d12能枚举和不能枚举对比
4741|20
lovec51|  楼主 | 2007-9-25 13:03 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
我用D12做了两块不同的板,一块是5V系统,CPU工作在70MHz,采用ale来区分命令和数据,D12可以正常枚举,也可以稳定传输数据.另一块是3.3V系统,CPU工作在25MHz,采用A0来区分命令和数据,枚举不能通过,现象是goodlink灯不停闪烁,windows设备管理器也不停刷新,就像正常枚举最后出现D12那一刻一样,但是没有出现D12也不出现"不明设备",好像枚举最后一步出问题的样子(猜想).固件程序基本一致(除地址不同).示波器观察D12的13脚有正常的12M波形输出(猜测D12初始化没问题),读D12的ID也正常.下面把用bus hound抓取的枚举数据帖出来,希望高手指点:我用的是winxp操作系统.前面看帖子说xp看不到全部的枚举数据,那怎样才能看到全部枚举数据?
先贴出能正常枚举的数据:
Bus Hound 3.02 capture. Complements of www.perisoft.net
开机枚举成功
  Dev   - Device ID
  Time  - Elapsed time since the start of the previous Phase
  Phase - ADDR= 1394 transfer address  LOCK= 1394 lock transaction
          CDB = Command block          NSTS= NT status
          CTL = USB control packet     RSET= bus reset
          DI  = Data In                RSTS= I/O Request Status
          DO  = Data Out               SNS = SCSI Sense Data
          IDE = IDE task file command  SSTS= SCSI Request Block Status
          ISOC= Isochronous Transfer   USTS= USB status
  (9) Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
  (10) USB Root Hub [7KB/Sec]
  (11) Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
  (12) USB Root Hub
  (18) yy's D12-JB Board [5KB/Sec]
Dev  Phase  Data                       Info           Time   Cmd.Phase.Ofs
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS       0us         1.1.0
            01 00 04 00                                             1.1.8
10  DI     00 00 00 00 - 01 01 01 00  ........        29us         1.2.0
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS      12us         2.1.0
            01 00 04 00                                             2.1.8
10  DI     00 00 00 00 - 01 01 01 00  ........        27us         2.2.0
10  CTL    00 00 00 00 - 23 01 10 00  GET STATUS      20us         3.1.0
            01 00 00 00                                             3.1.8
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS      65us         4.1.0
            01 00 04 00                                             4.1.8
10  DI     00 00 00 00 - 01 01 00 00  ........        22us         4.2.0
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS     124ms         5.1.0
            01 00 04 00                                             5.1.8
10  DI     00 00 00 00 - 01 01 00 00  ........        35us         5.2.0
10  CTL    00 00 00 00 - 23 03 04 00  GET STATUS      18us         6.1.0
            01 00 00 00                                             6.1.8
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS      31ms         7.1.0
            01 00 04 00                                             7.1.8
10  DI     00 00 00 00 - 03 01 10 00  ........        28us         7.2.0
10  CTL    00 00 00 00 - 23 01 14 00  GET STATUS       3us         8.1.0
            01 00 00 00                                             8.1.8
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS      31ms         9.1.0
            01 00 04 00                                             9.1.8
10  DI     00 00 00 00 - 03 01 00 00  ........        29us         9.2.0
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS      36ms        10.1.0
            01 00 04 00                                            10.1.8
10  DI     00 00 00 00 - 03 01 00 00  ........        25us        10.2.0
10  CTL    00 00 00 00 - 23 03 04 00  GET STATUS      16us        11.1.0
            01 00 00 00                                            11.1.8
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS      26ms        12.1.0
            01 00 04 00                                            12.1.8
10  DI     00 00 00 00 - 03 01 10 00  ........        26us        12.2.0
10  CTL    00 00 00 00 - 23 01 14 00  GET STATUS       3us        13.1.0
            01 00 00 00                                            13.1.8
10  CTL    00 00 00 00 - 80 06 00 02  GET STATUS     101ms        14.1.0
            00 00 ff 00                                            14.1.8
10  DI     00 00 00 00 - 09 02 2e 00  ........       6.9ms        14.2.0
            01 01 00 60 - 01 09 04 00  ...`....                    14.2.8
            00 04 dc a0 - b0 00 07 05  ........                    14.2.16
            81 03 04 00 - 0a 07 05 01  ........                    14.2.24
            03 04 00 0a - 07 05 82 02  ........                    14.2.32
            40 00 0a 07 - 05 02 02 40  @......@                    14.2.40
            00 0a                      ..                          14.2.48
10  CTL    00 00 00 00 - a3 00 00 00  GET STATUS      18us        15.1.0
            02 00 04 00                                            15.1.8
10  DI     00 00 00 00 - 00 01 00 00  ........        21us        15.2.0
18  CTL    00 00 00 00 - 80 06 00 01  GET STATUS     5.6ms        16.1.0
            00 00 12 00                                            16.1.8
10  CTL    00 00 00 00 - 80 06 00 01  GET STATUS      10us        17.1.0
            00 00 12 00                                            17.1.8
10  DI     00 00 00 00 - 12 01 00 01  ........       4.3ms        17.2.0
            dc 00 00 10 - 71 04 66 06  ....q.f.                    17.2.8
            00 01 00 00 - 00 19        ......                      17.2.16
18  DI     00 00 00 00 - 12 01 00 01  ........         4us        16.2.0
            dc 00 00 10 - 71 04 66 06  ....q.f.                    16.2.8
            00 01 00 00 - 00 19        ......                      16.2.16
18  CTL    00 00 00 00 - 80 06 00 02  GET STATUS      18us        18.1.0
            00 00 09 00                                            18.1.8
10  CTL    00 00 00 00 - 80 06 00 02  GET STATUS      12us        19.1.0
            00 00 09 00                                            19.1.8
10  DI     00 00 00 00 - 09 02 2e 00  ........       3.9ms        19.2.0
            01 01 00 60 - 01           ...`.                       19.2.8
18  DI     00 00 00 00 - 09 02 2e 00  ........         3us        18.2.0
            01 01 00 60 - 01           ...`.                       18.2.8
18  CTL    00 00 00 00 - 80 06 00 02  GET STATUS      14us        20.1.0
            00 00 2e 00                                            20.1.8
10  CTL    00 00 00 00 - 80 06 00 02  GET STATUS       7us        21.1.0
            00 00 2e 00                                            21.1.8
10  DI     00 00 00 00 - 09 02 2e 00  ........       5.9ms        21.2.0
            01 01 00 60 - 01 09 04 00  ...`....                    21.2.8
            00 04 dc a0 - b0 00 07 05  ........                    21.2.16
