求助
600|4
 楼主| 想做李白 发表于 2016-9-16 21:13 | 显示全部楼层 |阅读模式
IO, pi, gp, GPIO, ST
#include "pbdata.h"
#include "ds1302.h"
#include "systick.h"
/////1 3 5 7 9 B D0x81,0x83,0x85,0x87,0x89,0x8b,0x8d
uint8_t read[]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};//¶ÁÃë¡¢·Ö¡¢Ê±¡¢ÈÕ¡¢Ô¡¢ÖÜ¡¢ÄêµÄ¼Ä´æÆ÷µØÖ·
uint8_t write[]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c};//дÃë¡¢·Ö¡¢Ê±¡¢ÈÕ¡¢Ô¡¢ÖÜ¡¢ÄêµÄ¼Ä´æÆ÷µØÖ·
/*PA4.6ΪÊä³ö*/
/*PA5ÅäÖÃΪ¿ªÂ©Ä£Ê½£¬´ËģʽÏÂÄܹ»ÊµÏÖÕæÕýµÄË«ÏòIO¿Ú*/
void ds1302_GPIO_Configuration(void)
        GPIO_InitTypeDef GPIO_InitStruct;
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStruct.GPIO_Pin = ds1302clk|ds1302rst;
        GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA, &GPIO_InitStruct);
        GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_OD;
        GPIO_InitStruct.GPIO_Pin = ds1302dat;
void write_1302byte(uint8_t dat)//дһ¸ö×Ö½ÚµÄÊý¾ÝsckÉÏÉýÑØÐ´Êý¾Ý
        uint8_t i=0;
        GPIO_ResetBits(GPIOA,ds1302clk);
        //ds1302clk=0;
    delay_us(2);//ÑÓʱ´óÔ¼2us
        for(i=0;i<8;i++)
                    //ds1302clk=0;
                        if(dat&0x01)
                        GPIO_SetBits(GPIOA,ds1302dat);
                        else
                        GPIO_ResetBits(GPIOA,ds1302dat);
                         //ds1302dat=(dat&0x01);
                         delay_us(2);
                        GPIO_SetBits(GPIOA,ds1302clk);
                         //ds1302clk=1;
                         dat>>=1;
                         delay_us(1);
uint8_t read_1302(uint8_t add)//¶ÁÊý¾Ý
        uint8_t i=0,dat1=0x00;
        GPIO_ResetBits(GPIOA,ds1302rst);
        //ds1302rst=0;
        //ds1302clk=0;
        delay_us(2);//ÂÔ΢ÑÓʱ2us
        GPIO_SetBits(GPIOA,ds1302rst);
        //ds1302rst=1;
        delay_us(3);//ʱ¼äÒª´óÔ¼3us
        write_1302byte(add);//ÏÈд¼Ä´æÆ÷µÄµØÖ·
        for(i=0;i<8;i++)
                //ds1302clk=1;
                dat1>>=1;
                //ds1302clk=0;//À­µÍʱÖÓÏߣ¬ÒÔ±ãÓÚÊý¾ÝµÄ¶ÁÈë
                if(GPIO_ReadInputDataBit(GPIOA,ds1302dat)==1)//Êý¾ÝÏß´ËʱΪ¸ßµçƽ
                {dat1=dat1|0x80;}
          delay_us(1);
          //ds1302rst=0;
          return dat1;
void write_1302(uint8_t add,uint8_t dat)//ÏòÖ¸¶¨¼Ä´æÆ÷дÈëÒ»¸ö×Ö½ÚµÄÊý¾Ý
        //ds1302rst=0;
        //ds1302clk=0;
        delay_us(1);//ÂÔ΢ÑÓʱ
        //ds1302rst=1;
        delay_us(2);//ʱ¼ä´óÔ¼2us
        write_1302byte(dat);
        //ds1302clk=0;
        //ds1302rst=0;
        delay_us(1);
void ds1302_init(uint8_t *write,uint8_t *time)//³õʼ»¯1302
        uint8_t i=0,j=0;
        write_1302(0x8e,0x00);//È¥³ýд±£»¤
                for(i=0;i<7;i++)//תBCDÂë
                j=time[i]%10;//¸öλÊý²¿·Ö
                time[i]=(time[i]/10)*16+j;
        for(i=0;i<7;i++)//½øÐжÔʱ
                write_1302(write[i],time[i]);
    write_1302(0x8e,0x80);//¼Óд±£»¤
uint8_t g[7],time[7];
void ds1302_data(uint8_t *read)//´¦ÀíÊý¾Ý²¢Í¨¹ý´®¿Ú´òÓ¡
        uint8_t h,j,k,fen1,fen0;
        uint8_t i=0;
        static uint8_t s=1;
        for(i=0;i<7;i++)
                             time[i]=read_1302(read[i]);
                            }//¶ÁÊý¾ÝÒѾ­Íê³É
                                                fen1=time[0]/10;
                                          fen0=time[0]%10;
                            for(i=0;i<7;i++)
        g[i]=time[i]%16;//Ãë¸öλÊý¾Ý           16
                                                 time[i]=time[i]/16;//ÃëʮλÊý¾Ý           16
                                    //´ËʱÒÑת»»³É10½øÖÆÊý£¬g[i]ÀïÃæ´æ·ÅµÄÊÇÃë·ÖʱÈÕÔÂÖÜÄêµÄ¸÷¸öλÊý¾Ý
                                    //¶ø´ËʱµÄtime¡¾i¡¿ÀïÃæ´æ·ÅµÄÔòÊÇÃë·ÖʱÈÕÔÂÖÜÄêµÄʮλÊý¾Ý
                if(s!=(time[0]+g[0]))
          printf("20%d%dÄê%d%dÔÂ%d%dÈÕ%d%d:%d%d:%d%d ÐÇÆÚ%d\r\n",
          time[6],g[6],time[4],g[4],time[3],g[3],time[2],g[2],time[1],g[1],time[0],g[0],g[5]);
          s=time[0]+g[0];
                h=time[2];
                j=g[2];
                k=h+j;                                                           //56
                         show_num(70+1*20,251,time[2],RED,WHITE);
       show_num(70+2*20,251,g[2],RED,WHITE);
             show_num(70+4*20,251,time[1],RED,WHITE);
       show_num(70+5*20,251,g[1],RED,WHITE);
                    show_num(70+7*20,251,fen1,RED,WHITE);                      //time[0]
       show_num(70+8*20,251,fen0,RED,WHITE);                         //g[0]
                if((k<=9)){setPWM(600, 1000, 100,100);}
xyz549040622 发表于 2016-9-17 10:27 | 显示全部楼层
没有说明问题,求助什么呢?
dirtwillfly 发表于 2016-9-18 08:46 | 显示全部楼层
有什么问题?
yichunshan 发表于 2016-9-18 09:23 | 显示全部楼层
楼主说的有点道理,但是不完全对。
因为,,,,也许,,,,,所以,,,,,然而,,,,,或者,,,,,大概,,,,,,,一定,,,,,
总之,基本就是这样的
长的帅怪我落 发表于 2016-9-18 15:56 | 显示全部楼层
楼上说的很对,因为。。。而且。。。虽然。。。但是。。。综上所述。。。应该就是这样
