以下为CAN初始化程序
void CAN_Configuration(void)
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
RCC_ClocksTypeDef RCC_ClocksStatus;
//Configure CAN pin: RX
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//Configure CAN pin: TX
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
RCC_GetClocksFreq(&RCC_ClocksStatus);
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
// CAN cell init
CAN_InitStructure.CAN_TTCM=DISABLE;
CAN_InitStructure.CAN_ABOM=DISABLE;
CAN_InitStructure.CAN_AWUM=DISABLE;
CAN_InitStructure.CAN_NART=DISABLE;
CAN_InitStructure.CAN_RFLM=DISABLE;
CAN_InitStructure.CAN_TXFP=DISABLE;
CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;
CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
CAN_InitStructure.CAN_BS1=CAN_BS1_13tq;
CAN_InitStructure.CAN_BS2=CAN_BS2_2tq;
CAN_InitStructure.CAN_Prescaler=RCC_ClocksStatus.PCLK1_Frequency/(16*250000); //波特率计算,16M/(1+8+7)/4=250k
if(!CAN_Init(CAN1, &CAN_InitStructure))
//CAN初始化失败
Can_Structure.Init_Fail_Flag = true;
return;
/*这里注意的是采用点的位置,也就时BS1,BS2的设置问题,是CANopen协议中推荐的设置。
1Mbps速率下,采用点的位置在6tq位置处,BS1=5,BS2=2
500kbps速率下,采用点的位置在8tq位置处,BS1=7,BS2=3
250kbps速率下,采用点的位置在14tq位置处,BS1=13,BS2=2
125k,100k,50k,20k,10k的采用点位置与250K相同。*/
/* CAN filter init */
/* CAN_FilterInitStructure.CAN_FilterNumber=0;
CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);*/
//CAN filter init
CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
