单片机控制设备,有十几个按键,每按一次按键蜂鸣器就响一声
5736|5
 楼主| lihui567 发表于 2016-8-17 11:11 | 显示全部楼层 |阅读模式
这个程序时怎么控制的,每次检测按键有效后转到蜂鸣器发声函数吗
lpzailushang 发表于 2016-9-6 08:45 | 显示全部楼层
这个比较简单,你是做什么的
 楼主| lihui567 发表于 2016-9-17 16:38 | 显示全部楼层
就是一个按键控制的的小仪器,
billliu66 发表于 2016-9-23 21:59 | 显示全部楼层
我以前设计的一台仪器的程序中有类似的东西,看下这个函数**********************************************************************
Function name: SetParameter()
Parameter:void
Return: void
Description: set test parameter
Version: 0.0
Author:Bill Liu
Last update date: 2015/10
void SetParameter()
        static ui8 spt = 0;    //define first into set parameter interface flag
        static ui8 spn = 1;   // define parameter number variable
        static ui8 i = 0;
        ui8 ktem = 0;   //define keyboard in temp variable
  if(spt == 0)
                Soundbell100ms();
                LCDClearScreen();   // clear screen
                memset(interface.String,0,strlen(interface.String));
                spt = 1;
                LCDDisplayString(1, 0,"Dis:");
                LCDDisplayString(1, 10,"II:");
          LCDDisplayString(2, 0,"Speed:");
          LCDDisplayString(3, 0,"Freq:");
          LCDDisplayString(4, 0,"T_Cycle:");
                Displayfloat(1,4,parameter.Displacement,1);
                DisplayLongInt(1,13,parameter.WCycles);
                DisplayLongInt(2,6,parameter.SpeedL);
                DisplayLongInt(3,5,parameter.SpeedC);
                DisplayLongInt(4,8,parameter.TCycleValue);
                LCDCurPOn(1, 4);
        Delayxms(200,SYSCLOCK);
        ktem = GetKeyboardIn();
        switch(ktem)
                case 0x70: //F1 key down
                        spt = 0;
                        interface.flag = 'P'; //to set accelerate interface
                        break;
                case 0x26: //Arrow(up) key down
                        Soundbell100ms();
                        switch(spn)
                                case 1:
                                  i = 0;
                                        LCDDisplayString(1,4,"     ");
                                        spn = 5;
                                        LCDCurPOn(4, 8);
                                        break;
                                case 2:
                                        i = 0;
                                        LCDDisplayString(1,13,"       ");
                                        spn = 1;
                                        LCDCurPOn(1, 4);
                                        break;
                                case 3:
                                        i = 0;
                                        LCDDisplayString(2,6,"              ");
                                        spn = 2;
                                        LCDCurPOn(1, 13);
                                        break;
                                case 4:
                                        i = 0;
                                        LCDDisplayString(3,5,"               ");
                                        spn = 3;
                                        LCDCurPOn(2, 6);
                                        break;
                                case 5:
                                        i = 0;
                                        LCDDisplayString(4,8,"            ");
                                        spn = 4;
                                        LCDCurPOn(3, 5);
                                        break;
                        break;
                case 0x28: //Arrow(down) key down
                        Soundbell100ms();
                        switch(spn)
                                case 1:
                                  i = 0;
                                        spn = 2;
                                        LCDCurPOn(1, 13);
                                        break;
                                case 2:
                                        i = 0;
                                        spn = 3;
                                        LCDCurPOn(2, 6);
                                        break;
                                case 3:
                                        i = 0;
                                        spn = 4;
                                        LCDCurPOn(3, 5);
                                        break;
                                case 4:
                                        i = 0;
                                        spn = 5;
                                        LCDCurPOn(4, 8);
                                        break;
                                case 5:
                                        i = 0;
                                        spn = 1;
                                        LCDCurPOn(1, 4);
                                        break;
                        break;
                case 0x1B: //Esc key down
                        spt = 0;
                        spn = 1;
                  i = 0;
                  LCDCurOff();
                  GetSpeedL(parameter.SpeedC, parameter.Displacement);
                        if(parameter.SpeedL>7500)
                                parameter.SpeedL = 7500;
                                if(mode.testmode == 1)
                                        parameter.SpeedC = parameter.SpeedL * 30 / parameter.Displacement;
                        InitPCAflag = 0;
                        interface.flag = '2'; //enter new test interface
                        break;
                case 0x6C://Enter key down
                        Soundbell100ms();
                        switch(spn)
                                case 1:
                                        if(interface.String[0] != 0)
                                                parameter.Displacement = atof(interface.String);
                                        if(parameter.Displacement <0.1 )
                                                parameter.Displacement = 0.1;
                                        else if(parameter.Displacement > 100)
                                                parameter.Displacement = 98;
                                  i = 0;
                                        spn = 2;
                                        LCDCurPOn(1, 13);
                                  break;
                                case 2:
                                                parameter.WCycles = atol(interface.String);
                                  i = 0;
                                        if(mode.Warning != 0)
                                                        parameter.Wcounts = parameter.Tcounts + parameter.WCycles;
                                        spn = 3;
                                        LCDCurPOn(2, 6);
                                  break;
                                case 3:
                                                parameter.SpeedL = atol(interface.String);
                                  if(parameter.SpeedL < 23)
                                                parameter.SpeedL = 23;
                                        else if(parameter.SpeedL > 7500)
                                  i = 0;
                                        spn = 4;
                                        LCDCurPOn(3, 5);
                                        break;
                                case 4:
                                                parameter.SpeedC = atol(interface.String);
                                        if(parameter.SpeedC>7200)
                                                parameter.SpeedC = 7200;
                                  i = 0;
                                        spn = 5;
                                        LCDCurPOn(4, 8);
                                        break;
                                case 5:
                                                parameter.TCycleValue = atol(interface.String);
                                        if(parameter.TCycleValue > 1000000)
                                                parameter.TCycleValue = 1000000;
                                  i = 0;
                                        spn = 1;
                                        LCDCurPOn(1, 4);
                                        break;
                        break;
                default:
                        if(ktem > 0x29 && ktem <=0x39 )
                                Soundbell100ms();
                                interface.String[i] = ktem;
                                i++;
                                switch(spn)
                                        case 1:
                                                LCDDisplayString(1,4,interface.String);
                                          break;
                                        case 2:
                                                LCDDisplayString(1,13,interface.String);
                                          break;
                                        case 3:
                                                LCDDisplayString(2,6,interface.String);
                                          break;
                                        case 4:
                                                LCDDisplayString(3,5,interface.String);
                                          break;
                                        case 5:
                                                LCDDisplayString(4,8,interface.String);
                                          break;
                        break;
//End of function SetParameter()
 楼主| lihui567 发表于 2016-9-24 11:50 | 显示全部楼层
这个是不是触摸屏的一块程序啊
liufabing 发表于 2016-10-31 15:28 | 显示全部楼层
什么蜂鸣器,有源?无源?
按键触发后,调用蜂鸣器使能函数就好(同时启动蜂鸣器输出计时,100毫秒后关闭蜂鸣器就好).
认证:意法半导体(中国)投资有限公司
54
