请用数学原理证明下面的Q格式乘法和除法的舍入
2859|0
 楼主| snakeemail 发表于 2010-1-26 23:12 | 显示全部楼层 |阅读模式
TI, COM, ecom, ic, IO
Multiplication
// precomputed value:
#define K   (1 << (Q-1))
signed int       a, b, result;
signed long int  temp;
temp = (long int) a * (long int) b; // result type is operand's type
// Rounding; mid values are rounded up
temp += K;
// Correct by dividing by base
result= temp >> Q;
[edit]
Division
signed int a,b,result;
// pre-multiply by the base
temp = (long int)a << Q;
// So the result will be rounded ; mid values are rounded up.
temp = temp+b/2;
result = temp/b;
个人签名:提供500W线性 交流电源。0~300VAC,45~500Hz 提供10KW,0-330V直流电源,具体见http://blog.21ic.com/user1/3639/archives/2012/88528.html
547