            81 03 04 00 - 0a 07 05 01  ........                    21.2.24
            03 04 00 0a - 07 05 82 02  ........                    21.2.32
            40 00 0a 07 - 05 02 02 40  @......@                    21.2.40
            00 0a                      ..                          21.2.48
18  DI     00 00 00 00 - 09 02 2e 00  ........         2us        20.2.0
            01 01 00 60 - 01 09 04 00  ...`....                    20.2.8
            00 04 dc a0 - b0 00 07 05  ........                    20.2.16
            81 03 04 00 - 0a 07 05 01  ........                    20.2.24
            03 04 00 0a - 07 05 82 02  ........                    20.2.32
            40 00 0a 07 - 05 02 02 40  @......@                    20.2.40
            00 0a                      ..                          20.2.48
18  CTL    00 00 00 00 - 00 09 01 00  GET STATUS      12us        22.1.0
            00 00 00 00                                            22.1.8
10  CTL    00 00 00 00 - 00 09 01 00  GET STATUS       4us        23.1.0
            00 00 00 00                                            23.1.8
lovec51|  楼主 | 2007-9-25 13:05 | 显示全部楼层
下面贴出的是多次枚举不成功的数据
以上是一次枚举成功的数据,下面贴出的是多次枚举不成功的数据(windows设备管理器刷新一次我认为是枚举一次)
开机-关-开不成功.txt
  Dev   - Device ID
  (10) USB Root Hub [144KB/Sec]
  (12) USB Root Hub
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS          0us         1.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           27us         1.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         15us         2.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           28us         2.2.0
10  CTL    00 00 00 00 - 23 01 10 00 - 01 00 00 00                GET STATUS         21us         3.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         87us         4.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           25us         4.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        124ms         5.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           36us         5.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         20us         6.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms         7.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           26us         7.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          3us         8.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms         9.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           39us         9.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         38ms        10.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           27us        10.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         16us        11.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         24ms        12.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           20us        12.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          3us        13.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        1.1sc        14.1.0
10  DI     00 00 00 00 - 00 01 03 00                              ........           29us        14.2.0
10  CTL    00 00 00 00 - 23 01 11 00 - 01 00 00 00                GET STATUS          3us        15.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         44us        16.1.0
10  DI     00 00 00 00 - 00 01 01 00                              ........           18us        16.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         15us        17.1.0
10  DI     00 00 00 00 - 00 01 01 00                              ........           21us        17.2.0
10  CTL    00 00 00 00 - 23 01 10 00 - 01 00 00 00                GET STATUS         16us        18.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        421ms        19.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           41us        19.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        546ms        20.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           37us        20.2.0
10  CTL    00 00 00 00 - 23 01 01 00 - 01 00 00 00                GET STATUS        546ms        21.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 02 00 04 00                GET STATUS         59us        22.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           23us        22.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        1.0ms        23.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           37us        23.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 02 00 04 00                GET STATUS         23us        24.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           23us        24.2.0
10  USTS   00 00 00 00 - 00 00 01 c0                              ok                545ms        25.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        234ms        26.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           34us        26.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         23us        27.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           19us        27.2.0
10  CTL    00 00 00 00 - 23 01 10 00 - 01 00 00 00                GET STATUS         16us        28.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         71us        29.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           24us        29.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        124ms        30.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           41us        30.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         17us        31.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms        32.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           30us        32.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          4us        33.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms        34.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           35us        34.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         38ms        35.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           24us        35.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         16us        36.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         24ms        37.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           22us        37.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          3us        38.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        546ms        39.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           37us        39.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         20us        40.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms        41.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           27us        41.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          4us        42.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        1.5sc        43.1.0
