[AVR单片机] AVR mega16 SPI双机通讯例子 (为新手设计,简单易懂)
5554|13
 楼主| suoma 发表于 2009-11-16 22:27 | 显示全部楼层 |阅读模式
本程序实现的功能:主机发送1~255,丛机接收并在LED上显示出来。
连接方式: 两个mega16最小系统板 PB4到PB7全部对连。
主机程序:
CODE:
//ICC-AVR application builder : 2007-7-18 13:01:11
// Target : M16
// Crystal: 7.3728Mhz
// 作者:古欣
// AVR与虚拟仪器 http://www.avrvi.com
// 功能:SPI主机模式,循环发送从1~255
#include <iom16v.h>
#include <macros.h>
void port_init(void)
PORTA = 0x00;
DDRA = 0x00;
PORTB = 0x00;
DDRB = 0x00;
PORTC = 0x00; //m103 output only
DDRC = 0x00;
PORTD = 0x00;
DDRD = 0x00;
//SPI initialize
// clock rate: 57599hz
void spi_init(void)
PORTB |= (1<<PB4) | (1<<PB5) | (1<<PB6) | (1<<PB7);
DDRB |= (1<<DDB5) | (1<<DDB7) | (1<<DDB4);     //Set MOSI, SCK AND SS as outputs
SPCR = 0x73; //setup SPI
SPSR = 0x00; //setup SPI
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
spi_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
void SPI_MasterTransmit(char cData)
PORTB &=~ (1<<PB4); //强制接收方进入从模式
SPCR |= (1<<MSTR); // MSTR有时会被清零,这里强制进入主机模式
/* 启动数据传输 */
SPDR = cData;
/* 等待传输结束 */
while(!(SPSR & (1<<SPIF)))
PORTB |= (1<<PB4);
void Delay(void) //延时,没有详细计算
unsigned int i,j;
for(i=1000;i>0;i--)
for(j=200;j>0;j--)
void main(void)
unsigned char i=0;
init_devices();
while(1)
for(i=255;i>0;i--)
SPI_MasterTransmit(i);
Delay();
从机程序
CODE:
//ICC-AVR application builder : 2007-7-18 12:56:10
// Target : M16
// 作者:古欣
// 功能:从机模式,中断方式接收,并在LED上显示
#include <iom16v.h>
#include <macros.h>
PORTA = 0x00;
DDRA = 0xFF;
PORTB = 0x00;
DDRB = 0x00;
DDRC = 0x00;
PORTD = 0x00;
DDRD = 0x00;
//SPI initialize
void spi_init(void)
SPCR = 0xE3; //setup SPI
#pragma interrupt_handler spi_stc_isr:11
void spi_stc_isr(void)
//byte in SPDR has been sent/received
PORTA = SPDR;
port_init();
spi_init();
MCUCR = 0x00;
GICR = 0x00;
void main(void)
init_devices();
DDRB|=(1<<PB6); //MOSI 设置为输出
while(1)
;//等待中断
评分
参与人数 1威望 +1 收起 理由
lion1899 + 1 很给力!
查看全部评分
Karlshen 发表于 2009-11-16 22:33 | 显示全部楼层
看帖子也给分啊:lol
 楼主| suoma 发表于 2009-11-17 14:08 | 显示全部楼层
恩,所以要勤快点哦
Jimdo260122332 发表于 2009-11-24 09:23 | 显示全部楼层
错过-21IC 发表于 2009-11-24 13:04 | 显示全部楼层
我在虚拟论坛看过,不错的
328500920 发表于 2009-11-25 23:15 | 显示全部楼层
 楼主| suoma 发表于 2009-12-2 22:33 | 显示全部楼层
zhao3462910 发表于 2013-5-14 09:27 | 显示全部楼层
支持··
lion1899 发表于 2013-6-15 18:41 | 显示全部楼层
支持+1!!
Frank2013 发表于 2013-6-21 12:58 | 显示全部楼层
学习一下
wentao0100 发表于 2013-7-3 22:41 | 显示全部楼层
来学习的。
回到从前 发表于 2013-7-4 16:10 | 显示全部楼层
来学习一下!
cclgxuanshao 发表于 2016-3-9 15:18 | 显示全部楼层
MARK一下
