[AVR单片机] 我的Makefile没有SRC项
3055|2
 楼主| 四叶草 发表于 2007-5-4 18:17 | 显示全部楼层 |阅读模式
我看的书说如有多个文件要编译的话,就在SRC项的后面加入文件名,但是我的Makefile没有SRC项,正确来讲我的winavr里面的例子也没有SRC项啊,但是我试过它的是可以编译多个文件的。请问我想编译多个文件应该怎么做呢?我的Winavr的例子如下:
PRG            = stdiodemo
OBJ            = stdiodemo.o hd44780.o lcd.o uart.o
MCU_TARGET     = atmega16
OPTIMIZE       = -Os
DEFS           =
LIBS           =
# You should not have to change anything below here.
CC             = avr-gcc
CFLAGS        = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) $(DEFS)
LDFLAGS       = -Wl,-Map,$(PRG).map
OBJCOPY        = avr-objcopy
OBJDUMP        = avr-objdump
all: $(PRG).elf lst text eeprom
$(PRG).elf: $(OBJ)
    $(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS)
clean:
    rm -rf *.o $(PRG).elf *.eps *.png *.pdf *.bak
    rm -rf *.lst *.map $(EXTRA_CLEAN_FILES)
lst:  $(PRG).lst
%.lst: %.elf
    $(OBJDUMP) -h -S $< > $@
# Rules for building the .text rom images
text: hex bin srec
hex:  $(PRG).hex
bin:  $(PRG).bin
srec: $(PRG).srec
%.hex: %.elf
    $(OBJCOPY) -j .text -j .data -O ihex $< $@
%.srec: %.elf
    $(OBJCOPY) -j .text -j .data -O srec $< $@
%.bin: %.elf
    $(OBJCOPY) -j .text -j .data -O binary $< $@
# Rules for building the .eeprom rom images
eeprom: ehex ebin esrec
ehex:  $(PRG)_eeprom.hex
ebin:  $(PRG)_eeprom.bin
esrec: $(PRG)_eeprom.srec
%_eeprom.hex: %.elf
    $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O ihex $< $@
%_eeprom.srec: %.elf
    $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O srec $< $@
%_eeprom.bin: %.elf
    $(OBJCOPY) -j .eeprom --change-section-lma .eeprom=0 -O binary $< $@
# Every thing below here is used by avr-libc's build system and can be ignored
# by the casual user.
JPEG2PNM                = jpegtopnm
PNM2EPS                 = pnmtops
JPEGRESOLUTION          = 180
EXTRA_CLEAN_FILES       = *.hex *.bin *.srec *.eps
dox: ${JPEGFILES:.jpg=.eps}
%.eps: %.jpg
    $(JPEG2PNM) $< |\
    $(PNM2EPS) -noturn -dpi $(JPEGRESOLUTION) -equalpixels \
我应该改哪里呢?我试过只改“OBJ”为对应的文件,还是不行啊
 楼主| 四叶草 发表于 2007-5-5 16:44 | 显示全部楼层
我找到了一个有src的
还是谢谢大家了
ATmega8515 发表于 2007-5-5 17:01 | 显示全部楼层
放上来啊
怎么生成SRC,放上来啊。
