启动ccs时会弹出如下对话框<br />CAN't initialize target cpu:<br />error Ox80000200/-1073<br />fatal error during:Initialization,ocs,<br />bad target silicon revision number<br />please check your multi-processor configuration.<br />the number of devices in the JTAG sCAN path<br />must be correct for the silicon revision to be read<br />or,you may have selected the wrong DSP device driver.<br /><br />I/O Port=0<br />Board Name: C54xx XDS510 Emulator<br />Cpu Name :CPU_1<br /><br /><br /><br />有谁遇到过这样的问题吗? 请指教!<br />我用的是瑞泰 ICKTEK-5100USB V2.0仿真器<br /><br /> |
