一步一步完善我的设计(4):实现
683|5
keer_zu|  楼主 | 2016-5-20 10:35 | 只看该作者
AddTask.h
#ifndef __ADD_TASK_H__
#define __ADD_TASK_H__
#include <stdio.h>
#include <iostream>
#include <string>
#include <vector>
#include "json/json.h"
using namespace std;
class Transaction
public:
  virtual ~Transaction(){}
  virtual void Execute() = 0;
class CreateTaskTranscation : public Transaction
public:
        virtual ~CreateTaskTranscation(){}
        virtual void Execute();
        virtual bool SetCommandNames()=0;
protected:
        //string m_taskId;
        vector<string> m_commandNames;
class CreateVideoTaskTranscation : public CreateTaskTranscation
        CreateVideoTaskTranscation()
public:
        ~CreateVideoTaskTranscation(){}
        static CreateVideoTaskTranscation& GetInstance();
        virtual bool SetCommandNames();
class CreateDocTaskTranscation : public CreateTaskTranscation
        CreateDocTaskTranscation()
public:
        ~CreateDocTaskTranscation(){}
        static CreateDocTaskTranscation& GetInstance();
class CreateDpptTaskTranscation : public CreateTaskTranscation
        CreateDpptTaskTranscation()
public:
        ~CreateDpptTaskTranscation(){}
        static CreateDpptTaskTranscation& GetInstance();
class AddTask
        AddTask *next; // 1. "next" pointer in the base class
protected:
        CreateTaskTranscation* m_createTaskTranscation;
public:
        virtual void GetInfo() = 0;
        AddTask()
                next = NULL;
        void setNext(AddTask *n)
                next = n;
        void add(AddTask *n)
                if (next)
                        next->add(n);
                else
                        next = n;
        virtual void AddSpacificTask(Json::Value value)
                if(next != NULL)
                        next->AddSpacificTask(value);
                else
                        printf("error");
                        // TODO: log
class AddVideoTask : public AddTask
        AddVideoTask();
public:
        virtual void GetInfo(){}
        static AddVideoTask& GetInstance();
        virtual void AddSpacificTask(Json::Value value);
class AddDocTask : public AddTask
        AddDocTask();
public:
        static AddDocTask& GetInstance();
class AddDpptTask : public AddTask
        AddDpptTask();
public:
        static AddDpptTask& GetInstance();
#endif
keer_zu|  楼主 | 2016-5-20 10:36 | 只看该作者
AddTask.cpp
#include "AddTask.h"
#include "TsManager.h"
#include "CommandDb.h"
//class CommandDb;
extern CommandDb GCommandDb;
////////////////////////// CreateTaskTranscation ////////////////////////
void CreateTaskTranscation::Execute()
////////////////////////CreateVideoTaskTranscation //////////////////////
CreateVideoTaskTranscation& CreateVideoTaskTranscation::GetInstance()
        static  CreateVideoTaskTranscation instance_;
        return instance_;
bool CreateVideoTaskTranscation::SetCommandNames()
////////////////////////CreateDocTaskTranscation //////////////////////
CreateDocTaskTranscation& CreateDocTaskTranscation::GetInstance()
        static  CreateDocTaskTranscation instance_;
        return instance_;
bool CreateDocTaskTranscation::SetCommandNames()
////////////////////////CreateDpptTaskTranscation //////////////////////
CreateDpptTaskTranscation& CreateDpptTaskTranscation::GetInstance()
        static  CreateDpptTaskTranscation instance_;
        return instance_;
bool CreateDpptTaskTranscation::SetCommandNames()
//==========================  AddTask ===========================
//========================  AddVideoTask =========================
AddVideoTask& AddVideoTask::GetInstance()
        static  AddVideoTask instance_;
        return instance_;
AddVideoTask::AddVideoTask()
        m_createTaskTranscation = &CreateVideoTaskTranscation::GetInstance();
        GCommandDb.GetCommandNameInSpecificTsType(TS_VIDEO,m_commandNames);
void AddVideoTask::AddSpacificTask(Json::Value value)
        if(value["command"].asString() == "video_trans_task") {
                cout << "handle video task!" << endl;
