[资料分享] 德州仪器芯片推荐2016-6
4239|33
 楼主| 大秦正声 发表于 2016-6-6 17:56 | 显示全部楼层
描述
The ADS5413 is a low power, 12-bit, 65-MSPS, CMOS pipeline analog-to-digital converter (ADC) that operates from a single 3.3-V supply, while offering the choice of digital output levels from 1.8 V to 3.3 V. The low noise, high linearity, and low clock jitter makes the ADC well suited for high-input frequency sampling applications. On-chip duty cycle adjust circuit allows the use of a non-50% duty cycle. This can be bypassed for applications requiring low jitter or asynchronous sampling. The device can also be clocked with single ended or differential clock, without change in performance. The internal reference can be bypassed to use an external reference to suit the accuracy and low drift requirements of the application.
The device is specified over full temperature range (–40°C to +85°C).
特性
12-Bit Resolution
65-MSPS Maximum Sample Rate
2-Vpp Differential Input Range
3.3-V Single Supply Operation
1.8-V to 3.3-V Output Supply
400-mW Total Power Dissipation
 楼主| 大秦正声 发表于 2016-6-6 18:06 | 显示全部楼层
9.型号OPA656
功能:
宽带单位增益稳定 FET 输入运算放大器
地址:http://www.ti.com.cn/product/cn/opa656
描述
The OPA656 device combines a very wideband, unity-gain stable, voltage-feedback operational amplifier with a FET-input stage to offer an ultra high dynamic-range amplifier for Analog-to-Digital Converter (ADC) buffering and transimpedance applications. Extremely low DC errors give good precision in optical applications.
The high unity-gain stable bandwidth and JFET input allows exceptional performance in high-speed, low-noise integrators.
The high input impedance and low bias current provided by the FET input is supported by the ultra-low 7-nV/√Hz input voltage noise to achieve a very low integrated noise in wideband photodiode transimpedance applications.
Broad transimpedance bandwidths are achievable given the OPA656 device’s high 230-MHz gain bandwidth product. As shown below, a –3-dB bandwidth of 1 MHz is provided even for a high 1-MΩ transimpedance gain from a 47-pF source capacitance.
特性
500 MHz Unity-gain Bandwidth
Low Input Bias Current: 2 pA
Low Offset And Drift: ±250 µV, ±2 µV/°C
Low Distortion: 74-dB SFDR at 5 MHz
High-Output Current: 70 mA
Low Input Voltage Noise: 7 nV/√Hz
 楼主| 大秦正声 发表于 2016-6-7 10:32 | 显示全部楼层
10. 型号:CC1101-Q1
功能:低成本低功耗低于 1GHz 的射频收发器
地址:http://www.ti.com.cn/product/cn/cc1101-q1
 楼主| 大秦正声 发表于 2016-6-7 10:33 | 显示全部楼层
描述
The CC11x1-Q1 device family is designed for very low-power wireless applications. The circuits are mainly intended for the Industrial, Scientific and Medical (ISM) and Short Range Device (SRD) frequency bands at 315 MHz, 433 MHz, 868 MHz, and 915 MHz, but can easily be programmed for operation at other frequencies in the 310-MHz to 348-MHz, 420-MHz to 450-MHz, and 779-MHz to 928-MHz bands.
The devices integrate a highly configurable baseband modem. The modem supports various modulation formats and has a configurable data rate up to 250 kBaud. CC11x1-Q1 family provides extensive hardware support for packet handling, data buffering, burst transmissions, clear channel assessment, link quality indication, and wake-on-radio. The main operating parameters and the 64-byte transmit/receive FIFOs can be controlled via an SPI interface. In a typical system, the devices are used together with a microcontroller and a few additional passive components.
特性
Qualification in Accordance With AEC-Q100 Grade 1
Extended Temperature Range Up To 125°C
Radio-Frequency (RF) Performance High Sensitivity (–114 dBm at 1.2 kBaud, 315 MHz,
1% Packet Error Rate
 楼主| 大秦正声 发表于 2016-6-7 10:38 | 显示全部楼层
11.型号:CC1150
功能:针对低功耗无线应用设计的高度集成多通道射频发送器
地址:http://www.ti.com.cn/product/cn/cc1150
描述
The CC1150 is a true single-chip UHF transmitter designed for very low power wireless applications. The circuit is mainly intended for the ISM (Industrial, Scientific and Medical) and SRD (Short Range Device) frequency bands at 315-, 433-, 868-, and 915-MHz, but can easily be programmed for operation at other frequencies in the 300 to 348 MHz, 400 to 464 MHz and 800 to 928 MHz bands.
