急,关于跑马灯程序
4665|10
 楼主| zhuliang1125 发表于 2009-12-8 10:17 | 显示全部楼层 |阅读模式
我是刚学习程序的新人,现在想自己做个跑马灯硬件的很简单
但软件我不知道怎么弄 跑马灯龙舞花样
具体的程序代码如下:
*   File: TheLEDsDragon.c
*   Description: LEDs Gragon Animation
*   Created Date:  2007-09-12
*    Last Modified: 2007-09-12
*    Author: Jeffrey - Schicksal@126.com
*    Notes: None
#include <REGX51.h>
#define LED_FLASH_T 10000;
void LEDs_Move();
void LEDs_Error();
void LEDs_Gragon();
*   Function: delay(unsigned int t)
*   Input Variables: t
*    Return Variables: None
*    Usage: Common Delay Routine, t as the delay time ticks
void delay(unsigned int t)
        for(;t>0;t--);      // 延时循环
#ifndef true
    #define true 1
#endif
#define TASK_1 1
#define TASK_2 2
*   Function: main()
*   Input Variables: None
*    Usage: Program Entry
void main()
        unsigned char System_Status = true;
        unsigned char System_Task = TASK_2;
        while(1)
                // 程序主任务区
//LEDs_Move();
                // 程序主任务区
                if(System_Status == true)               // 当系统处于正常状态
                        if(System_Task == TASK_1)       // 程序分支一
                                LEDs_Move();                // 跑马灯指示系统正常
                        else if(System_Task == TASK_2)  // 程序分支二
                                LEDs_Dragon();          // 跑马灯龙舞花样指示
                else                                        // 当系统发生错误
                        LEDs_Error();                   // 跑马灯指示错误
*   Function: LEDs_Move
*   Usage: System Normal Status Report
void LEDs_Move()
        static unsigned char LEDs = 0x55;       // 静态变量用于存储LEDs发光状态
        P0 = LEDs;                              // LED间隔亮灭并移位
        delay(LED_FLASH_T);                     // 延时
        LEDs = ~LEDs;                           // 状态改变
*   Function: LEDs_Error
*    Usage: System Error Status Report
void LEDs_Error()
        static unsigned char LEDs = 0x00;        // 静态变量用于存储LEDs发光状态
        P0 = LEDs;                              // LED警告报警亮灭
*   Function: LEDs_Dragon
*    Usage: System Dragon LED Animation
void LEDs_Dragon()
    static unsigned char Direction = 1;           // 静态变量用于存储龙舞方向
    static unsigned char LED_status = 0x0F;     // 静态变量用于存储LEDs发光状态
    if(Direction==1)
        if(LED_status>=0x0F)
            LED_status=LED_status<<1;
        else if(LED_status==0x07)
            LED_status=0x0F;
        else if(LED_status==0x03)
            LED_status=0x07;
        else
            LED_status=0x03;
        if(LED_status==0xC0)
            Direction=0;
    else
        if(LED_status==0xE0)
            LED_status=0xF0;
            LED_status=0xE0;
        else if(LED_status<=0xF0)
            LED_status=LED_status>>1;
            Direction=1;
    P0=~LED_status;
怎么才弄这程序才完整?
谢谢了?
千古寸心 发表于 2009-12-8 21:48 | 显示全部楼层
呵呵,本人眼拙,不知道你要问啥
houfire007 发表于 2009-12-8 22:22 | 显示全部楼层
函数可正确?
 楼主| zhuliang1125 发表于 2009-12-9 08:30 | 显示全部楼层
就是怎么把上面的程序写正确,呵呵我是初学者,希望大家指导
auzxj 发表于 2009-12-9 08:34 | 显示全部楼层
你的意思是上面的程序有问题???
和2楼一样不知道你在问什么
 楼主| zhuliang1125 发表于 2009-12-9 09:12 | 显示全部楼层
是的  那程序有问题 更重要的是 我不知道void LEDs_Error()
void LEDs_Move()
这2个子程序的作用
 楼主| zhuliang1125 发表于 2009-12-9 09:13 | 显示全部楼层
希望大家能教我这只笨鸟
auzxj 发表于 2009-12-9 10:25 | 显示全部楼层
这是C语言问题啊
LEDs_Error()用来指示系统错误的
LEDs_Move()用来指示系统正常
从这个程序看,这两个函数都不会被调用,只会一只调用 LEDs_Dragon();
若想调用LEDs_Error()LEDs_Move()需要把 unsigned char System_Status = true;unsigned char System_Task = TASK_2;    改一下,怎么改看下程序就会懂了,努力学习一下C语言吧,这里连中断都没有,纯语言的东西
这两个函数中注意一下“static unsigned char”,看一下C的课本,理解一下这个变量时如何变化的
chunyisihai 发表于 2009-12-9 11:40 | 显示全部楼层
如楼上所说!System_Task没变化,LEDs_Error(),LEDs_Move()根本没调用,楼主去多看看C语言。
auzxj 发表于 2009-12-9 11:42 | 显示全部楼层
这是这个程序的流程图,你看下吧
[img][/img]
 楼主| zhuliang1125 发表于 2009-12-9 12:27 | 显示全部楼层
谢谢大家