10  DI     00 00 00 00 - 00 01 03 00                              ........           26us        43.2.0
10  CTL    00 00 00 00 - 23 01 11 00 - 01 00 00 00                GET STATUS          4us        44.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         42us        45.1.0
10  DI     00 00 00 00 - 00 01 01 00                              ........           18us        45.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         15us        46.1.0
10  DI     00 00 00 00 - 00 01 01 00                              ........           21us        46.2.0
10  CTL    00 00 00 00 - 23 01 10 00 - 01 00 00 00                GET STATUS         15us        47.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         62ms        48.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           34us        48.2.0
10  CTL    00 00 00 00 - 23 01 01 00 - 01 00 00 00                GET STATUS        546ms        49.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 02 00 04 00                GET STATUS         54us        50.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           20us        50.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        1.0ms        51.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           33us        51.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 02 00 04 00                GET STATUS         26us        52.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           24us        52.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        420ms        53.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           26us        53.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         17us        54.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           28us        54.2.0
10  CTL    00 00 00 00 - 23 01 10 00 - 01 00 00 00                GET STATUS         20us        55.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         60us        56.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           22us        56.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        124ms        57.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           33us        57.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         16us        58.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms        59.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           33us        59.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          3us        60.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms        61.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           38us        61.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         38ms        62.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           24us        62.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         15us        63.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         24ms        64.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           27us        64.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          3us        65.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        546ms        66.1.0
10  DI     00 00 00 00 - 03 01 00 00                              ........           35us        66.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         16us        67.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         31ms        68.1.0
10  DI     00 00 00 00 - 03 01 10 00                              ........           24us        68.2.0
10  CTL    00 00 00 00 - 23 01 14 00 - 01 00 00 00                GET STATUS          3us        69.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        1.2sc        70.1.0
10  DI     00 00 00 00 - 00 01 03 00                              ........           30us        70.2.0
10  CTL    00 00 00 00 - 23 01 11 00 - 01 00 00 00                GET STATUS          3us        71.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         56us        72.1.0
10  DI     00 00 00 00 - 00 01 01 00                              ........           24us        72.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         11us        73.1.0
10  DI     00 00 00 00 - 00 01 01 00                              ........           26us        73.2.0
10  CTL    00 00 00 00 - 23 01 10 00 - 01 00 00 00                GET STATUS         19us        74.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        343ms        75.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           40us        75.2.0
10  CTL    00 00 00 00 - 23 01 01 00 - 01 00 00 00                GET STATUS        546ms        76.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 02 00 04 00                GET STATUS         64us        77.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           24us        77.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        1.2ms        78.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           36us        78.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 02 00 04 00                GET STATUS         20us        79.1.0
10  DI     00 00 00 00 - 00 01 00 00                              ........           23us        79.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        889ms        80.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           22us        80.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         13us        81.1.0
10  DI     00 00 00 00 - 01 01 01 00                              ........           23us        81.2.0
10  CTL    00 00 00 00 - 23 01 10 00 - 01 00 00 00                GET STATUS         15us        82.1.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS         52us        83.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           22us        83.2.0
10  CTL    00 00 00 00 - a3 00 00 00 - 01 00 04 00                GET STATUS        124ms        84.1.0
10  DI     00 00 00 00 - 01 01 00 00                              ........           39us        84.2.0
10  CTL    00 00 00 00 - 23 03 04 00 - 01 00 00 00                GET STATUS         15us       &nbs
lovec51|  楼主 | 2007-9-26 11:14 | 显示全部楼层
我以前做过一个带串口的板子,目的就是想观察枚举过程。
结果好像是:USB速度太快,导致串口发送堵塞。
话说回来,如果都要用串口调试USB,那不是所有有USB的板子都最好留出一个串口?
