为什么中断里面不需要清除
1670|29
spark周|  楼主 | 2016-1-31 17:41 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
void TimerA1Init( void )
    TA1CTL = TASSEL_2 + MC_2 + ID_3;        // Timer_A1: Continous mode, SMCLK, clock source divided by 8 = 8MHz/8 =1MHz
    TA1CCR1 = TIMEA1_TIME_CONSTANT;         // 10 ms compare interrupt  as key scanf
    TA1CCTL1 = CCIE;
    TA1CTL |=  TAIE;                        //interrupt  enable
#pragma vector=TIMER1_A1_VECTOR
__interrupt void TIMER1_A1_ISR(void)
    uint8_t  ucKeyValue;
    switch(__even_in_range(TA1IV,14))
        case  0: break;             // No interrupt
        case  2:
            TA1CCR1 += TIMEA1_TIME_CONSTANT;       // timer 10ms
spark周|  楼主 | 2016-1-31 17:44 | 显示全部楼层
嗯,我知道了,多谢啊
