[嵌入式linux] 嵌入式LINUX讲座2:如何建立NFS
2960|0
 楼主| wenming 发表于 2009-7-26 09:55 | 显示全部楼层 |阅读模式
一些基本的操作直接GOOGLE,我这里只写核心的部分。开发环境为RHEL 5.2。开发板为AT91SAM9G20。
1.在下面的步骤中,Linux系统的地址是192.168.1.101;开发板的地址为:192.168.1.100
网关的地址为:192.168.1.1
2. 用vim /etc/exports打开exports文件,在文件中添加如下内容:
/opt/eldk/arm/ 192.168.1.110(rw,no_root_squash)
保存然后退出
3.开发板设置bootargs如下:
setenv bootargs root=/dev/nfs rw nfsroot=192.168.1.111:/opt/eldk/arm
ip=192.168.1.110:192.168.1.111:192.168.1.1:255.255.255.0:at91:eth0:off
console=ttyS0,115200
下面是启动画面:
U-Boot 1.3.4 (Jul 25 2009 - 21:23:33)
DRAM: 64 MB
NAND: 256 MiB
DataFlash:AT45DB321
Nb pages: 8192
Page Size: 528
Size= 4325376 bytes
Logical address: 0xD0000000
Area 0: D0000000 to D00041FF (RO) Bootstrap
Area 1: D0004200 to D00083FF Environment
Area 2: D0008400 to D0041FFF (RO) U-Boot
Area 3: D0042000 to D0251FFF Kernel
Area 4: D0252000 to D041FFFF FS
In: serial
Out: serial
Err: serial
Net: macb0
macb0: Starting autonegotiation...
macb0: Autonegotiation complete
macb0: link up, 100Mbps full-duplex (lpa: 0x45e1)
Hit any key to stop autoboot: 0
## Booting kernel from Legacy Image at 22000000 ...
Image Name: Linux-2.6.27
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1535016 Bytes = 1.5 MB
Load Address: 20008000
Entry Point: 20008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux.................................................................................................... done, booting the kernel.
Linux version 2.6.27 (wenming@localhost.localdomain) (gcc version 4.2.2) #3 Sat Jul 25 17:09:14 CST 2009
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: Atmel AT91SAM9G20-EK
Memory policy: ECC disabled, Data cache writeback
Clocks: CPU 396 MHz, master 132 MHz, main 18.432 MHz
CPU0: D VIVT write-back cache
CPU0: I cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/nfs rw nfsroot=192.168.1.111:/opt/eldk/arm/images/rootfs/yang ip=192.168.1.110:192.168.1.111:192.168.1.1:255.255.255.0:at91:eth0:off console=ttyS0,115200
AT91: 96 gpio irqs in 3 banks
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttyS0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61664KB available (2828K code, 233K data, 128K init)
Calibrating delay loop... 197.83 BogoMIPS (lpj=989184)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 288 bytes
NET: Registered protocol family 16
AT91: Power Management
AT91: Starting after software reset
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS2 version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 120
io scheduler noop registered
io scheduler anticipatory registered (default)
atmel_usart.0: ttyS0 at MMIO 0xfefff200 (irq = 1) is a ATMEL_SERIAL
atmel_usart.1: ttyS1 at MMIO 0xfffb0000 (irq = 6) is a ATMEL_SERIAL
atmel_usart.2: ttyS2 at MMIO 0xfffb4000 (irq = 7) is a ATMEL_SERIAL
brd: module loaded
loop: module loaded
ssc ssc.0: Atmel SSC device at 0xc4870000 (irq 14)
MACB_mii_bus: probed
eth0: Atmel MACB at 0xfffc4000 irq 21 (00:11:22:33:44:55)
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=ffffffff:00, irq=-1)
Driver 'sd' needs updating - please use bus_type methods
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
AT91 NAND: 8-bit, Software ECC
Scanning device for bad blocks
Creating 3 MTD partitions on "atmel_nand":
0x00000000-0x00400000 : "Bootstrap"
0x00400000-0x04000000 : "Partition 1"
0x04000000-0x10000000 : "Partition 2"
usbmon: debugfs is not available
at91_ohci at91_ohci: AT91 OHCI
at91_ohci at91_ohci: new USB bus registered, assigned bus number 1
at91_ohci at91_ohci: irq 20, io mem 0x00500000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
udc: at91_udc version 3 May 2006
mice: PS/2 mouse device common for all mice
input: gpio-keys as /class/input/input0
rtc-at91sam9 at91_rtt.0: rtc core: registered at91_rtt as rtc0
rtc-at91sam9 at91_rtt.0: rtc0: SET TIME!
i2c /dev entries driver
i2c-gpio i2c-gpio: using pins 55 (SDA) and 56 (SCL)
Registered led device: ds5
Registered led device: ds1
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.17.
ASoC version 0.13.2
WM8731 Audio Codec 0.13<6>ALSA device list:
No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
rtc-at91sam9 at91_rtt.0: hctosys: unable to read the hardware clock
IP-Config: Complete:
device=eth0, addr=192.168.1.110, mask=255.255.255.0, gw=192.168.1.1,
host=at91, domain=, nis-domain=(none),
bootserver=192.168.1.111, rootserver=192.168.1.111, rootpath=
Looking up port of RPC 100003/2 on 192.168.1.111
eth0: link up (100/Full)
Looking up port of RPC 100005/1 on 192.168.1.111
VFS: Mounted root (nfs filesystem).
Freeing init memory: 128K
init started: BusyBox v1.7.1 (2008-11-24 17:40:49 MET)
starting pid 366, tty '': '/etc/rc.sh'
starting pid 371, tty '': '/bin/application'
starting pid 372, tty '': '/bin/sh'
### Application running ...