我的意思是还有没有其他办法?
lovec51|  楼主 | 2007-9-26 17:51 | 显示全部楼层
查资料仔细看了一下上述数据如下:
我凭感觉对数据做了一个大概的注释:也许不准确,但是应该就这个意思
下面首先是正确枚举成功的数据:
            01 00 04 00                                             1.1.8
        其他类型请求=设备到主机    读设备状态
            01 00 04 00                                             2.1.8
                    读设备状态
            01 00 00 00                                             3.1.8
        其它类型请求=主机到设备  清除设备状态  可能是复位
            01 00 04 00                                             4.1.8
         读设备状态
            01 00 04 00                                             5.1.8
                读设备状态
            01 00 00 00                                             6.1.8
        其它类型请求=主机到设备 设定设备状态
            01 00 04 00                                             7.1.8
            读设备状态
            01 00 00 00                                             8.1.8
            01 00 04 00                                             9.1.8
            读设备状态
            01 00 04 00                                            10.1.8
            读设备状态
            01 00 00 00                                            11.1.8
         其它类型请求=主机到设备 设定设备状态
            01 00 04 00                                            12.1.8
            读设备状态
            01 00 00 00                                            13.1.8
            00 00 ff 00                                            14.1.8
        设备标准请求=设备到主机 获取描述符 长度FF
            00 0a                      ..                          14.2.48
lovec51|  楼主 | 2007-9-26 17:53 | 显示全部楼层
不能正确枚举的数据:
                读设备状态
            读设备状态
            读设备状态
            读设备状态
            其它类型请求=主机到设备 设定状态
             读设备状态
            其它类型请求=主机到设备 清除设备状态
            读设备状态
            读设备状态
            其它类型请求=主机到设备 设定设备状态
              读设备状态
            读设备状态
lovec51|  楼主 | 2007-9-26 18:08 | 显示全部楼层
为了突出重点,我只截取一段来注释,完整的数据在1楼和2楼
能够成功枚举的过程大概如下:
读设备状态-读设备状态-清除状态-读设备状态-读设备状态-设定状态-读设备状态-清除状态-读设备状态-读设备状态-设定状态-读设备状态-清楚状态-获取描述符
而不能枚举成功的过程如下:
读设备状态-读设备状态-清除状态-读设备状态-读设备状态-设定状态-读设备状态-清除状态-读设备状态-读设备状态-设定状态-读设备状态-清楚状态-读设备状态
这就可以看到,前面13步都是一样的,并且返回数据也一样,只有最后一步,能枚举的是获取描述符,不能枚举的则是读设备状态.
