STR710FZ2T6串口速率始终只有设定值的四分之一
6156|24
 楼主| pcseye 发表于 2007-10-11 21:56 | 显示全部楼层 |阅读模式
您好!
我用的是一块,别人送我的STR7的核心板.外部晶振4MHz.
使用的环境是KEIL 的MDK3.51版本。
现在运行KEIL自带的 KEIL/ARM/BOARDS/HITEX/ST_HELLO 程序,发现实际的波特率只有设定的1/4...
到底是哪里错了呢,请老大们赐教。
以下是main程序。
#include "71x_lib.h"
#define UART0_Rx_Pin (0x0001<<8)   /*  TQFP 64: pin N?63 , TQFP 144 pin N?143 */
#define UART0_Tx_Pin (0x0001<<9)   /*  TQFP 64: pin N?64 , TQFP 144 pin N?144 */
#define UART1_Rx_Pin (0x0001<<10)  /*  TQFP 64: pin N?1  , TQFP 144 pin N?1   */
#define UART1_Tx_Pin (0x0001<<11)  /*  TQFP 64: pin N?2  , TQFP 144 pin N?3   */
#define UART2_Rx_Pin (0x0001<<13)  /*  TQFP 64: pin N?5  , TQFP 144 pin N?9   */
#define UART2_Tx_Pin (0x0001<<14)  /*  TQFP 64: pin N?6  , TQFP 144 pin N?10  */
#define UART3_Rx_Pin (0x0001<<1)   /*  TQFP 64: pin N?52 , TQFP 144 pin N?123 */
#define UART3_Tx_Pin (0x0001<<0)   /*  TQFP 64: pin N?53 , TQFP 144 pin N?124 */
#define Use_UART3
//#define Use_UART1
//#define Use_UART2
//#define Use_UART3
   #ifdef Use_UART0
     #define  UARTX  UART0
     #define  UARTX_Rx_Pin  UART0_Rx_Pin
     #define  UARTX_Tx_Pin  UART0_Tx_Pin
     #define  UARTX_Periph  UART0_Periph
   #endif /* Use_UART0 */
   #ifdef Use_UART1
     #define  UARTX  UART1
     #define  UARTX_Rx_Pin  UART1_Rx_Pin
     #define  UARTX_Tx_Pin  UART1_Tx_Pin
     #define  UARTX_Periph  UART1_Periph
   #endif /* Use_UART1 */
   #ifdef Use_UART2
     #define  UARTX  UART2
     #define  UARTX_Rx_Pin  UART2_Rx_Pin
     #define  UARTX_Tx_Pin  UART2_Tx_Pin
     #define  UARTX_Periph  UART2_Periph
   #endif /* Use_UART2 */
   #ifdef Use_UART3
     #define  UARTX  UART3
     #define  UARTX_Rx_Pin  UART3_Rx_Pin
     #define  UARTX_Tx_Pin  UART3_Tx_Pin
     #define  UARTX_Periph  UART3_Periph
   #endif /* Use_UART3 */
u16 i;
u16 UARTStatus;
u8 bBuffer[4] = {'t','e','s','t'};
/* Example 1 */
int main(void)
  #ifdef DEBUG
    debug();
  #endif
/* UART configuration ---------------------------------------------------------- */
    /*  Configure the GPIO pins as alternate function push pull */
   GPIO_Config(GPIO0,UARTX_Tx_Pin, GPIO_AF_PP);
    /*  Configure the GPIO pins as Input Tristate CMOS */
   GPIO_Config(GPIO0,UARTX_Rx_Pin, GPIO_IN_TRI_CMOS);
/*  Configure the UART X --------------------------------------------------------*/
    /*  Turn UARTX on */
   UART_OnOffConfig(UARTX, ENABLE);
    /*  Disable FIFOs */
   UART_FifoConfig (UARTX, DISABLE);
    /*  Reset the UART_RxFIFO */
   UART_FifoReset(UARTX, UART_RxFIFO);
    /*  Reset the UART_TxFIFO */
   UART_FifoReset(UARTX, UART_TxFIFO);
    /*  Disable Loop Back */
   UART_LoopBackConfig(UARTX, DISABLE);
    /* Configure the UARTX as following:
      - Baudrate = 9600 Bps
      - No parity
      - 8 data bits
      - 1 stop bit */
   UART_Config(UARTX, 9600, UART_NO_PARITY, UART_1_StopBits, UARTM_8D);
    /*  Enable Rx */
   UART_RxConfig(UARTX, ENABLE);
  while(1)
   for(i=0; i<4; i++)
     UART_ByteSend(UARTX,(u8 *)&bBuffer);
ST_ARM 发表于 2007-10-12 09:37 | 显示全部楼层
看看你的71x_conf.h文件
#ifndef __71x_CONF_H
#define __71x_CONF_H
/* Comment the line below to put the library in release mode */
#define RCCU_Main_Osc 0x16000000
这里的0x16000000改为0x4000000了没有?
