求助DSP2812发出10M的PWM,占空比可变
3445|3
 楼主| thf2008 发表于 2009-12-19 09:35 | 显示全部楼层 |阅读模式
打算用EVA来做这这个
时钟设置:
SysCtrlRegs.PLLCR.bit.DIV = 0x4;   //主频应该是60M
SysCtrlRegs.HISPCP.all = 0x0001;
SysCtrlRegs.LOSPCP.all = 0x0001;
EVA设置:
    // Set the Period for the GP timer 2 to 0x0200;
    EvaRegs.T2PR = 0x06;       // Period
    EvaRegs.T2CMPR = EvaRegs.T2PR/4;     // Compare Reg
    // Enable Period interrupt bits for GP timer 2
    // Count up, x128, internal clk, enable compare, use own period
    EvaRegs.EVAIMRB.bit.T2PINT = 1;
    EvaRegs.EVAIFRB.bit.T2PINT = 1;
    // Clear the counter for GP timer 2
    EvaRegs.T2CNT = 0x0000;
    EvaRegs.T2CON.all = 0x1042;
中断设置:
interrupt void eva_timer2_isr(void)
  EvaTimer2InterruptCount++;
  // Enable more interrupts from this timer
   if(OSCL_Flag == 1)
                OSCL=1;
                OSCL_Flag = 0;
   }else{
                OSCL=0;
                OSCL_Flag = 1;
  // Note: To be safe, use a mask value to write to the entire
  // EVAIFRB register.  Writing to one bit will cause a read-modify-write
  // operation that may have the result of writing 1's to clear
  // bits other then those intended.
  EvaRegs.EVAIFRB.all = BIT0;
  // Acknowledge interrupt to receive more interrupts from PIE group 3
  PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
按照上面的设置,应该得到,10M,占空比为25%的PWM,但是结果不是,而是1M左右的PWM,好像占空比也没有改变,这是为何?清高手指教
linhai2009 发表于 2009-12-19 09:57 | 显示全部楼层
10M?10000kHz?要这么快的pwm来做什么?
wangwo 发表于 2009-12-19 23:21 | 显示全部楼层
占空比没有改变?怎么说?原来多少,应该变成多少?
juventus9554 发表于 2009-12-22 22:51 | 显示全部楼层
没碰到过这个要求的呢
