atmel发布29美金的xmega套件,疯狂DIY吧.
5211|11
 楼主| avr32 发表于 2009-11-3 14:50 | 显示全部楼层 |阅读模式
Atmel Introduces $29 Evaluation Kit for AVR XMEGA
San Jose, CA, November 2, 2009 - Atmel® Corporation (Nasdaq: ATML) today announced the availability of the Xplain evaluation kit for its AVR® XMEGA™ microcontroller family. With a suggested resale price of $29 USD, this kit enables users the ability to evaluate features and system performance of Atmel's XMEGA at a minimum hardware cost. The kit is powered through a mini USB connector where end-users can develop their own applications on XMEGA using Xplain. The 8-/16-bit XMEGA microcontrollers, introduced in 2008, are optimized for ultra- low power and high system performance with a very innovative and complete feature set well suited for a wide range of applications.
Atmel's ATxmega128A1 is the onboard XMEGA device in the Xplain kit. The device is a 100-pin, general purpose microcontroller with 128 KB of In-System Programmable Flash memory and an 8 KB boot section in Flash that can also be used as additional application memory. The ATxmega128A1 contains all features available in the XMEGA family which includes, but is not limited to, a DMA controller, Event system, 12-bit high speed analog peripherals, AES and DES crypto module, external bus interface and all second-generation picoPower™ features achieving the market's lowest power consumption microcontrollers.
For evaluation and development purposes, the Xplain kit contains a speaker with an audio amplifier, a potentiometer and temperature sensor, which are all connected to the 12-bit DAC or ADC on the ATxmega128A1 device. The external memories include an 8 MB SDRAM and an 8 MB serial DataFlash®, and eight buttons and eight LEDs for basic user interface and application interaction are also available. Spare digital and analog pins on the ATxmega128A1 are available through pin-headers for external analog input and output, digital input and output, PWM, input capture, and USART, SPI and I2C-compatible TWI communication.
The Xplain kit is shipped with basic code programmed into the ATxmega128A1 to demonstrate the use of buttons, LEDs and the speaker on the kit. Documentation includes a user guide, schematics and a full bill of materials available at: http://www.atmel.com/Xplain. Additional code examples, good design practices recommendations and general hints and tips are available as application notes at: http://www.atmel.com/AVR.
Xplain supports other development tools from Atmel including the JTAGICE mkII debugger, AVRISP mkII programmer and AVR Studio® - the free AVR IDE Software Development Tool available at http://www.atmel.com/AVRStudio. By using these tools with Xplain, users have the ability to do on-chip debugging or in-system programming.
More information on the XMEGA microcontroller family is available at: http://www.atmel.com/XMEGA.
Availability, Pricing and Photo
The Xplain kit is available now. Suggested retail price is $29 USD per kit.
To download a high-resolution of the Xplain board, please click the following link:
http://www.atmel.com/images/homepage_new/press/xplain_side.jpg
Information:
Atmel's Xplain product information may be retrieved at http://www.atmel.com/Xplain.
For further information on the AVR XMEGA product family, visit http://www.atmel.com/XMEGA.
Press Contacts:
Clive Over, Director of Public Relations
Tel: +1 (408) 436-4305, Email: clive.over@atmel.com
宇容创行 发表于 2009-11-3 14:55 | 显示全部楼层
确实超值
但atmel 的新东西
小心使用,不要等到量产了,发现
1 货买不到了,全中国都没有现货
2 直接停产了,替代产品买不到,或存在bug
 楼主| avr32 发表于 2009-11-3 15:22 | 显示全部楼层
套件规格
•  ATxmega128A1 microcontroller
•  External Memory
-  8MB SDRAM
-  8MB Serial Data Flash
•  AT90USB1287
-  Communication gateway
•  Analog Input (to ADC)
-  Temperature sensor
-  Potentiometer
•  Analog Output (from DAC)
-  Mono speaker via audio amplifier
•  Digital IO
-  UART communication through USB gateway
-  8 micro switch buttons
-  8 LEDs
-  8 spare analog pins
-  8 spare digital pins
古道热肠 发表于 2009-11-3 15:37 | 显示全部楼层
呵呵,与STM32相比,优势何在?
ddb_21ic 发表于 2009-11-3 15:41 | 显示全部楼层
8MB SDRAM
wangkj 发表于 2009-11-3 16:10 | 显示全部楼层
能买到吗,avr32 or avr?
 楼主| avr32 发表于 2009-11-3 22:12 | 显示全部楼层
按**公司的人说:你是GE? Intel?
xwj 发表于 2009-11-3 22:37 | 显示全部楼层
有别的东西要学,没空玩这个
itelectron 发表于 2009-11-4 11:53 | 显示全部楼层
打听 下xwj  在学啥 好玩的东东
lelee007 发表于 2009-11-4 18:31 | 显示全部楼层
板子很漂亮哦
不过$29不算便宜了
BitFu 发表于 2009-11-6 17:14 | 显示全部楼层
29*7=203
也不便宜
happya1 发表于 2009-11-7 21:20 | 显示全部楼层
古道热肠 对你的 串口MP3模块 感兴趣啊,有淘宝吗?看看