这是从PC发出来的命令,PC肯定不会错,是不是由于在XP下看不到设定地址前面的数据,所以前面的in包错了我也看不到,导致最后PC发的包不正确??
lovec51|  楼主 | 2007-9-26 18:56 | 显示全部楼层
换一个bus hound 5抓数据,结果一样:
Bus Hound 5.00 capture. Complements of www.perisoft.net
设备上电_枚举不成功
  Device - Device ID (followed by the endpoint for USB devices)
            (10) USB Root Hub
            (22) yy's D12-JB Board
  Data   - Hex dump of the data transferred
  Cmd... - Position in the captured data
  Delta  - Elapsed time from the previous phase to the current phase
  Date   - Date the phase occurred in year/month/day form
  Descr  - Description of the phase
Device  Data         Cmd.Phase.Ofs(rep)  Delta  Date        Description
  10.0  a3 00 00 00         1.1.0(2)     5.3sc  2007-09-26  GET STATUS
        01 00 04 00         1.1.4
  10.0  01 01 01 00         1.2.0         32us  2007-09-26  ....
  10.0  23 01 10 00         3.1.0         77us  2007-09-26  CLEAR FEATURE
        01 00 00 00         3.1.4
  10.0  a3 00 00 00         4.1.0(2)      88us  2007-09-26  GET STATUS
        01 00 04 00         4.1.4
  10.0  01 01 00 00         4.2.0         25us  2007-09-26  ....
  10.0  23 03 04 00         6.1.0        124ms  2007-09-26  SET FEATURE
        01 00 00 00         6.1.4
  10.0  a3 00 00 00         7.1.0         31ms  2007-09-26  GET STATUS
        01 00 04 00         7.1.4
  10.0  03 01 10 00         7.2.0         35us  2007-09-26  ....
  10.0  23 01 14 00         8.1.0          7us  2007-09-26  CLEAR FEATURE
        01 00 00 00         8.1.4
  10.0  a3 00 00 00         9.1.0(2)      30ms  2007-09-26  GET STATUS
        01 00 04 00         9.1.4
  10.0  03 01 00 00         9.2.0         36us  2007-09-26  ....
  10.0  23 03 04 00        11.1.0         37ms  2007-09-26  SET FEATURE
        01 00 00 00        11.1.4
  10.0  a3 00 00 00        12.1.0         25ms  2007-09-26  GET STATUS
        01 00 04 00        12.1.4
  10.0  03 01 10 00        12.2.0         29us  2007-09-26  ....
  10.0  23 01 14 00        13.1.0          6us  2007-09-26  CLEAR FEATURE
        01 00 00 00        13.1.4
  10.0  a3 00 00 00        14.1.0        1.4sc  2007-09-26  GET STATUS
        01 00 04 00        14.1.4
  10.0  00 01 03 00        14.2.0         39us  2007-09-26  ....
  10.0  23 01 11 00        15.1.0          7us  2007-09-26  CLEAR FEATURE
        01 00 00 00        15.1.4
  10.0  a3 00 00 00        16.1.0(2)      61us  2007-09-26  GET STATUS
        01 00 04 00        16.1.4
  10.0  00 01 01 00        16.2.0         27us  2007-09-26  ....
  10.0  23 01 10 00        18.1.0         69us  2007-09-26  CLEAR FEATURE
        01 00 00 00        18.1.4
  10.0  a3 00 00 00        19.1.0(2)     171ms  2007-09-26  GET STATUS
        01 00 04 00        19.1.4
  10.0  00 01 00 00        19.2.0         50us  2007-09-26  ....
  10.0  23 01 01 00        21.1.0        1.0sc  2007-09-26  CLEAR FEATURE
        01 00 00 00        21.1.4
  10.0  a3 00 00 00        22.1.0         58us  2007-09-26  GET STATUS
        02 00 04 00        22.1.4
  10.0  00 01 00 00        22.2.0         31us  2007-09-26  ....
  10.0  a3 00 00 00        23.1.0        1.0ms  2007-09-26  GET STATUS
        01 00 04 00        23.1.4
  10.0  00 01 00 00        23.2.0         43us  2007-09-26  ....
  10.0  a3 00 00 00        24.1.0         24us  2007-09-26  GET STATUS
        02 00 04 00        24.1.4
  10.0  00 01 00 00        24.2.0         29us  2007-09-26  ....
  10.0  a3 00 00 00        25.1.0(2)     280ms  2007-09-26  GET STATUS
        01 00 04 00        25.1.4
  10.0  01 01 01 00        25.2.0         42us  2007-09-26  ....
  10.0  23 01 10 00        27.1.0        308us  2007-09-26  CLEAR FEATURE
        01 00 00 00        27.1.4
  10.0  a3 00 00 00        28.1.0(2)      32ms  2007-09-26  GET STATUS
        01 00 04 00        28.1.4
  10.0  01 01 00 00        28.2.0         32us  2007-09-26  ....
