求助,简单的单片机与FPGA并行通信
2176|0
 楼主| tong2gang 发表于 2007-8-2 23:54 | 显示全部楼层 |阅读模式
今天郁闷了一天,麻烦大侠们帮我看一下.
想写一条程序实现单片机并行发数据3个8位的数据给FPGA,共24位,FPGA提取前20位.一个时钟口和一个FPGA数据输出使能.时钟由单片机控制,每个时钟周期输入8位数据.程序如下,可就是实现不了.能帮个忙说下哪里没弄好吗?
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
Use ieee.std_logic_unsigned.all;
Entity Buf is
    port(datain:in std_logic_vector(7 downto 0);--数据进
        clk        :in std_logic;--时钟
        en         :in std_logic;--输出使能
        dataout:inout std_logic_vector(19 downto 0)--数据出
end Buf;
architecture rtl of Buf is
signal databuf:std_logic_vector(23 downto 0);
signal count:std_logic_vector(1 downto 0);
begin
    process(clk)
    begin
        if(clk 'event and clk='1')then
            if(count="10")then
                count<="00";
            else count<=count+1;
            end if;
        end if;
    end process;
    process(count)
    begin
            CASE count IS
                WHEN "00" =>
                    databuf(23 downto 16)<=datain;
                WHEN "01" =>
                    databuf(15 downto 8)<=datain;
                WHEN "10"=>
                    databuf(7 downto 0)<=datain;
                WHEN others =>
                    databuf<=databuf;
            END CASE;
    end process;
    process(clk)
    begin
        if(en='1')then
            dataout<=databuf(19 downto 0);
        else dataout<=dataout;
        end if;
    end process;
end rtl;