The RF transmitter is integrated with a highly configurable baseband modulator. The modulator supports various modulation formats and has a configurable data rate up to 500 kBaud. The CC1150 device provides extensive hardware support for packet handling, data buffering and burst transmissions.
The main operating parameters and the 64-byte transmit FIFO of CC1150 can be controlled via an SPI interface. In a typical system, the CC1150 device will be used together with a microcontroller and a few additional passive components.
CC1150 is part of the SmartRF™ technology platform based on 0.18-µm CMOS technology from Texas Instruments.
特性
Small Size QLP 4-mm × 4-mm Package, 16 Pins
True Single Chip UHF RF Transmitter
Frequency Bands 300 to 348 MHz
400 to 464 MHz
 楼主| 大秦正声 发表于 2016-6-7 10:42 | 显示全部楼层
12.型号:CC430F6137
功能:16 位超低功耗 MCU、32KB 闪存、4KB RAM、CC1101 无线电、AES-128、12 位 ADC、USCI、LCD 驱动器
地址:http://www.ti.com.cn/product/cn/cc430f6137
 楼主| 大秦正声 发表于 2016-6-7 10:43 | 显示全部楼层
相关终端应用
LED 灯具 - 室内 LED 照明
智能仪表 - 水表
智能仪表 - 热量计
智能仪表 - 燃气表
智能仪表:燃气表和水表
能量采集 - 其他
 楼主| 大秦正声 发表于 2016-6-7 10:49 | 显示全部楼层
13.型号:TMS320C6416T
功能:定点数字信号处理器
地址:http://www.ti.com.cn/product/cn/tms320c6416t
 楼主| 大秦正声 发表于 2016-6-7 10:50 | 显示全部楼层
描述
The TMS320C64x™ DSPs (including the TMS320C6414T, TMS320C6415T, and TMS320C6416T devices) are the highest-performance fixed-point DSP generation in the TMS320C6000™ DSP platform. The TMS320C64x™ (C64x™) device is based on the second-generation high-performance, advanced VelociTI™ very-long-instruction-word (VLIW) architecture (VelociTI.2™) developed by Texas Instruments (TI), making these DSPs an excellent choice for wireless infrastructure applications. The C64x™ is a code-compatible member of the C6000™ DSP platform.
With performance of up to 8000 million instructions per second (MIPS) at a clock rate of 1 GHz, the C64x devices offer cost-effective solutions to high-performance DSP programming challenges. The C64x™ DSPs possess the operational flexibility of high-speed controllers and the numerical capability of array processors. The C64x. DSP core processor has 64 general-purpose registers of 32-bit word length and eight highly independent functional units—two multipliers for a 32-bit result and six arithmetic logic units (ALUs)— with VelociTI.2™ extensions. The VelociTI.2™ extensions in the eight functional units include new instructions to accelerate the performance in key applications and extend the parallelism of the VelociTI™ architecture. The C64x can produce four 16-bit multiply-accumulates (MACs) per cycle for a total of 4000 million MACs per second (MMACS), or eight 8-bit MACs per cycle for a total of 8000 MMACS. The C64x DSP also has application-specific hardware logic, on-chip memory, and additional on-chip peripherals similar to the other C6000™ DSP platform devices.
The C6416T device has two high-performance embedded coprocessors [Viterbi Decoder Coprocessor (VCP) and Turbo Decoder Coprocessor (TCP)] that significantly speed up channel-decoding operations on-chip. The VCP operating at CPU clock divided-by-4 can decode over 833 7.95-Kbps adaptive multi-rate (AMR) [K = 9, R = 1/3] voice channels. The VCP supports constraint lengths K = 5, 6, 7, 8, and 9, rates R = 1/2, 1/3, and 1/4, and flexible polynomials, while generating hard decisions or soft decisions. The TCP operating at CPU clock divided-by-2 can decode up to sixty 384-Kbps or ten 2-Mbps turbo encoded channels (assuming 6 iterations). The TCP implements the max*log-map algorithm and is designed to support all polynomials and rates required by Third-Generation Partnership Projects (3GPP and 3GPP2), with fully programmable frame length and turbo interleaver. Decoding parameters such as the number of iterations and stopping criteria are also programmable. Communications between the VCP/TCP and the CPU are carried out through the EDMA controller.