  10.0  23 03 04 00        30.1.0        123ms  2007-09-26  SET FEATURE
        01 00 00 00        30.1.4
  10.0  a3 00 00 00        31.1.0         31ms  2007-09-26  GET STATUS
        01 00 04 00        31.1.4
  10.0  03 01 10 00        31.2.0         27us  2007-09-26  ....
  10.0  23 01 14 00        32.1.0          5us  2007-09-26  CLEAR FEATURE
        01 00 00 00        32.1.4
  10.0  a3 00 00 00        33.1.0(2)      31ms  2007-09-26  GET STATUS
        01 00 04 00        33.1.4
  10.0  03 01 00 00        33.2.0         45us  2007-09-26  ....
  10.0  23 03 04 00        35.1.0         37ms  2007-09-26  SET FEATURE
        01 00 00 00        35.1.4
  10.0  a3 00 00 00        36.1.0         24ms  2007-09-26  GET STATUS
        01 00 04 00        36.1.4
  10.0  03 01 10 00        36.2.0         42us  2007-09-26  ....
  10.0  23 01 14 00        37.1.0          7us  2007-09-26  CLEAR FEATURE
        01 00 00 00        37.1.4
lovec51|  楼主 | 2007-9-26 18:57 | 显示全部楼层
成功的
设备上电_枚举成功
            (10) USB Root Hub
  10.0  a3 00 00 00         1.1.0(2)     4.2sc  2007-09-26  GET STATUS
        01 00 04 00         1.1.4
  10.0  01 01 01 00         1.2.0         33us  2007-09-26  ....
  10.0  23 01 10 00         3.1.0         78us  2007-09-26  CLEAR FEATURE
        01 00 00 00         3.1.4
  10.0  a3 00 00 00         4.1.0(2)      89us  2007-09-26  GET STATUS
        01 00 04 00         4.1.4
  10.0  01 01 00 00         4.2.0         45us  2007-09-26  ....
        01 00 00 00         6.1.4
        01 00 04 00         7.1.4
  10.0  23 01 14 00         8.1.0          8us  2007-09-26  CLEAR FEATURE
        01 00 00 00         8.1.4
  10.0  a3 00 00 00         9.1.0(2)      31ms  2007-09-26  GET STATUS
        01 00 04 00         9.1.4
  10.0  03 01 00 00         9.2.0         38us  2007-09-26  ....
  10.0  23 03 04 00        11.1.0         36ms  2007-09-26  SET FEATURE
        01 00 00 00        11.1.4
  10.0  a3 00 00 00        12.1.0         26ms  2007-09-26  GET STATUS
        01 00 04 00        12.1.4
  10.0  03 01 10 00        12.2.0         34us  2007-09-26  ....
        01 00 00 00        13.1.4
  10.0  80 06 00 02        14.1.0        102ms  2007-09-26  GET DESCRIPTOR
        00 00 ff 00        14.1.4
  10.0  09 02 2e 00        14.2.0        6.9ms  2007-09-26  ....
        01 01 00 60        14.2.4                           ...`
        01 09 04 00        14.2.8                           ....
        00 04 dc a0        14.2.12                          ....
        b0 00 07 05        14.2.16                          ....
        81 03 04 00        14.2.20                          ....
        0a 07 05 01        14.2.24                          ....
        03 04 00 0a        14.2.28                          ....
        07 05 82 02        14.2.32                          ....
        40 00 0a 07        14.2.36                          @...
        05 02 02 40        14.2.40                          ...@
        00 0a              14.2.44                          ..
  10.0  a3 00 00 00        15.1.0         30us  2007-09-26  GET STATUS
        02 00 04 00        15.1.4
  10.0  00 01 00 00        15.2.0         32us  2007-09-26  ....
  22.0  80 06 00 01        16.1.0        5.9ms  2007-09-26  GET DESCRIPTOR
        00 00 12 00        16.1.4
  22.0  12 01 00 01        16.2.0        4.9ms  2007-09-26  ....
        dc 00 00 10        16.2.4                           ....
        71 04 66 06        16.2.8                           q.f.
        00 01 00 00        16.2.12                          ....
        00 19              16.2.16                          ..
