摆脱小农意识,C#学完出学堂, 交上毕业“论文”
7368|39
 楼主| hotpower 发表于 2008-10-31 18:18 | 显示全部楼层 |阅读模式
C#, se, TE, Box, TI
Program.cs文件,主要是建立互斥,阻止多实例运行(方法还有许多)
using System;
using System.Collections.Generic;
using System.Linq;
using System.Windows.Forms;
using System.Threading;//Mutex类需要
namespace WindowsFormsApplication2
    static class Program
        /// <summary>
        /// 应用程序的主入口点。
        /// </summary>
        [STAThread]
        static void Main()
            bool createdNew;
            Mutex mutexFile = new Mutex(false, "WindowsFormsApplication2", out createdNew);//创建互斥
            if (createdNew)
            {//成功创建无进程运行
                Application.EnableVisualStyles();
                Application.SetCompatibleTextRenderingDefault(false);
                Application.Run(new Form1());
            else
            {//创建失败有进程在运行
                MessageBox.Show("对不起,有一进程在工作", "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
Form1.cs文件,程序的主体,主要是VS如何调用DLL,关闭窗口提示,异常的捕捉等.
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Runtime.InteropServices;//加动态链接库需要
    public partial class Form1 : Form
        [DllImport("winio.dll")]
        public static extern bool InitializeWinIo();
        public static extern bool GetPortVal(IntPtr wPortAddr, out int pdwPortVal, byte bSize);
        public static extern bool SetPortVal(uint wPortAddr, IntPtr dwPortVal, byte bSize);
        public static extern byte MapPhysToLin(byte pbPhysAddr, uint dwPhysSize, IntPtr PhysicalMemoryHandle);
        public static extern bool UnmapPhysicalMemory(IntPtr PhysicalMemoryHandle, byte pbLinAddr);
        public static extern bool GetPhysLong(IntPtr pbPhysAddr, byte pdwPhysVal);
        public static extern bool SetPhysLong(IntPtr pbPhysAddr, byte dwPhysVal);
        public static extern void ShutdownWinIo();
        [DllImport("user32.dll")]
        public static extern int MapVirtualKey(uint Ucode, uint uMapType);
        public Form1()
            InitializeComponent();
        private void Form1_FormClosing(object sender, FormClosingEventArgs e)
        {//捕捉窗体Close事件,关闭窗口时提示
            if (MessageBox.Show("请您确认是否退出(Y/N)", "系统提示", MessageBoxButtons.YesNo, MessageBoxIcon.Information) == DialogResult.Yes)
                try
                    ShutdownWinIo();
                catch (System.Exception error)
                {//WinIO卸载失败异常
                    MessageBox.Show(error.Message, "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
                e.Cancel = false;//允许退出系统
            else
                e.Cancel = true;//阻止退出系统
        private void timer1_Tick(object sender, EventArgs e)
        {//Timer定时到事件
            toolStripStatusLabel3.Text = System.DateTime.Now.ToString();
            if (toolStripProgressBar1.Value < toolStripProgressBar1.Maximum)
                toolStripProgressBar1.Value += toolStripProgressBar1.Step;
            else
                toolStripProgressBar1.Value = toolStripProgressBar1.Minimum;
        private void button2_Click(object sender, EventArgs e)
        {//WinIO读操作
            int pdwPortVal = 0;
            try
                uint wPortAddr = Convert.ToUInt32(comboBox1.Text, 16);
                if (GetPortVal((IntPtr)wPortAddr, out pdwPortVal, sizeof(byte)))
                    textBox2.Text = string.Format("{0:x02}", (byte)pdwPortVal);
                else
                    MessageBox.Show("WinIO读操作失败!!!", "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
            {//读出操作异常处理
            for (int i = 0; i < 8; i ++)
                switch (i)
                    case 0:
                        checkBox8.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 1:
                        checkBox7.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 2:
                        checkBox6.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 3:
                        checkBox5.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 4:
                        checkBox4.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 5:
                        checkBox3.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 6:
                        checkBox2.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 7:
                        checkBox1.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
        private void Form1_Load(object sender, EventArgs e)
        {//delphi一般在此初始化
            try
                InitializeWinIo();
            {//WinIO加载失败异常处理
        private void button1_Click(object sender, EventArgs e)
        {//WinIO写操作
            try
