audit(1253721012.193:2): enforcing=1 old_enforcing=0 auid=4294967295
security: 3 users, 6 roles, 1658 types, 210 bools, 1 sens, 1024 cats
security: 61 classes, 57675 rules
SELinux: Completing initialization.
SELinux: Setting up existing superblocks.
SELinux: initialized (dev sda1, type ext3), uses xattr
SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts
SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
SELinux: initialized (dev devpts, type devpts), uses transition SIDs
SELinux: initialized (dev eventpollfs, type eventpollfs), uses task SIDs
SELinux: initialized (dev inotifyfs, type inotifyfs), uses genfs_contexts
SELinux: initialized (dev futexfs, type futexfs), uses genfs_contexts
SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
SELinux: initialized (dev cpuset, type cpuset), not configured for labeling
SELinux: initialized (dev proc, type proc), uses genfs_contexts
SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
audit(1253721012.521:3): policy loaded auid=4294967295
e100: Intel(R) PRO/100 Network Driver, 3.5.10-k2-NAPI
e100: Copyright(c) 1999-2005 Intel Corporation
ACPI: PCI Interrupt 0000:04:0d.0[A] -> GSI 21 (level, low) -> IRQ 18
e100: eth0: e100_probe: addr 0xf4220000, irq 18, MAC addr 00:E0:81:00:94:D0
EDAC MC: Ver: 2.0.1 Oct 10 2007
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
intel_rng: FWH not detected
input: PC Speaker as /class/input/input2
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
8250_pnp: Unknown symbol serial8250_unregister_port
8250_pnp: Unknown symbol serial8250_register_port
EDAC i82860: i82860 init one
EDAC MC0: Giving out device to i82860_edac i82860: DEV 0000:00:00.0
hdc: ATAPI 40X DVD-ROM CD-R/RW drive, 8192kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ACPI: PCI Interrupt 0000:00:1f.3[B] -> GSI 17 (level, low) -> IRQ 19
sd 0:0:0:0: Attached scsi generic sg0 type 0
ACPI: PCI Interrupt 0000:00:1f.5[B] -> GSI 17 (level, low) -> IRQ 19
PCI: Setting latency timer of device 0000:00:1f.5 to 64
Floppy drive(s): fd0 is 1.44M
FDC 0 is a National Semiconductor PC87306
intel8x0_measure_ac97_clock: measured 58594 usecs
intel8x0: clocking to 48000
lp0: using parport0 (interrupt-driven).
lp0: console ready
SELinux: initialized (dev ramfs, type ramfs), uses genfs_contexts
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
[drm] Initialized drm 1.0.1 20051102
ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 20
[drm] Initialized radeon 1.25.0 20060524 on minor 0
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
ibm_acpi: ec object not found
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
device-mapper: ioctl: 4.11.0-ioctl (2006-09-14) initialised: dm-devel@redhat.com
device-mapper: multipath: version 1.0.5 loaded
EXT3 FS on sda1, internal journal
Adding 2096472k swap on /dev/sda2. Priority:-1 extents:1 across:2096472k
SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts
IA-32 Microcode Update Driver: v1.14-xen <tigran@veritas.com>
ADDRCONF(NETDEV_UP): eth0: link is not ready
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
Bluetooth: HIDP (Human Interface Emulation) ver 1.1
SELinux: initialized (dev autofs, type autofs), uses genfs_contexts
eth0: no IPv6 routers present
Bridge firewalling registered
ip_tables: (C) 2000-2006 Netfilter Core Team
Netfilter messages via NETLINK v0.30.
ip_conntrack version 2.4 (8192 buckets, 65536 max) - 228 bytes per conntrack
device vif0.0 entered promiscuous mode
xenbr0: port 1(vif0.0) entering learning state
xenbr0: topology change detected, propagating
xenbr0: port 1(vif0.0) entering forwarding state
ADDRCONF(NETDEV_UP): peth0: link is not ready
e100: peth0: e100_watchdog: link up, 100Mbps, full-duplex
ADDRCONF(NETDEV_CHANGE): peth0: link becomes ready
virbr0: no IPv6 routers present
device peth0 entered promiscuous mode
xenbr0: port 2(peth0) entering learning state
xenbr0: port 2(peth0) entering forwarding state
target0:0:0: FAST-80 WIDE SCSI 160.0 MB/s DT (12.5 ns, offset 62)
agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
[drm] Setting GART location based on new memory map
[drm] Loading R200 Microcode
[drm] writeback test succeeded in 1 usecs
由于信息过长,分三段发,万分感谢!
