一个24C02B的问题
2318|1
 楼主| lhb8605 发表于 2009-11-4 10:59 | 显示全部楼层 |阅读模式
#include <reg51.h>
#include <math.h>
#include <intrins.h>
#include <serial_t0_interrupt.h>
*函数原型: 变量定义
*功    能: 寄存器和引脚定义
#define uchar unsigned char
#define uint unsigned int
uchar   i,j,k,Temp;
bit    AckTemp;
*函数原型: 宏定义和变量定义
*功    能: 寄存器和引脚定义
void Delay (unsigned int delay_time)
while(delay_time)
  delay_time--;
*函数:起始信号
*功能:向24c02发送起始信号
void I2cStart ()
SCL=0;
Delay(100);
SDA=1;
Delay(100);
SCL=1;
Delay(100);
SDA=0;
Delay(100);
SCL=0;
*函数:停止信号
*功能:向24c02发送停止信号
void I2cStop ()
SDA=0;
Delay(100);
SCL=1;
Delay(100);
SDA=1;
Delay(100);
SCL=0;
*函数:发送0
*功能:向24c02发送0
void Send0 ()
SDA=0;
Delay(100);
SCL=1;
Delay(100);
SCL=0;
Delay(100);
*函数:发送1
*功能:向24c02发送1
void Send1()
SDA=1;
Delay(100);
SCL=1;
Delay(100);
SCL=0;
Delay(100);
*函数:应答信号
*功能:向24c02发送应答信号,函数返回应答信号F0
bit CheckAck ()
SCL=0;
Delay(100);
SDA=1;
Delay(100);
SCL=1;
Delay(100);
F0=SDA;
Delay(100);
SCL=0;
Delay(100);
return F0;
*函数:应答信号
void SendCheckAck ()
SCL=0;
Delay(100);
SDA=0;
Delay(100);
SCL=1;
Delay(100);
SCL=0;
Delay(100);
*函数:发送一个字节
*功能:向24c02发送一个字节
void SendI2cByte (unsigned char SByte)
for (i=0;i<8;i++)
  if ( (SByte<<i)&0x80 )
    Send1();
    Delay(40);
  else
    Send0();
    Delay(40);
*函数:读一个字节
*功能:向24c02读取一个字节,函数返回I2c读到的字节
unsigned char ReadI2cByte ()
unsigned char RByte=0;
for (i=0;i<8;i++)
  SDA=1;    //释放总线
  Delay(100);
  SCL=1;
  Delay(100);
  F0=SDA;
  Delay(100);
  SCL=0;
  Delay(100);
  if(F0)
   RByte=RByte<<1;
   RByte=RByte|0x01;
  else
   RByte=RByte<<1;
return RByte;
*函数:写一个字节给24c02
*功能:向24c02写一个字节,进行函数调用时应送地址WAdd,送字节数据WData
void WriteOneByte (unsigned char WAdd,unsigned char WData)
I2cStart();
SendI2cByte (0xA0);  //器件地址00,写24c02
AckTemp=CheckAck();
SendI2cByte(WAdd);
AckTemp=CheckAck();
SendI2cByte(WData);
AckTemp=CheckAck();
I2cStop();
*函数:写一串字节给24c02
*功能:向24c02写一串字节
/*void WriteOnePage (unsigned char WAdd,unsigned char WDNum)
unsigned char WData[5];
I2cStart();
SendI2cByte(0xA0);  //器件地址00,写24c02
AckTemp=CheckAck();
SendI2cByte(WAdd);
AckTemp=CheckAck();
SendI2cByte(WData);
AckTemp=CheckAck();
I2cStop();
*函数:读一个字节
*功能:向24c02读一个字节,进行函数调用时应该写入要读的地址RAdd,函数返回读到的字节
unsigned char ReadOneByte (unsigned char RAdd)
unsigned char ReadData;
I2cStart();
SendI2cByte(0xA0);  //器件地址,发送0x00,控制0号24c02,执行伪写操作
AckTemp=CheckAck();
SendI2cByte(RAdd);
AckTemp=CheckAck();
I2cStart();    //开始读操作
SendI2cByte(0xA1);
AckTemp=CheckAck();
ReadData=ReadI2cByte();
// SendCheckAck();
I2cStop();
return ReadData;
*函数:Main
*功能:程序运行
main()
serial_initialization();
EA=0;
while(1)
  WriteOneByte(0x01,0x01);
  Delay(60000);
  Delay(60000);
  SBUF=0x11;
  while(!TI);
  TI=0;
  SBUF=ReadOneByte(0x01);
  while(!TI);
  TI=0;
  SBUF=0xEE;
  while(!TI);
  TI=0;
  Delay(60000);
  Delay(60000); //*/
结果串口发送出来数据为:  11 FF EE
大家好,写了一个24c02B的程序,可是就是通讯不上,还请高手帮忙看看。
 楼主| lhb8605 发表于 2009-11-4 13:24 | 显示全部楼层
问题已解决
