[Kinetis]
I2C模拟驱动
847|4
ccw1986|  楼主 | 2016-1-22 21:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "sw_iic.h"
//----I2C Variables -------------------------------------------------------
byte ak1=NACK;
byte ak2=NACK;
byte ak3=NACK;
*        Function:         Delay
*        Parameters: 16-bit delay value
*        Return:                none
*        Simple delay loop.
void SwIIC_Delay(byte count)
        byte i;
        for (i=0; i<count; i++)
    //asm nop;
*        Function:         Wait
*        Parameters: 8-bit delay value
*        Return:                none
*        Simple delay loop. Little longer than delay function.
void SwIIC_Wait(byte loop)
while(--loop);
    //asm nop;
*        Function:         SwIIC_Init
*        Parameters: none
*        Return:                none
*        Function initialize sw IIC interface
void SwIIC_Init(void)
  SCL_D = P_IN;
  SDA_D = P_IN;
  SS_D = P_OUT;
  SCL_PU = PU_ON;
  SDA_PU = PU_ON;
  SS=1;
*        Function:         IIC_DATA_0
*        Parameters: none
*        Return:                none
*        Physical layer of IIC - Write '0' on bus
void IIC_DATA_0(void)
  word i = 0;
  SDA = 0;
  SDA_D = P_OUT;
  SwIIC_Wait(SDA_HOLD);
  SCL_D = P_IN;
  while((!SCL) && (i++ < MAX_IIC_TIMEOUT));
  SwIIC_Wait(SCL_HOLD);
  SCL = 0;
  SCL_D = P_OUT;
*        Function:         IIC_DATA_1
*        Parameters: none
*        Return:                none
*        Physical layer of IIC - Write '1' on bus
void IIC_DATA_1(void)
  word i = 0;
  SDA_D = P_IN;
  SCL_D = P_IN;
  SCL = 0;
  SCL_D = P_OUT;
*        Function:         IIC_GetBit
*        Parameters: none
*        Return:                value of bit on bus
*        Physical layer of IIC - Read a bit from bus IIC
byte IIC_GetBit(void)
  byte level;
  word i = 0;
  SDA_D = P_IN;
  SCL_D = P_IN;
  level = SDA;
  SCL = 0;
  SCL_D = P_OUT;
  return level;
ccw1986|  楼主 | 2016-1-22 21:03 | 只看该作者
*        Function:         IIC_START
*        Parameters: none
*        Return:                none
*        Physical layer of IIC - Set up START condition on bus
void IIC_START(void)
  SDA = 0;
  SDA_D = P_OUT;
  SCL = 0;
  SCL_D = P_OUT;
*        Function:         IIC_REPEAT_START
*        Parameters: none
*        Return:                none
*        Physical layer of IIC - Set up REPEAT_START condition on bus
void IIC_REPEAT_START(void)
  word i = 0;
  SDA_D = P_IN;
  SCL_D = P_IN;
  IIC_START();
*        Function:         IIC_STOP
*        Parameters: none
*        Return:                none
*        Physical layer of IIC - Set up STOP condition on bus
void IIC_STOP(void)
  word i = 0;
  SDA = 0;
  SDA_D = P_OUT;
  SCL_D = P_IN;
  SDA_D = P_IN;
*        Function:         SwIIC_SendAddressWrite
*        Parameters: tx_byte
*        Return:                none
*        Send device address on bus with write flag
void SwIIC_SendAddressWrite(byte tx_byte)
  byte k;
  tx_byte <<= 1;
  tx_byte &= 0xfe;
  for(k=8;k>0;k--)
    if (tx_byte & 0x80)
      IIC_DATA_1();
    else
      IIC_DATA_0();
    tx_byte <<= 1;
  ak1=IIC_GetBit();
*        Function:         SwIIC_SendAddressRead
*        Return:                none
*        Send device address on bus with read flag
void SwIIC_SendAddressRead(byte tx_byte)
  byte k;
  tx_byte <<= 1;
  tx_byte |= 0x01;
  for(k=8;k>0;k--)
    if (tx_byte & 0x80)
      IIC_DATA_1();
    else
      IIC_DATA_0();
    tx_byte <<= 1;
  ak3=IIC_GetBit();
*        Function:         SwIIC_SendRegister
*        Return:                none
*        Send device internal register address on bus
void SwIIC_SendRegister(byte tx_byte)
  byte k;
  for(k=8;k>0;k--)
    if (tx_byte & 0x80)
      IIC_DATA_1();
    else
      IIC_DATA_0();
    tx_byte <<= 1;
  ak2=IIC_GetBit();
ccw1986|  楼主 | 2016-1-22 21:04 | 只看该作者
*        Function:         IIC_ReadByte
*        Parameters: ack
*        Return:                val
*        Read a byte from IIC bus
byte IIC_ReadByte(byte ack)
byte i, val;
  for(i=8; i>0; i--)
    val <<= 1;
    val |= IIC_GetBit();
  if (ack == IIC_ACK)
    IIC_DATA_0();
  else
    IIC_DATA_1();
  return val;
*        Function:         IIC_SendByte
*        Return:                none
*        Write a byte to IIC bus
void IIC_SendByte(byte tx_byte)
  byte k;
  for(k=8;k>0;k--)
    if (tx_byte & 0x80)
      IIC_DATA_1();
    else
      IIC_DATA_0();
    tx_byte <<= 1;
  ak3=IIC_GetBit();
byte IIC_SendByteM(byte tx_byte)
  byte k;
  for(k=8;k>0;k--)
    if (tx_byte & 0x80)