  22.0  80 06 00 02        17.1.0         28us  2007-09-26  GET DESCRIPTOR
        00 00 09 00        17.1.4
  22.0  09 02 2e 00        17.2.0        3.9ms  2007-09-26  ....
        01 01 00 60        17.2.4                           ...`
        01                 17.2.8                           .
  22.0  80 06 00 02        18.1.0         26us  2007-09-26  GET DESCRIPTOR
        00 00 2e 00        18.1.4
  22.0  09 02 2e 00        18.2.0        5.9ms  2007-09-26  ....
        01 01 00 60        18.2.4                           ...`
        01 09 04 00        18.2.8                           ....
        00 04 dc a0        18.2.12                          ....
        b0 00 07 05        18.2.16                          ....
        81 03 04 00        18.2.20                          ....
        0a 07 05 01        18.2.24                          ....
        03 04 00 0a        18.2.28                          ....
        07 05 82 02        18.2.32                          ....
        40 00 0a 07        18.2.36                          @...
        05 02 02 40        18.2.40                          ...@
        00 0a              18.2.44                          ..
  22.0  00 09 01 00        19.1.0         30us  2007-09-26  SET CONFIG
        00 00 00 00        19.1.4
lovec51|  楼主 | 2007-9-27 14:56 | 显示全部楼层
用bushound抓D12确实只有很少数据:
只有D12
  22.0  80 06 00 01         1.1.0        3.3sc  2007-09-27  GET DESCRIPTOR
        00 00 12 00         1.1.4
  22.0  12 01 00 01         1.2.0        4.6ms  2007-09-27  ....
        dc 00 00 10         1.2.4                           ....
        71 04 66 06         1.2.8                           q.f.
        00 01 00 00         1.2.12                          ....
        00 19               1.2.16                          ..
  22.0  80 06 00 02         2.1.0         29us  2007-09-27  GET DESCRIPTOR
        00 00 09 00         2.1.4
  22.0  09 02 2e 00         2.2.0        3.9ms  2007-09-27  ....
        01 01 00 60         2.2.4                           ...`
        01                  2.2.8                           .
  22.0  80 06 00 02         3.1.0         26us  2007-09-27  GET DESCRIPTOR
        00 00 2e 00         3.1.4
  22.0  09 02 2e 00         3.2.0        5.9ms  2007-09-27  ....
        01 01 00 60         3.2.4                           ...`
        01 09 04 00         3.2.8                           ....
        00 04 dc a0         3.2.12                          ....
        b0 00 07 05         3.2.16                          ....
        81 03 04 00         3.2.20                          ....
        0a 07 05 01         3.2.24                          ....
        03 04 00 0a         3.2.28                          ....
        07 05 82 02         3.2.32                          ....
        40 00 0a 07         3.2.36                          @...
        05 02 02 40         3.2.40                          ...@
        00 0a               3.2.44                          ..
  22.0  00 09 01 00         4.1.0         28us  2007-09-27  SET CONFIG
        00 00 00 00         4.1.4
lovec51|  楼主 | 2007-9-27 14:57 | 显示全部楼层
而那个不能枚举的板子什么都抓不到!
lovec51|  楼主 | 2007-9-27 20:34 | 显示全部楼层
成功枚举出海量存储器
周的代码太繁杂,我看你的那个用52模拟海量存储器的代码稍微简洁一些,所以想在你的基础上调,在以前的好板子(能枚举的板子)上成功了,我想用他枚举成常见的D12设备(跟周的开发板那样),我修改了你的"设备描述符""配置描述符""接口描述符""端点描述",修改成跟周的定义一样,结果还是不能枚举成功,
请问还要修改那些地方??????
lovec51|  楼主 | 2007-9-27 20:50 | 显示全部楼层
我在两个板子上跑圈圈的海量存储器那个程序都成功了!
贴图庆祝一下先!
lovec51|  楼主 | 2007-9-27 21:51 | 显示全部楼层
你指那里错了?我修改你的程序错了还是我修改自己的程序错
你的那个程序要枚举成D12开发板要改那些地方?
lovec51|  楼主 | 2007-9-28 16:24 | 显示全部楼层
描述符该成跟周立功的一样,可是枚举第一步就过不去
也就是DEVICE_DESCRIPTOR就有问题,始终到不了CONFIGURATION_DESCRIPTOR这一步!
