VISUALDSP++调试问题
5851|4
 楼主| fang8_2 发表于 2010-3-10 14:07 | 显示全部楼层 |阅读模式
[Error ea1011] "command-line":1 'C:\DOCUME~1\': Already saw input filename \LOCALS~1\Temp\includes3.doj.
[Error ea1011] "command-line":1 '\LOCALS~1\Temp\acc0a8c3641000\acc0a8c3641002.s': Already saw input filename \LOCALS~1\Temp\includes3.doj.
[Error ea1011] "command-line":1 '\LOCALS~1\Temp\acc0a8c3641000': Already saw input filename \LOCALS~1\Temp\includes3.doj.
Assembler totals: 3 error(s) and 0 warning(s)
cc3089: fatal error: Assembler failed
[Error ea1072] ".\Porting\uCOSII\driv_CoreTimer_asm.s":20 'includes.h':
Import header file failed to compile.
Please correct the compilation errors and re-assemble.
[Error ea1068] ".\Porting\uCOSII\driv_CoreTimer_asm.s":36 'OS_TCB' not found:
Typedef in .EXTERN directive was not found in .import data.
The typedef definition must be imported via a header file in a .IMPORT directive.
The .IMPORT directive must precede the usage in the .EXTERN directive.
[Error ea1067] ".\Porting\uCOSII\driv_CoreTimer_asm.s":173 offsetof(OS_TCB) unknown:
Symbol was not found in .import data.
The symbol must either be declared locally or
[Error ea1067] ".\Porting\uCOSII\driv_CoreTimer_asm.s":213 offsetof(OS_TCB) unknown:
Previous errors prevent assembly
Assembler totals: 4 error(s) and 0 warning(s)
Tool failed with exit/exception code: 1.
Build was unsuccessful.
请问这是什么问题啊,尤其是前几个错误?
 楼主| fang8_2 发表于 2010-3-10 14:08 | 显示全部楼层
版本是VISUALDSP++5.0,update7的
zibowds 发表于 2010-4-26 21:12 | 显示全部楼层
前几天我也遇到过这个问题,好像还是系统不兼容的问题,建议换XP,vista也好。
sujiechen 发表于 2010-6-28 16:47 | 显示全部楼层
好像是路径的问题,编译器最好装在C盘上,还有工程目录不能有中文目录。
coreduo 发表于 2010-6-29 23:04 | 显示全部楼层
中文目录名的问题
