如何在AD程序中添加串口程序
3889|7
 楼主| tiger2010 发表于 2010-2-7 13:18 | 显示全部楼层 |阅读模式
想利用利用串口把AD采集的数值发给上位机,但是自己添加了几次都不成功,希望高手指点一下该如何设置程序,不胜感激,AD主程序如下,除了在主程序中需要改动外,想问下还需要改动或者添加哪些文件?现在很是苦恼,希望高手给多多指点啊
#include "DSP281x_Device.h"     // DSP281x Headerfile Include File
#include "DSP281x_Examples.h"   // DSP281x Examples Include File
// Prototype statements for functions found within this file.
interrupt void adc_isr(void);
// Global variables used in this example:
Uint16 LoopCount;
Uint16 ConversionCount;
Uint16 Voltage1[1024];
Uint16 Voltage2[1024];
main()
InitSysCtrl();//初始化cpu
   DINT;//关中断
   InitPieCtrl();//初始化pie寄存器
   IER = 0x0000;//禁止所有的中断
   IFR = 0x0000;
   InitPieVectTable();//初始化pie中断向量表
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
   EALLOW;  // This is needed to write to EALLOW protected register
   PieVectTable.ADCINT = &adc_isr;
   EDIS;    // This is needed to disable write to EALLOW protected registers
   AdcRegs.ADCTRL1.bit.RESET = 1;                // Reset the ADC module
        asm(" RPT #10 || NOP");                                // Must wait 12-cycles (worst-case) for ADC reset to take effect
   AdcRegs.ADCTRL3.all = 0x00C8;                // first power-up ref and bandgap circuits
   AdcRegs.ADCTRL3.bit.ADCBGRFDN = 0x3;        // Power up bandgap/reference circuitry
   AdcRegs.ADCTRL3.bit.ADCPWDN = 1;                // Power up rest of ADC
// Enable ADCINT in PIE
   PieCtrlRegs.PIEIER1.bit.INTx6 = 1;
   IER |= M_INT1; // Enable CPU Interrupt 1
   EINT;          // Enable Global interrupt INTM
   ERTM;          // Enable Global realtime interrupt DBGM
   LoopCount = 0;
   ConversionCount = 0;
// Configure ADC
   AdcRegs.ADCMAXCONV.all = 0x0001;       // Setup 2 conv's on SEQ1
   AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0; // Setup ADCINA3 as 1st SEQ1 conv.
   AdcRegs.ADCCHSELSEQ1.bit.CONV01 = 0x1; // Setup ADCINA2 as 2nd SEQ1 conv.
   AdcRegs.ADCTRL2.bit.EVA_SOC_SEQ1 = 1;  // Enable EVASOC to start SEQ1
   AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 1;  // Enable SEQ1 interrupt (every EOS)
// Configure EVA
// Assumes EVA Clock is already enabled in InitSysCtrl();
   EvaRegs.T1CMPR = 0x0080;               // Setup T1 compare value
   EvaRegs.T1PR = 0x10;                 // Setup period register
   EvaRegs.GPTCONA.bit.T1TOADC = 1;       // Enable EVASOC in EVA
   EvaRegs.T1CON.all = 0x1042;            // Enable timer 1 compare (upcount mode)
// Wait for ADC interrupt
   while(1)
      LoopCount++;
  Voltage1[ConversionCount] = AdcRegs.ADCRESULT0 >>4;
  Voltage2[ConversionCount] = AdcRegs.ADCRESULT1 >>4;
  // If 40 conversions have been logged, start over
  if(ConversionCount == 1023)
     ConversionCount = 0;//breakpoint
  else ConversionCount++;
  // Reinitialize for next ADC sequence
  AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;         // Reset SEQ1
  AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;       // Clear INT SEQ1 bit
  PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;   // Acknowledge interrupt to PIE
  return;
llljh 发表于 2010-2-7 13:24 | 显示全部楼层
把串口通信例程加上,然后,在AD采到数据后,调用串口发送程序,就可以了!
linhai1986 发表于 2010-2-8 00:28 | 显示全部楼层
楼上说的对,在AD采到数据的最后加上发送程序就行了
xiaoxin1986 发表于 2010-2-8 00:57 | 显示全部楼层
LZ说添加了几次都没成功,不知LZ是加了什么程序没成功?
 楼主| tiger2010 发表于 2010-2-8 12:43 | 显示全部楼层
原来这样,我下午试试
谢谢楼上几位达人
thf2008 发表于 2010-2-8 13:04 | 显示全部楼层
这个很简答啊,LZ还是要多看看例程
liliang9554 发表于 2010-2-9 00:36 | 显示全部楼层
期待结果