      IIC_DATA_1();
    else
      IIC_DATA_0();
    tx_byte <<= 1;
  ak3=IIC_GetBit();
  return(ak3);
*        Function:         SwIIC_ReadByte
*        Parameters: RegAdd
*        Return:                none
*        Complete data transfer - read a byte from device register
* Note: Secured routine through check of acknowledge
byte SwIIC_ReadByte(byte RegAdd)
      byte temp;
      ak1=NACK;
      ak2=NACK;
      ak3=NACK;
      while(!(ak3==ACK))
        IIC_START();
        SwIIC_Delay(START_DELAY);
        SwIIC_SendAddressWrite(ION_ADDR);
        SwIIC_Delay(ADDRESS_DELAY);
          if(!ak1)
          SwIIC_SendRegister(RegAdd);
              if(!ak2)
              IIC_REPEAT_START();
              SwIIC_SendAddressRead(ION_ADDR);
              if(!ak3) temp=IIC_ReadByte(IIC_NACK);
      IIC_STOP();
      ak1=NACK;
      ak2=NACK;
    return(temp);
*        Function:         SwIIC_WriteByte
*        Parameters: RegAdd, RegVal
*        Return:                none
*        Complete data transfer - write a byte to device (ION) register
void SwIIC_WriteByte(byte RegAdd, byte RegVal)
      ak1=NACK;
      ak2=NACK;
      ak3=NACK;
      while(ak3)
        IIC_START();
          if(!ak1)
              if(!ak2)
              IIC_SendByte(RegVal);
        IIC_STOP();
        ak1=NACK;
        ak2=NACK;
*        Function:         SwIIC_MultiRead
*        Parameters: RegAdd, *buff (data), cnt - length
*        Return:                none
*        Complete data transfer - multiple write a bytes to device (ION) registers
void SwIIC_MultiReadBytes(byte RegAdd, byte *buff, byte cnt)
  byte i;
  i=0;
  ak1=NACK;
  ak2=NACK;
  ak3=NACK;
      while(!(ak3==ACK))
       IIC_START();
       if(!ak1)
        if(!ak2)
         IIC_REPEAT_START();
         if(!ak3)
          for(i=0;i<(cnt - 1);i++)
           *buff++ = IIC_ReadByte(IIC_ACK);
          *buff++ = IIC_ReadByte(IIC_NACK);
       IIC_STOP();
       ak1=NACK;
       ak2=NACK;
*        Function:         SwIIC_MultiWrite
*        Return:                none
*        Complete data transfer - multiple write a bytes into device (ION) registers
void SwIIC_MultiWriteBytes(byte RegAdd, byte *buff, byte cnt)
  byte i,j,ak[32];
  i=0;
  ak1=NACK;
  ak2=NACK;
  ak3=NACK;
  for(j=0;j<32;j++) ak[j]=NACK;
      while(!(ak[cnt+2]==ACK))
        IIC_START();
          if(!ak1)
              ak[2]=ak2;
              while((!ak[i+2])&&(i<cnt))
                ak[i+3]=IIC_SendByteM(*(buff++));
                i++;
        IIC_STOP();
        ak1=NACK;
        for (j=0;j<(cnt-1);j++) ak[j+2]=NACK;
ccw1986|  楼主 | 2016-1-22 21:05 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]      sw_iic.h
* [url=home.php?mod=space&uid=187600]@author[/url]    R20246
* [url=home.php?mod=space&uid=895143]@version[/url]   2.0.0.1
* [url=home.php?mod=space&uid=212281]@date[/url]      FEB-14-2008
* [url=home.php?mod=space&uid=247401]@brief[/url]     ION (MMA7455L) - Ion MMA7455L in Measure mode (using SPI or IIC)
#ifndef SW_IIC_H
#define SW_IIC_H
#include "derivative.h"
#define ION_ADDR 0x1D /* ION address is 1D */
#define SCL     PTCD_PTCD3
#define SCL_D   PTCDD_PTCDD3
#define SCL_PU  PTCPE_PTCPE3
#define SDA     PTCD_PTCD2
#define SDA_D   PTCDD_PTCDD2
#define SDA_PU  PTCPE_PTCPE2
#define SS      PTBD_PTBD3
#define SS_D    PTBDD_PTBDD3
#define SS_PU   PTBPE_PTBPE3
#define P_OUT   1
#define P_IN    0
#define PU_ON   1
#define PU_OFF  0
#define ACK 0
#define NACK 1
#define IIC_ACK  0
#define IIC_NACK 1
#define START_DELAY 1
#define ADDRESS_DELAY 1
#define SDA_HOLD 5          //20MHz Bus Clock: 1  => IIC 110kHz
#define SCL_HOLD 5          //                 5  => IIC  70kHz
#define MAX_IIC_TIMEOUT 0x9F00
// FUNCTION DECLARATION
void SwIIC_Delay(byte);
void SwIIC_Wait(byte);
void IIC_DATA_0(void);
void IIC_DATA_1(void);
byte IIC_GetBit(void);
void IIC_START(void);
void IIC_REPEAT_START(void);
void IIC_STOP(void);
byte IIC_ReadByte(byte ack);
void IIC_SendByte(byte tx_byte);
byte IIC_SendByteM(byte tx_byte);
void SwIIC_Init(void);
void SwIIC_SendAddressWrite(byte tx_byte);
void SwIIC_SendAddressRead(byte tx_byte);
void SwIIC_SendRegister(byte tx_byte);
byte SwIIC_ReadByte(byte RegAdd);
void SwIIC_WriteByte(byte RegAdd, byte RegVal);
void SwIIC_MultiReadBytes(byte num, byte *buff, byte cnt);
void SwIIC_MultiWriteBytes(byte num, byte *buff, byte cnt);
#endif //SW_IIC_H
neeringstu| | 2016-1-23 20:51 | 只看该作者
这个需要保存啊,也可以用于其他单片机之类的吗
KL系列的iic不是挺好用的吗,为啥还要模拟