        } else {
                AddTask::AddSpacificTask(value);
//=========================  AddDocTask ==========================
AddDocTask& AddDocTask::GetInstance()
        static  AddDocTask instance_;
        return instance_;
AddDocTask::AddDocTask()
        m_createTaskTranscation = &CreateDocTaskTranscation::GetInstance();
        GCommandDb.GetCommandNameInSpecificTsType(TS_DOCUMENT_LINUX,m_commandNames);
        GCommandDb.GetCommandNameInSpecificTsType(TS_DOCUMENT_OFFICE,m_commandNames);
        GCommandDb.GetCommandNameInSpecificTsType(TS_DOCUMENT_WPS,m_commandNames);
void AddDocTask::AddSpacificTask(Json::Value value)
        if(value["command"].asString() == "doc_trans_task") {
                cout << "handle doc task!" << endl;
        } else {
//========================  AddDpptTask ==========================
AddDpptTask& AddDpptTask::GetInstance()
        static  AddDpptTask instance_;
        return instance_;
AddDpptTask::AddDpptTask()
        m_createTaskTranscation = &CreateDpptTaskTranscation::GetInstance();
        GCommandDb.GetCommandNameInSpecificTsType(TS_DYNAMIC_PPT,m_commandNames);
void AddDpptTask::AddSpacificTask(Json::Value value)
        if(value["command"].asString() == "dynamic_ppt_trans_task"){
                cout << "handle dppt task!" << endl;
        } else {
keer_zu|  楼主 | 2016-5-20 17:10 | 只看该作者
扩展一条新命令,只需在这里面派生一个新的命令类,不需要修改之前代码,保证开闭原则:
头文件:
CommandDb.h
#ifndef __COMMAND_DB_H__
#define __COMMAND_DB_H__
#include <string>
#include "Task.h"
class Command
protected:
        string m_commandName;
        TsProperty m_tsProperty;
        bool m_isUseTs;
        TsType m_tsType;
        TaskType m_taskType;
public:
        Command();
        virtual ~Command();
        string GetCommansName(){ return m_commandName;}
        TsType GetTsType(){return m_tsType;}
        TaskType GetTaskType(){return m_taskType;}
        virtual bool BuildTsCmd(const Json::Value& appCmd,Json::Value& tsCmd);
        virtual bool BuildTsResponse(const Json::Value& tsResult,Json::Value& tsResponse);
        virtual bool BuildAppResult(const Json::Value& tsResult,Json::Value& appResult);
        virtual bool  BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse) = 0;
///////////////////////////////// specific command //////////////////////////////////////
class CommandServerStatus : public Command
public:
        CommandServerStatus();
        ~CommandServerStatus();
        virtual bool  BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse);
class CommandVideoMessage : public Command
public:
        CommandVideoMessage()
                m_commandName = "video_message_task";
                m_isUseTs = true;
                m_tsType = TS_VIDEO;
                m_tsProperty = TS_LIGHT;
                m_taskType = VideoTask;
        ~CommandVideoMessage(){}
class CommandVideoTrans : public Command
public:
        CommandVideoTrans()
                m_commandName = "video_trans_task";
                m_isUseTs = true;
                m_tsProperty = TS_HEAVY;
        ~CommandVideoTrans(){}
class CommandPrintScreen : public Command
public:
        CommandPrintScreen()
                m_commandName = "print_screen_task";
                m_isUseTs = true;
        ~CommandPrintScreen(){}
class CommandVideoCut : public Command
public:
        CommandVideoCut()
                m_commandName = "video_cut_task";
                m_isUseTs = true;
class CommandVideoMerge : public Command
public:
        CommandVideoMerge()
                m_commandName = "video_merge_task";
                m_isUseTs = true;
class CommandDocTrans : public Command
public:
        CommandDocTrans()
                m_commandName = "doc_trans_task";
                m_isUseTs = true;
                m_taskType = DocTask;
class CommandDynamicPptTrans : public Command
public:
        CommandDynamicPptTrans()
                m_commandName = "dynamic_ppt_trans_task";
                m_isUseTs = true;
                m_tsType = TS_DYNAMIC_PPT;
