C6678 多核通信问题
2382|18
 楼主| 红星闪闪放光彩 发表于 2016-1-19 17:59 | 显示全部楼层 |阅读模式
我用的是K2H系列的EVM,初学者,刚刚开始在板子上测试多核DSP通信的例程。
出现的问题好像是只有核0到1的通信,其他核之间没有通信,测试结果是:
1. debug后:
C66xx_0: GEL Output:
Connecting Target...
C66xx_0: GEL Output: TCI6638K2K GEL file Ver is 1.3
C66xx_0: GEL Output: Detected PLL bypass enabled: SECCTL[BYPASS] = 0x00800000
C66xx_0: GEL Output: (2a) MAINPLLCTL1 = 0x00000040
C66xx_0: GEL Output: (2b) PLLCTL = 0x00000048
C66xx_0: GEL Output: (2c) PLLCTL = 0x00000048
C66xx_0: GEL Output: (2d) Delay...
C66xx_0: GEL Output: (2e) SECCTL = 0x00810000
C66xx_0: GEL Output: (2f) PLLCTL = 0x0000004A
C66xx_0: GEL Output: (2g) Delay...
C66xx_0: GEL Output: (2h) PLLCTL = 0x00000048
C66xx_0: GEL Output: (4)PLLM[PLLM] = 0x0000000F
C66xx_0: GEL Output: MAINPLLCTL0 = 0x05000000
C66xx_0: GEL Output: (5) MAINPLLCTL0 = 0x07000000
C66xx_0: GEL Output: (5) MAINPLLCTL1 = 0x00000040
C66xx_0: GEL Output: (6) MAINPLLCTL0 = 0x07000000
C66xx_0: GEL Output: (7) SECCTL = 0x00890000
C66xx_0: GEL Output: (8a) Delay...
C66xx_0: GEL Output: PLL1_DIV3 = 0x00008002
C66xx_0: GEL Output: PLL1_DIV4 = 0x00008004
C66xx_0: GEL Output: PLL1_DIV7 = 0x00000000
C66xx_0: GEL Output: (8d/e) Delay...
C66xx_0: GEL Output: (10) Delay...
C66xx_0: GEL Output: (12) Delay...
C66xx_0: GEL Output: (13) SECCTL = 0x00090000
C66xx_0: GEL Output: (Delay...
C66xx_0: GEL Output: (14) PLLCTL = 0x00000041
C66xx_0: GEL Output: PLL has been configured (CLKIN * PLLM / PLLD / PLLOD = PLLOUT):
C66xx_0: GEL Output: PLL has been configured (122.88 MHz * 16 / 1 / 2 = 983.04 MHz)
C66xx_0: GEL Output: Power on all PSC modules and DSP domains...
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=2, md=9!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=17, md=25!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=17, md=26!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=18, md=27!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=19, md=28!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=19, md=29!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=20, md=30!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=20, md=31!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=20, md=32!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=20, md=33!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=21, md=34!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=22, md=35!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=22, md=36!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=23, md=37!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=23, md=38!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=24, md=39!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=24, md=40!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=24, md=41!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=24, md=42!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=25, md=43!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=25, md=44!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=25, md=45!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=25, md=46!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=26, md=47!
C66xx_0: GEL Output: Set_PSC_State... Timeout Error #03 pd=27, md=48!
C66xx_0: GEL Output: Power on all PSC modules and DSP domains... Done.
C66xx_0: GEL Output: WARNING: SYSCLK is the input to the PA PLL.
C66xx_0: GEL Output: Completed PA PLL Setup
C66xx_0: GEL Output: PAPLLCTL0 - before: 0x0x098804C0 after: 0x0x07080400
C66xx_0: GEL Output: PAPLLCTL1 - before: 0x0x00000040 after: 0x0x00002040
C66xx_0: GEL Output: DDR begin
C66xx_0: GEL Output: XMC setup complete.
C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ...
C66xx_0: GEL Output: DDR3 PLL Setup complete, DDR3A clock now running at 666 MHz.
C66xx_0: GEL Output: DDR3A initialization complete
C66xx_0: GEL Output: DDR3 PLL Setup ...
C66xx_0: GEL Output: DDR3 PLL Setup complete, DDR3B clock now running at 800MHz.