The C64x uses a two-level cache-based architecture and has a powerful and diverse set of peripherals. The Level 1 program cache (L1P) is a 128-Kbit direct mapped cache and the Level 1 data cache (L1D) is a 128-Kbit 2-way set-associative cache. The Level 2 memory/cache (L2) consists of an 8-Mbit memory space that is shared between program and data space. L2 memory can be configured as mapped memory or combinations of cache (up to 256K bytes) and mapped memory. The peripheral set includes three multichannel buffered serial ports (McBSPs); an 8-bit Universal Test and Operations PHY Interface for Asynchronous Transfer Mode (ATM) Slave [UTOPIA Slave] port [C6415T/C6416T only]; three 32-bit general-purpose timers; a user-configurable 16-bit or 32-bit host-port interface (HPI16/HPI32); a peripheral component interconnect (PCI) [C6415T/C6416T only]; a general-purpose input/output port (GPIO) with 16 GPIO pins; and two glueless external memory interfaces (64-bit EMIFA and 16-bit EMIFB), both of which are capable of interfacing to synchronous and asynchronous memories and peripherals.
The C64x has a complete set of development tools which includes: an advanced C compiler with C64x-specific enhancements, an assembly optimizer to simplify programming and scheduling, and a Windows. debugger interface for visibility into source code execution.
TMS320C6000, C64x, and C6000 are trademarks of Texas Instruments.
Windows is a registered trademark of the Microsoft Corporation.
Other trademarks are the property of their respective owners.
Throughout the remainder of this document, the TMS320C6414T, TMS320C6415T, and TMS320C6416T shall be referred to as TMS320C64x or C64x where generic, and where specific, their individual full device part numbers will be used or abbreviated as C6414T, C6415T, or C6416T.
These C64x™ devices have two EMIFs (64-bit EMIFA and 16-bit EMIFB). The prefix "A" in front of a signal name indicates it is an EMIFA signal whereas a prefix "B" in front of a signal name indicates it is an EMIFB signal. Throughout the rest of this document, in generic EMIF areas of discussion, the prefix "A" or "B" may be omitted from the signal name.
特性
Highest-Performance Fixed-Point DSPs 1.67-/1.39-/1.17-/1-ns Instruction Cycle
600-/720-/850-MHz, 1-GHz Clock Rate
Eight 32-Bit Instructions/Cycle
Twenty-Eight Operations/Cycle
4800, 5760, 6800, 8000 MIPS
 楼主| 大秦正声 发表于 2016-6-7 10:54 | 显示全部楼层
14. 型号:TMS320F28335
功能:Delfino 浮点微处理器
地址:http://www.ti.com.cn/product/cn/tms320f28335
 楼主| 大秦正声 发表于 2016-6-7 10:55 | 显示全部楼层
相关终端应用
CPAP 呼吸机
HEV/EV - 逆变器
Ventilator
保护继电器 - 配电馈线保护
变电站控制
太阳能 - 组串式逆变器
数字万用表 (DMM)
机械控制(通过 DeviceNet)
 楼主| 大秦正声 发表于 2016-6-7 10:56 | 显示全部楼层
描述
TMS320F28335,TMS320F28334,TMS320F28332,TMS320F28235,TMS320F28234 和 TMS320F28232 器件,是TMS320C28x™/ Delfino™ DSP/MCU 系列产品成员,它们是针对要求严格的控 制应用的高度集成、高性能解决方案。
特性
高性能静态 CMOS 技术高达 150MHz(6.67ns 周期时间)
1.9V/1.8V内核,3.3V I/O设计
高性能 32 位 CPU(TMS320C28x)IEEE-754 单精度浮点单元(FPU)(只在 F2833x 上提供)
