[DSP编程] 看不懂这程序的作用!!求指点下
1062|0
 楼主| 荼蘼的夏伤 发表于 2016-5-4 20:02 | 显示全部楼层 |阅读模式
interrupt void adc_isr(void);
// Global variables used in this example:
Uint16 LoopCount;
Uint16 ConversionCount;
Uint16 Frequence;//5,10,15,20,25,30,35,40,45,50Hz:
Uint16 Voltage;  //30,49,66,88,110,154,176,180,220v:
void DSP281x_ADCIO(void)
   InitAdc();  // For this example, init the ADC
// Enable ADCINT in PIE
   PieCtrlRegs.PIEIER1.bit.INTx6 = 1;
   IER |= M_INT1; // Enable CPU Interrupt 1
   EINT;          // Enable Global interrupt INTM
   ERTM;          // Enable Global realtime interrupt DBGM
   LoopCount = 0;
   ConversionCount = 0;
// Configure ADC:start/stop mode
   AdcRegs.ADCMAXCONV.all = 0x0000;       // Setup 2 conv's on SEQ1
   AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x3; // Setup ADCINA3 as 1st SEQ1 conv.
   AdcRegs.ADCTRL2.bit.EXT_SOC_SEQ1 = 1;  // Enable EXTSOC to start SEQ1
   AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 1;  // Enable SEQ1 interrupt (every EOS)
// Wait for ADC interrupt
   while(1)
      LoopCount++;
interrupt void  adc_isr(void)  // interrupt :Keyword
  Frequence =(Uint16)((AdcRegs.ADCRESULT0 >>6)/81.6);//Input the Frequence
  Voltage =(Uint16)(4.4*Frequence);//Acorrding with VVVF curve get the voltage
  // If 40 conversions have been logged, start over
  if(ConversionCount == 1)
  else ConversionCount++;
  // Reinitialize for next ADC sequence
  AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;         // Reset SEQ1
  AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;       // Clear INT SEQ1 bit
  PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;   // Acknowledge interrupt to PIE
  return;
