[STM32F1] spi3无波形输出,已开afio,禁用jtag。
1352|6
 楼主| any012 发表于 2016-8-24 16:10 | 显示全部楼层 |阅读模式
实在是找不出问题,只好厚着脸皮又来发求助帖了。
现象是卡在spi发送函数里的判断是否发送完成这里:
while(SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_TXE) == RESET);
到这里貌似司循环了。
  1. void SPI3_Init(void)
  3.         GPIO_InitTypeDef GPIO_InitStructure;
  4.         SPI_InitTypeDef SPI_InitStructure;
  5.
  6.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
  7.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
  8.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
  9.
  10.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_5;
  11.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  12.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  13.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  14.
  15.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  16.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  17.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  18.
  19.         SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  20.         SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  21.         SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  22.         SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  23.         SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  24.         SPI_InitStructure.SPI_NSS =SPI_NSS_Soft;
  25.         SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
  26.         SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  27.         SPI_InitStructure.SPI_CRCPolynomial = 7;
  28.         SPI_Init(SPI3, &SPI_InitStructure);
  29.         SPI_Cmd(SPI3, ENABLE);
  30. }
  1. u8 SPI3_ReadWriteByte(u8 TxData)
  3.         u8 retry = 0;
  4.         while(SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_TXE) == RESET);        //µÈ´ý·¢ËÍÈ¥¿Õ
  5.         {
  6.                 retry++;
  7.                 if(retry > 200)
  8.                         return 0;
  9.         }
  10.         SPI_I2S_SendData(SPI3, TxData);                        //ͨ¹ýÍâÉèSPIx·¢ËÍÒ»¸öÊý¾Ý
  11.         retry = 0;
  12.         while(SPI_I2S_GetFlagStatus(SPI3, SPI_I2S_FLAG_RXNE) == RESET);        //µÈ´ý½ÓÊÕÍêÒ»¸öbyte
  13.         {
  14.                 retry++;
  15.                 if(retry > 200)
  16.                         return 0;
  17.         }
  18.         return SPI_I2S_ReceiveData(SPI3);                //·µ»ØÍ¨¹ýSPIx×î½ü½ÓÊܵÄÊý¾Ý
  19. }
SPI3测试.zip
309.24 KB, 下载次数: 1
dongnanxibei 发表于 2016-8-24 18:26 | 显示全部楼层
https://bbs.21ic.com/icview-1372436-1-1.html
参考一下这个人的配置。肯定就有波形了,然后再找其他问题。
mmuuss586 发表于 2016-8-24 18:53 | 显示全部楼层
参考官方的例程看下,应该是SPI初始化部分问题;
初始化不对,发送数据是会死机的;
 楼主| any012 发表于 2016-8-25 10:43 | 显示全部楼层
看得眼都花了,也看不出问题在哪...
 楼主| any012 发表于 2016-8-26 15:36 | 显示全部楼层
找到问题了,焊的是STM32F103VB,没有SPI3,现在在尝试将SPI1重映射到PB3,PB4,PB5.
 楼主| any012 发表于 2016-8-29 08:58 | 显示全部楼层
现在是将SPI1重映射到PB3,PB4,PB5上。
程序不会再卡在等待SPI发送完成这里了。
SCLK有波形,但MOSI没波形。
  1. void SPI1_Init(void)
  5.
  6.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO | RCC_APB2Periph_SPI1, ENABLE);
  7. //        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
  8.         GPIO_PinRemapConfig(GPIO_Remap_SPI1, ENABLE);
  9.
  14.
  18.
  28.         SPI_Init(SPI1, &SPI_InitStructure);
  29.         SPI_Cmd(SPI1, ENABLE);
  30. }
 楼主| any012 发表于 2016-8-29 10:16 | 显示全部楼层
测试到管脚,有波形,是我的问题,之前测的是光耦之后的位置。
现在SPI算是正常了。
