vmgsim3.1.36流程模拟软件化学工艺模拟
2484|0
 楼主| bjxrjw 发表于 2009-12-25 10:27 | 显示全部楼层 |阅读模式
VMGSim新版本3.2正式发布  我们现在有最新版的vmgsim3.1.36
经过几个月的测试,VMG宣布发布新版本VMGSim3.2, 该版本的主要特色如下:
New Reporting Tools 新的模拟报告工具
VMGSim makes it easy to display the most relevant information of a collection of objects such as unit operations, streams, controller, or information unit operations in a tabular format using the Summary Set tool.  在VMGSim中利用Summary Set工具你能够非常容易地以表格的形式显示许多例如单元操作,物流,控制器,信息单元操作等采集对象的相关信息。qq:394623568  电话:13294332477  软件经过测试可以完整好用,有需要可以联系
When selecting variables, the user can select their own display names for each variable, choose specific display units and display format for each variables. Once the user has selected the desired variables/configuration can be stored as a data group and used later在选择变量时,用户可以自己命名每个变量的显示名称,选择特定的显示单位以及每个变量的显示格式,当用户已经选择了满意的变量/配置后可以将其作为数据组进行储存以便今后的调用。
Summaries can be exported to ExcelTM, WordTM  as well as the clipboard or printer.汇总表可以输出到ExcelTM, WordTM 以及剪贴板中,也可以打印
New Unit Operations新的单元操作
A new Plasma Gasification unit operation is introduced in this version after extensive field testing by some of the leading companies in the use of this technology. The model includes complete atomic balances, detailed equipment options and extensive pre-built kinetic parameters for the main carbon reactions and necessary options to model product distributions.在经过一些处于行业领导地位的公司的广泛测试之后,一个全新的煤浆气化炉单元操作正式集成到本版本中。本模型包含了完整的原子平衡,详细的设备选项,及预先建立的有关碳元素的主要化学反应的广泛的动力学参数和模拟产品分布的必要选项。
New Thermodynamic Methods 新的热力学方法
Virtual Materials Group new Gasification property package is also introduced in this version. Accurate absolute enthalpies of gases and solids necessary for the modeling of this new important class of problems is provided together with phase change data for metals and inorganic oxides, and closely integrated with our new Plasma Gasification unit operation. VMG公司新的Gasification物性包也被置于本版本中。本版本还提供了对于新的重要级别的建模问题所必须的气体和固体的绝对焓值,以及金属及四轴飞行器氧化物相变的准确计算,并于我们新的Plasma Gasification单元操作紧密集成在一起。
The NH3FlueGasTreating property package is available with this release uses a rigorous electrolytic model to simulate the reactions in liquid phase based on VMG’s proven Amine model. 本版本还提供了一个NH3FlueGasTreating物性包,它基于VMG的胺包用严格的电解质模型来模拟液相中的化学反应。
Partial List of New Features and Enhancements部分新特性一览表
    Flow sheeting 流程图qq:394623568  电话:13294332477  软件经过测试可以完整好用,有需要可以联系
ü      Support for Microsoft Excel 2007 支持微软的Excel 2007
ü      Customizable Microsoft Word Template 可自定义微软Word模板
ü      Added CSS style to format HTML reports 增加的CSS类型以便定制HTML报告
Unit Operations 单元操作
ü      Plasma Gasification unit operation  煤浆汽化单元操作
ü      Automatic TEMA clearance calculations for heat exchanger rating 对于换热器核算的自动TEMA间隙计算功能
ü      Approach to equilibrium and temperature control for individual chemical reactions 对于每个的化学反应的平衡差距及温度控制功能
ü      Solve compressors and expanders with outlet temperature specified 规定出口温度进行压缩机和膨胀机的求解
ü      Solve compressors, expanders and pumps with Pressure Ratio Spec  规定压比进行压缩机,膨胀机及机泵的求解
Dynamics动态模拟
ü      Split range controller 分程控制器
ü      Generic fire formula for depressuring studies 普通火灾卸压研究
ü      New heat transfer expressions for horizontal tubes 水平管道新的热传递公式
ü      Reciprocating compressor 往复式压缩机
ü      Beggs and Brill correlation in pipes 管道计算的Beggs 和 Brill关联式
ü      NEMA B curve support for modeling electric motors 对于电动马达的模拟的NEMA B 曲线支持
Thermodynamics 热力学
ü      New NH3FlueGasTreating property package 新的NH3FlueGasTreating物性包
ü      New Gasification property package 新的Gasification物性包
ü      Support for CO2 and H2S in Steam95 在Steam95中支持CO2和H2S
ü      Added COASTAL-AGR and PEGDME-280SM to Physical Solvents property package 在物理溶剂物性包中支持COASTAL-AGR和PEGDME-280SM
ü      New pure components 新增了一些纯组分