                int pdwPortVal = Convert.ToInt32(textBox1.Text, 16);
                if (!SetPortVal(wPortAddr, (IntPtr)pdwPortVal, sizeof(byte)))
                    MessageBox.Show("WinIO写入操作失败!!!", "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
            {//写入操作异常处理
        private void textBox1_KeyPress(object sender, KeyPressEventArgs e)
        {//与delphi一样的处理方法
            char ch = e.KeyChar;
            if (!((ch >= '0' && ch <= '9') || (ch >= 'a' && ch <= 'f') || (ch >= 'A' && ch <= 'F')))
                switch (ch)
                    case '\x08'://退格
                    case '\x0d'://回车
                        break;//放过
                    default:
                        e.KeyChar = '\x0';//放弃输入的非法字符
                        MessageBox.Show("请正确输入16进制数!!!", "系统提示", MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
                        break;
            else
            {//合法16进制数
                e.KeyChar |= ' ';//强制转换为小写字母
        private void button3_Click(object sender, EventArgs e)
        {//WinIO读操作
            int pdwPortVal = 0;
            try
                uint wPortAddr = Convert.ToUInt32(comboBox1.Text, 16) + 1;//状态口
                    textBox3.Text = string.Format("{0:x02}", (byte)pdwPortVal);
                else
            {//读出操作异常处理
            for (int i = 0; i < 8; i++)
                switch (i)
                    case 0:
                        checkBox9.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 1:
                        checkBox10.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 2:
                        checkBox11.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 3:
                        checkBox12.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 4:
                        checkBox13.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 5:
                        checkBox14.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 6:
                        checkBox15.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 7:
                        checkBox16.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
        private void textBox4_KeyPress(object sender, KeyPressEventArgs e)
        {//与delphi一样的处理方法
                switch (ch)
                    case '\x08'://退格
                    case '\x0d'://回车
                        break;//放过
                    default://捕捉到的非法字符
                        break;
            else
            {//合法16进制数
        private void button4_Click(object sender, EventArgs e)
        {//控制口WinIO写操作
            try
                uint wPortAddr = Convert.ToUInt32(comboBox1.Text, 16) + 2;//控制口
                int pdwPortVal = Convert.ToInt32(textBox4.Text, 16);
            {//写入操作异常处理
        private void button5_Click(object sender, EventArgs e)
        {//控制口WinIO读操作
            int pdwPortVal = 0;
            try
                    textBox5.Text = string.Format("{0:x02}", (byte)pdwPortVal);
                else
            {//读出操作异常处理
                switch (i)
                    case 0:
                        checkBox17.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 1:
                        checkBox18.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 2:
                        checkBox19.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 3:
                        checkBox20.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 4:
                        checkBox21.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 5:
                        checkBox22.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 6:
                        checkBox23.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
                    case 7:
                        checkBox24.Checked = ((pdwPortVal & (1 << i)) != 0) ? true : false;
                        break;
        private void xToolStripMenuItem_Click(object sender, EventArgs e)
        {//主菜单内退出系统
            Close();
        private void aToolStripMenuItem_Click(object sender, EventArgs e)
        {//主菜单的帮助
            MessageBox.Show("C#学习菜鸟作\nHotPower@126.com", "并口调试帮助提示", MessageBoxButtons.OK);
 楼主| hotpower 发表于 2008-10-31 18:30 | 显示全部楼层
哈哈~~~俺以后不玩CVI,BCB,DELPHI,VB,VC了~~~
dengm 发表于 2008-10-31 19:01 | 显示全部楼层
c# == C++++
C# ==
      C ||
ch2003_23 发表于 2008-10-31 19:14 | 显示全部楼层
hotpower成精了?学得这么快,佩服
 楼主| hotpower 发表于 2008-10-31 19:20 | 显示全部楼层
晕~~~和delphi操作一个套路,没什么学的~~~
俺不学都知道事件应该加到何处~~~
哈哈~~~摆脱“技巧”方能“熟能生巧”~~~
俺基本3天就会了~~~(可能多说了2天)
xiaoaihua 发表于 2008-10-31 19:26 | 显示全部楼层
我咋就没有那么好的天份呢?
