[STM32F1] cubemx生成的F103的SPI代码运行不成功
2618|7
 楼主| wanyisq 发表于 2016-5-25 09:19 | 显示全部楼层 |阅读模式
我把以前的工程中的模拟SPI换成cubemx生成的硬件SPI代码,驱动OLED。但是一直没效果。之前没用过CUBEMX,不知道问题在哪。
生成的SPI.c文件如下
  1. #include "spi.h"
  2. #include "gpio.h"
  3. SPI_HandleTypeDef hspi1;
  4. void MX_SPI1_Init(void)
  5. {
  6. hspi1.Instance = SPI1;
  7. hspi1.Init.Mode = SPI_MODE_MASTER;
  8. hspi1.Init.Direction = SPI_DIRECTION_2LINES;
  9. hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
  10. hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
  11. hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
  12. hspi1.Init.NSS = SPI_NSS_SOFT;
  13. hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_16;
  14. hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
  15. hspi1.Init.TIMode = SPI_TIMODE_DISABLED;
  16. hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLED;
  17. hspi1.Init.CRCPolynomial = 10;
  18. HAL_SPI_Init(&hspi1);
  19. }
  20. void HAL_SPI_MspInit(SPI_HandleTypeDef* hspi)
  21. {
  22. GPIO_InitTypeDef GPIO_InitStruct;
  23. if(hspi->Instance==SPI1)
  24. {
  25. __SPI1_CLK_ENABLE();
  26. GPIO_InitStruct.Pin = GPIO_PIN_5|GPIO_PIN_7;
  27. GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  28. GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
  29. HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  30. }
  31. }
  32. void HAL_SPI_MspDeInit(SPI_HandleTypeDef* hspi)
  33. {
  34. if(hspi->Instance==SPI1)
  35. {
  36. __SPI1_CLK_DISABLE();
  37. /**SPI1 GPIO Configuration
  38. PA5 ------> SPI1_SCK
  39. PA7 ------> SPI1_MOSI
  40. */
  41. HAL_GPIO_DeInit(GPIOA, GPIO_PIN_5|GPIO_PIN_7);
  42. }
  43. }
mian.c中的初始化如下
  1. int main(void)
  3.    HAL_Init();
  4.    SystemClock_Config();
  5.    MX_GPIO_Init();
  6.    MX_SPI1_Init();
  7.    while (1)
  8.    {
  9.    }
  10. }
下面是SPI写函数。、
  1. void SPI_WriteCmd(uint8_t cmd)
  3.     DC_L;
  4.     HAL_SPI_Transmit(&hspi1, (uint8_t *)cmd,1,100)
  5.     while(HAL_SPI_GetState(&hspi1)==HAL_SPI_STATE_BUSY_TX);
  6. }
  7. void SPI_Write_Data(uint8_t data)
  8. {
  9.     DC_H;
  10.     HAL_SPI_Transmit(&hspi1, (uint8_t *)data,1,100)
  11.     while(HAL_SPI_GetState(&hspi1)==HAL_SPI_STATE_BUSY_TX);
  12. }
那位大神看得出问题在哪里吗
时钟
时钟
SPI配置
SPI配置
管脚配置
管脚配置
1223657347 发表于 2016-5-25 10:28 来自手机 | 显示全部楼层
片选?
xmshao 发表于 2016-5-25 10:48 | 显示全部楼层
极性、相位正确否?
 楼主| wanyisq 发表于 2016-5-25 10:58 | 显示全部楼层
 楼主| wanyisq 发表于 2016-5-25 10:59 | 显示全部楼层
极性、相位正确否?
极性和相位对应芯片文档中的
643757107 发表于 2016-5-25 14:10 | 显示全部楼层
从开始一点一点搞,别想着之前的。
orangebanana 发表于 2016-5-25 14:19 | 显示全部楼层
你看看这个spi的时序是否和你想要的完全一致
LearningASM 发表于 2016-5-26 08:47 | 显示全部楼层
看看中断配置,以前用过DMA+USART的,发现DMA中断默认开了,USART的中断没开,搞得只能发送一次。
个人签名:--By Dr. Heinz Doofenshmirtz
40