C66xx_0: GEL Output: DDR3B initialization complete
C66xx_0: GEL Output: DDR done
C66xx_1: GEL Output:
C66xx_1: GEL Output: TCI6638K2K GEL file Ver is 1.3
C66xx_2: GEL Output:
C66xx_2: GEL Output: TCI6638K2K GEL file Ver is 1.3
C66xx_3: GEL Output:
C66xx_3: GEL Output: TCI6638K2K GEL file Ver is 1.3
C66xx_4: GEL Output:
C66xx_4: GEL Output: TCI6638K2K GEL file Ver is 1.3
C66xx_5: GEL Output:
C66xx_5: GEL Output: TCI6638K2K GEL file Ver is 1.3
C66xx_6: GEL Output:
C66xx_6: GEL Output: TCI6638K2K GEL file Ver is 1.3
C66xx_7: GEL Output:
C66xx_7: GEL Output: TCI6638K2K GEL file Ver is 1.3
2. resume后:
[C66xx_0] Set interrupt form Core 0 to Core 1, cycle =16405
Interrupt Info 16
angerbird 发表于 2016-1-19 21:21 | 显示全部楼层
多核意味着多线程处理的。。
 楼主| 红星闪闪放光彩 发表于 2016-1-20 09:42 | 显示全部楼层
多核意味着多线程处理的。。
谢谢回复。
我刚刚接触DSP,不太明白,就是用了一个IPC 的例程实验一下,软仿的时候没有问题,连上板子硬件仿真就得到了上面的结果。
请问您的意思是我是哪里没做对?还是少了什么步骤?
zhangmangui 发表于 2016-1-20 23:13 | 显示全部楼层
干接触就上这么高大上的
zhangmangui 发表于 2016-1-20 23:14 | 显示全部楼层
这个论坛里面研究的网友比较少  只能靠你慢慢琢磨了
 楼主| 红星闪闪放光彩 发表于 2016-1-21 16:06 | 显示全部楼层
好吧,慢慢琢磨。。。谢谢
 楼主| 红星闪闪放光彩 发表于 2016-1-21 16:16 | 显示全部楼层
好吧,慢慢琢磨。。。谢谢
zhangmangui 发表于 2016-1-23 23:18 | 显示全部楼层
好吧,慢慢琢磨。。。谢谢
还望你多分享   指点
小木欧尼 发表于 2016-1-24 18:19 | 显示全部楼层
多核  又是多核
门槛太高
 楼主| 红星闪闪放光彩 发表于 2016-1-25 15:22 | 显示全部楼层
多核  又是多核
门槛太高
又被打击了
edishen 发表于 2016-1-25 21:31 | 显示全部楼层
不是打击  应该是鼓舞吧
你做的是很多人做不了的
 楼主| 红星闪闪放光彩 发表于 2016-1-28 15:17 | 显示全部楼层
不是打击  应该是鼓舞吧
你做的是很多人做不了的
开玩笑的,哈哈,谢谢鼓励!
Ryze 发表于 2016-2-13 21:13 | 显示全部楼层
楼主搞明白了吗
 楼主| 红星闪闪放光彩 发表于 2016-2-22 09:51 | 显示全部楼层
楼主搞明白了吗
还没有……
 楼主| 红星闪闪放光彩 发表于 2016-2-26 11:06 | 显示全部楼层
IPC程序已经测试通过了。
应该是不需要再配置文件里添加GEL文件的。就不会出现上边的结果了。
最终原因是示例程序中的中断事件代码和我的K2H板子的不一样,把代号改了就没有问题了。
zhangjin_comeon 发表于 2016-2-27 17:42 | 显示全部楼层
没玩过多核
小木欧尼 发表于 2016-2-28 23:47 | 显示全部楼层
这种高大上的东西   支持    向往
xiaop5140 发表于 2016-5-5 22:59 | 显示全部楼层
谢谢回复。
我刚刚接触DSP,不太明白,就是用了一个IPC 的例程实验一下,软仿的时候没有问题,连上板子硬 ...
我也遇到了这个问题,解决的方法是应该把多个dsp核联合,group,然后再运行,这样就能看到正确的打印信息
AcedX 发表于 2016-7-9 15:16 | 显示全部楼层
朋友,加群DSP+FPGA处理架构 74522342讨论一下吧!