                m_taskType = DpptTask;
class CommandTaskProgress : public Command
public:
        CommandTaskProgress()
                m_commandName = "task_progress_request";
                m_isUseTs = false;
                m_taskType = NoTsTask;
/////////////////////////////////  CommandDb  ///////////////////////////////////////
class CommandDb
public:
        CommandDb();
        ~CommandDb();
        bool AddCommand(Command* cmd);
        bool GetCommandNameInSpecificTaskType(TaskType taskType,vector<string>& CommandNames);
private:
        map<string,Command*> m_commands;
#endif
keer_zu|  楼主 | 2016-5-20 17:11 | 只看该作者
实现:
CommandDb.cpp
CommandServerStatus GCmdServerStatus;
CommandVideoMessage GCmdVideoMessage;
CommandVideoTrans GCmdVideoTrans;
CommandPrintScreen GCmdPrintScreen;
CommandVideoMerge GCmdVideoMerge;
CommandDocTrans GCmdDocTrans;
CommandDynamicPptTrans GCmdDynamicPptTrans;
////////////////////////////////////// Command //////////////////////////////////////////
Command::Command()
Command::~Command()
bool Command::BuildTsCmd(const Json::Value& appCmd,Json::Value& tsCmd)
        return true;
bool Command::BuildTsResponse(const Json::Value& tsResult,Json::Value& tsResponse)
        return true;
bool Command::BuildAppResult(const Json::Value& tsResult,Json::Value& appResult)
        return true;
//////////////////////////////////// CommandServerStatus ///////////////////////////////////////////
CommandServerStatus::CommandServerStatus()
        m_commandName = "server_status_task";
        m_isUseTs = false;
CommandServerStatus::~CommandServerStatus()
bool  CommandServerStatus::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
////////////////////////////////////// CommandVideoMessage //////////////////////////////////////
bool  CommandVideoMessage::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
////////////////////////////////////// CommandVideoTrans ///////////////////////////////////////
bool  CommandVideoTrans::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
///////////////////////////////////// CommandPrintScreen ///////////////////////////////////////
bool CommandPrintScreen::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
///////////////////////////////////// CommandVideoCut /////////////////////////////////////////
bool CommandVideoCut::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
///////////////////////////////////// CommandVideoMerge //////////////////////////////////////
bool CommandVideoMerge::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
//////////////////////////////////// CommandDocTrans ////////////////////////////////////////
bool CommandDocTrans::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
/////////////////////////////////// CommandDynamicPptTrans //////////////////////////////////
bool CommandDynamicPptTrans::BuildAppResponse(const Json::Value& appCmd,Json::Value& appResponse)
        return true;
///////////////////////////////// CommandTaskProgress ///////////////////////////////////////
bool CommandTaskProgress::BuildAppResponse(const  Json::Value & appCmd, Json::Value & appResponse)
/////////////////////////////////////// CommandDb ////////////////////////////////////////
CommandDb::CommandDb()
        AddCommand(&GCmdServerStatus);
        AddCommand(&GCmdVideoMessage);
        AddCommand(&GCmdVideoTrans);
        AddCommand(&GCmdPrintScreen);
        AddCommand(&GCmdVideoMerge);
        AddCommand(&GCmdDocTrans);
        AddCommand(&GCmdDynamicPptTrans);
CommandDb::~CommandDb()
bool CommandDb::AddCommand(Command* cmd)
        m_commands[cmd->GetCommansName()] = cmd;
        return true;
bool CommandDb::GetCommandNameInSpecificTaskType(TaskType taskType,vector<string>& CommandNames)
        map<string,Command *>::iterator it;
        for(it=m_commands.begin();it!=m_commands.end();++it){
                if(it->second->GetTaskType() == taskType)
                        CommandNames.push_back(it->first);
keer_zu|  楼主 | 2016-5-20 17:12 | 只看该作者
以上类的框架有了,内容填上就行。
1466