/* Comment the lines below corresponding to unwanted peripherals */
//#define _ADC12
//#define _APB
//#define _APB1
//#define _APB2
//#define _BSPI
//#define _BSPI0
//#define _BSPI1
//#define _CAN
//#define _EIC
//#define _EMI
//#define _FLASH
#define _GPIO
#define _GPIO0
#define _GPIO1
#define _GPIO2
#define _I2C
#define _I2C0
#define _I2C1
#define _PCU
#define _RCCU
//#define _RTC
//#define _TIM
//#define _TIM0
//#define _TIM1
//#define _TIM2
//#define _TIM3
//#define _UART
//#define _UART0
//#define _UART1
//#define _UART2
//#define _UART3
//#define _USB
//#define _WDG
//#define _XTI
//#define _IRQVectors
#endif /* __71x_CONF_H */
 楼主| pcseye 发表于 2007-10-12 11:41 | 显示全部楼层
确实没有设置为4000000
但,无论是改为0x4000000还是4000000,,,串口速率仍旧是1/4....困惑ING...谢谢各位老大
浪淘沙 发表于 2007-10-12 12:10 | 显示全部楼层
建议:删除所有生成的中间文件,重新编译链接项目文件
 楼主| pcseye 发表于 2007-10-12 14:05 | 显示全部楼层
还是不行呢.
我重新从C盘的KEIL安装目录里,拷贝出了整个工程(之前我没有直接在这里修改源程序)
并且照前边两位说的,删除了所有中间文件。..但问题还是没解决啊.
还有,我在仿真里边,让程序 "RUN"起来之后,截到如下的图...
 楼主| pcseye 发表于 2007-10-12 15:27 | 显示全部楼层
这块板子之前有BOOT,通信都正常啊
这块板子,送给我的时候,是有BOOT的。通信都正常。
而且我用ADS编译的文件也正常跑起来了。
现在买了个ULINK,,,就把BOOT擦掉了。没想到串口不正常。...是什么原因呢
ST_ARM 发表于 2007-10-12 16:31 | 显示全部楼层
检测option
见图
 楼主| pcseye 发表于 2007-10-12 18:14 | 显示全部楼层
"4.0"MHz这个也是很早就设置好了
"4.0"MHz这个也是很早就设置好了...
也是不行的。
还有,稍微有点不放心的是,,,Device项里,,,没有选具体器件...
例程抓过来就用了。
老大们...谢谢..
到底是啥问题啊55555555555
 楼主| pcseye 发表于 2007-10-13 10:45 | 显示全部楼层
还是不行,第几个不眠夜拉
老大们,帮帮忙吧。。。
ST_ARM 发表于 2007-10-15 09:31 | 显示全部楼层
我不大会用KEIL 的MDK
因为没有license,我一直没法使用KEIL 的MDK,而且16k的版本不够用,所以一直没有去使用它。
你的问题仅凭你提供的信息可能没法解决,你能否将你的项目整个打包放上来?
qishi00 发表于 2007-10-15 21:11 | 显示全部楼层
应该是要在初始化的时候设置一下时钟
在初始化部分应该设置主频率的分频和倍频,
现在一般都是直接用库编程,而库缺省是用16M的频率,虽然改了源程序的主时钟频率,但是没有重新编译库的话,还是用16M的频率
 楼主| pcseye 发表于 2007-10-16 08:15 | 显示全部楼层
恩,谢谢
这两天在打杂,以上方法等我周末再试验。有结果给大家汇报。谢谢
 楼主| pcseye 发表于 2007-10-17 23:33 | 显示全部楼层
这会总算可以干点正事
11点刚把手上的杂活干完,可以整整正事了。..
发现,自己怎么折腾都不行.
还是把工程打包发上来吧~~~
各位老大,帮忙吧~
yjf1979yjf 发表于 2007-10-18 16:35 | 显示全部楼层
士大夫
士大夫
yjf1979yjf 发表于 2007-10-18 16:52 | 显示全部楼层
按时地方
广泛
 楼主| pcseye 发表于 2007-10-19 18:11 | 显示全部楼层
你以为驱动个串口那么重要么
我是在学ARM没错。
这个串口驱动不驱动起来,只是个过程。我并不重视结果的。
我的目标很明确,在这个探寻的过程中,可以逐步学会这个东西。串口不正常说明设置有问题。在这个基础上作再多也没意义。
而且这个是预研,不会有那么多精力投入的。
 楼主| pcseye 发表于 2007-10-19 18:13 | 显示全部楼层
而且我相信,有这个问题的不止我一个
而且我相信,有这个问题的不止我一个.
这些资料留在这里,还会对其他人有用的。还有,你的思维方式...
 楼主| pcseye 发表于 2007-10-22 23:51 | 显示全部楼层
依然无音信
依然无音信哦~~~~~~~~
ST_ARM 发表于 2007-10-23 09:54 | 显示全部楼层
你最好不要用Keil自带的库
最好使用产生那个库的源文件去开发。
问题还是这个造成的:
Keil编译好的库中使用了RCCU_Main_Osc,而这个值就是0x16000000,在外面改不了。除非你用的晶振是16M。
香水城 发表于 2007-10-23 21:04 | 显示全部楼层
19楼说的有道理,LZ的问题解决了吗?
