[Actel FPGA] spi 编译报错 请高手指点
1892|4
 楼主| 3B1105 发表于 2010-1-6 22:44 | 显示全部楼层 |阅读模式
//spi_slave.v---------------------------------------
// designed for format A, active high
module SPI_slave(clk, MOSI, SSEL,datain);
input clk;
input SSEL, MOSI;
output[7:0] datain;
reg [1:0] MOSIr;  always @(posedge clk) MOSIr <= {MOSIr[0], MOSI};
wire MOSI_data = MOSIr[0];
reg [3:0] bitcnt; //count for bit
reg byte_received;  // high when a byte has been received
reg [7:0] byte_data_received;
begin
  if((~SSEL)||(~((bitcnt<8)&&(bitcnt>0))))
    bitcnt <= 4'b0000;
  else
                        begin
                                 bitcnt <= bitcnt + 3'b001 ;
                                 byte_data_received <= {byte_data_received[6:0], MOSI_data};
                        end
end
always @(posedge clk) byte_received =(bitcnt==4'b1000);
    if(byte_received)
    begin
        bitcnt <= 0;
        datain <= byte_data_received;     //modelsim 仿真该行报错何解  高手指点
    end
endmodule
yoyowodeai 发表于 2010-1-7 22:42 | 显示全部楼层
路过,不懂!不过好意思
午夜粪车 发表于 2010-1-7 22:45 | 显示全部楼层
好意思?啥意思?
sunmooning 发表于 2010-1-8 20:54 | 显示全部楼层
错误的提示也不给写出来,怎么知道具体错出现在什么地方呢?
6019赵文 发表于 2010-1-8 23:26 | 显示全部楼层
看不出错误在哪,不好意思
