求助:LPC2388可否不加外复位电路?
2589|0
 楼主| NE5532 发表于 2010-1-5 14:07 | 显示全部楼层 |阅读模式
做一个LPC2388的板子,发现有的板子复位不可靠,现象描述在下面(抄的给NXP的邮件,不翻译了)。求助有没有用过的朋友,我是直接用6k2的上拉拉到电源上的。
I'am Using LPC2388. In the datasheet, it said this chip has POR function, So I use it without any external reset IC but tied the reset pin to Vcc from a k2 resistor. But I found some of my system CAN'T reset reliably, after power on, it doesn't run my program, if I tied the reset pin to GND and then release it use a jumper, the program start to run, or if I shortly re-tuen on the power the program runs OK.
My question is : Does LPC2388 can work reliably WITH OUT extern reset IC or R-C reset circuit? i.e. it can reset it self when power on?
个人签名:††††看NE5532教学视频,炼就工程技术研发功力†††††††††† 《跟我学DC-DC电源管理技术》【从只会写软件成长为软硬兼施】 《印刷电路板设计进阶》【12年一线设计经验大放送】 《印刷电路板设计基础》【新手别怕,老工程师带你入门!】
159