HWM 发表于 2008-10-31 19:29 | 显示全部楼层
“层次”越高越好弄,否则前人的工作就没价值啦。
关键是摆脱“机器”思维,回归“人类”思维。
sodwell 发表于 2008-10-31 20:36 | 显示全部楼层
re
呵呵 是这样的!
HOT大叔有时间就学习学习QT吧 现在出QT4了,真正的跨平台,开源,学习乐趣无穷!
代码WINDOWS LINUX都可使用
学习WINDOWS编程 我怎么感觉不到乐趣了.......
 楼主| hotpower 发表于 2008-10-31 21:13 | 显示全部楼层
农家无银两~~~别人下班俺上学堂~~~
饿了凉水+馒头~~~
tdh03z 发表于 2008-10-31 22:02 | 显示全部楼层
晕,现在内存这么便宜也不扩充下
 楼主| hotpower 发表于 2008-10-31 23:03 | 显示全部楼层
晕~~~这是村里的~~~俺家里的T23都用了快6年了~~~
夜校上学堂结束~~~
“功课太繁重”~~~真想呕吐~~~
程序匠人 发表于 2008-10-31 23:12 | 显示全部楼层
裤子来了
hexenzhou 发表于 2008-11-1 08:46 | 显示全部楼层
感觉菜农不务正业,东戳一下,西戳一下。
 楼主| hotpower 发表于 2008-11-1 09:28 | 显示全部楼层
jack.king 发表于 2008-11-1 09:32 | 显示全部楼层
大叔的东西太多了我都眼花缭乱了
 楼主| hotpower 发表于 2008-11-1 09:44 | 显示全部楼层
多上学堂就不会“花眼”~~~
年轻时贪玩整天下棋耽误了“学业”~~~
如今别人休假,俺继续上“学堂”,总感觉比下棋“务些正业”~~~
哈哈~~~继续摆脱“技巧”,也好C~~~
sz_kd 发表于 2008-11-1 09:50 | 显示全部楼层
linqing171 发表于 2008-11-1 11:39 | 显示全部楼层
c#继承了delphi的快速开发 的优势
hot大叔跑的太快了,微软更新不过来了,没有新东西了。c#还没有普及呢。
风格上就是一个delphi。隐藏了消息等做程序的人不关心的过程,只有功能才是有用的。
虽然库函数效率很高,但是framework需要另外安装,并且性能的代价是内存的占用,如果内存达不到要求,性能反而更低。。。。。。。
等待 vista 普及,等待黑屏,为什么打开自动更新还不黑屏? 难道俺是番茄版的原因?
hsp8031 发表于 2008-11-1 12:05 | 显示全部楼层
三天即会?层次太低!
  低级语言只有高层次的人员才能玩。
  语言越高级,入门的门栏越低,低层次人员都可玩。要不现在单片机这么普及。
  等到有一天把人的语言写入单片机即可操控时,您也就是一个真正的菜农啦!
  如果真有这样的编译器,可每人写的单片机的效率还是不会一样。别把思想看成技巧,更别把技巧混谈为淫技!
dengm 发表于 2008-11-1 12:14 | 显示全部楼层
如果扩大 framework 一点,把win32 API Delete,内存就不用多少了
