Spurious_ISR                            ; 26, INTISR[ 10]  EXTI Line4 Interrupt
        DCD     App_Spurious_ISR                            ; 27, INTISR[ 11]  DMA Channel1 Global Interrupt
        DCD     App_Spurious_ISR                            ; 28, INTISR[ 12]  DMA Channel2 Global Interrupt
        DCD     App_Spurious_ISR                            ; 29, INTISR[ 13]  DMA Channel3 Global Interrupt
        DCD     App_Spurious_ISR                            ; 30, INTISR[ 14]  DMA Channel4 Global Interrupt
        DCD     App_Spurious_ISR                            ; 31, INTISR[ 15]  DMA Channel5 Global Interrupt
        DCD     App_Spurious_ISR                            ; 32, INTISR[ 16]  DMA Channel6 Global Interrupt
        DCD     App_Spurious_ISR                            ; 33, INTISR[ 17]  DMA Channel7 Global Interrupt
        DCD     App_Spurious_ISR                            ; 34, INTISR[ 18]  ADC Global Interrupt
        DCD     App_Spurious_ISR                            ; 35, INTISR[ 19]  USB High Priority / CAN TX  Interrupts
        DCD     App_Spurious_ISR                            ; 36, INTISR[ 20]  USB Low  Priority / CAN RX0 Interrupts
        DCD     App_Spurious_ISR                            ; 37, INTISR[ 21]  CAN RX1 Interrupt
        DCD     App_Spurious_ISR                            ; 38, INTISR[ 22]  CAN SCE Interrupt
        DCD     App_Spurious_ISR                            ; 39, INTISR[ 23]  EXTI Line[9:5] Interrupt
        DCD     App_Spurious_ISR                            ; 40, INTISR[ 24]  TIM1 Break  Interrupt
        DCD     App_Spurious_ISR                            ; 41, INTISR[ 25]  TIM1 Update Interrupt
        DCD     App_Spurious_ISR                            ; 42, INTISR[ 26]  TIM1 Trigger & Commutation Interrupts
        DCD     App_Spurious_ISR                            ; 43, INTISR[ 27]  TIM2 Global Interrupt
        DCD     App_Spurious_ISR                            ; 44, INTISR[ 28]  TIM3 Global Interrupt
        DCD     App_Spurious_ISR                            ; 45, INTISR[ 29]  TIM4 Global Interrupt
        DCD     App_Spurious_ISR                            ; 46, INTISR[ 30]  I2C1 Event  Interrupt
        DCD     App_Spurious_ISR                            ; 47, INTISR[ 31]  I2C1 Error  Interrupt
        DCD     App_Spurious_ISR                            ; 48, INTISR[ 32]  I2C2 Event  Interrupt
        DCD     App_Spurious_ISR                            ; 49, INTISR[ 33]  I2C2 Error  Interrupt
        DCD     App_Spurious_ISR                            ; 50, INTISR[ 34]  SPI1 Global Interrupt
        DCD     USART1_IRQHandler                             ; 51, INTISR[ 35]  SPI2 Global Interrupt
        DCD     App_Spurious_ISR                     ; 52, INTISR[ 36]  USART1 Global Interrupt
        DCD     App_Spurious_ISR                   ; 53, INTISR[ 37]  USART2 Global Interrupt
        DCD     App_Spurious_ISR                            ; 54, INTISR[ 38]  USART3 Global Interrupt
        DCD     App_Spurious_ISR                            ; 55, INTISR[ 39]  EXTI Line [15:10] Interrupts
        DCD     App_Spurious_ISR                            ; 56, INTISR[ 40]  RTC Alarm through EXT Line Interrupt
        DCD     App_Spurious_ISR                            ; 57, INTISR[ 41]  USB Wakeup from Suspend through EXTI Int.
;                          DEFAULT HANDLERS
App_NMI_ISR         B       App_NMI_ISR
App_Fault_ISR       B       App_Fault_ISR
App_Spurious_ISR    B       App_Spurious_ISR
                ALIGN
                END
 楼主| 高密度 发表于 2008-6-26 11:56 | 显示全部楼层
中断处理函数是这个
    OS_CPU_SR  cpu_sr;
    OSIntNesting++;
   OS_EXIT_CRITICAL();
    OSIntExit();
香水城 发表于 2008-6-26 11:58 | 显示全部楼层
移植错误或使用错误
我不会uCOS,帮不上忙
 楼主| 高密度 发表于 2008-6-26 12:52 | 显示全部楼层
那也谢谢香哥了。现在我感觉是中断处理函数没有问题
应该是向量表不对
个人感觉
cpufan 发表于 2008-6-26 13:48 | 显示全部楼层
换 st demo中的向量表试试看
 楼主| 高密度 发表于 2008-6-26 14:00 | 显示全部楼层
那样编译就通不过了,你看我改的vectors.s文件有问题吗?
dy008 发表于 2008-6-26 15:01 | 显示全部楼层
cortexM3使用uCos中的中断问题!
ucos的cortexm3移植模板均没有设置NVIC的优先级分组,使用的是默认级别,
当用户添加自己中断服务时应该将Tmr_TickISR_Handler调为最高,OSPendSV调为最低,自己的中断服务处于中间即可!
jtingwang 发表于 2008-6-26 17:43 | 显示全部楼层
前面是UART?后面是SPI?
anzil 发表于 2010-3-26 10:30 | 显示全部楼层
你这个中断处理程序只是接收中断处理,不是写中断。如果是写中断的话,只要你设置写中断允许,因为此时串口发送寄存器这时候本身就是空的,所以系统就会马上进到你现在的中断处理函数中,而你又没有对写中断做处理,系统就会死机。
yemingxp 发表于 2010-9-29 10:51 | 显示全部楼层
你这个中断处理程序只是接收中断处理,不是写中断。如果是写中断的话,只要你设置写中断允许,因为此时串口发送寄存器这时候本身就是空的,所以系统就会马上进到你现在的中断处理函数中,而你又没有对写中断做处理, ...
是不是答非所问了?别人没见开了写中断,哪有你说的情况?!
