TI TMS320F2806 ECAN自测模式,发送确认位的TA不置位是怎么回事?
// TI File $Revision: /main/4 $ // Checkin $Date: December 3, 2004 13:58:42 $ //########################################################################### // // FILE: Example_280xECanBack2Back.c // // TITLE: DSP280x eCAN Back-to-back transmission and reception in // SELF-TEST mode // // ASSUMPTIONS: // // This program requires the DSP280x header files. // // This progrm uses the peripheral's self test mode. // Other then boot mode configuration, no other hardware configuration // is required. // // As supplied, this project is configured for "boot to SARAM" // operation. The 280x Boot Mode table is shown below. // For information on configuring the boot mode of an eZdsp, // please refer to the documentation included with the eZdsp, // // Boot GPIO18 GPIO29 GPIO34 // Mode SPICLKA SCITXDA // SCITXB // ------------------------------------- // Flash 1 1 1 // SCI-A 1 1 0 // SPI-A 1 0 1 // I2C-A 1 0 0 // ECAN-A 0 1 1 // SARAM 0 1 0 <- "boot to SARAM" // OTP 0 0 1 // I/0 0 0 0 // // // // DESCRIPTION: // // This test transmits data back-to-back at high speed without // stopping. // The received data is verified. Any error is flagged. // MBX0 transmits to MBX16, MBX1 transmits to MBX17 and so on.... // This program illustrates the use of self-test mode // //########################################################################### // Original Author H.J. // // $TI Release: DSP280x V1.30 $ // $Release Date: February 10, 2006 $ //###########################################################################
#include "DSP280x_Device.h" // DSP280x Headerfile Include File #include "DSP280x_Examples.h" // DSP280x Examples Include File
// Prototype statements for functions found within this file. void mailbox_check(int32 T1, int32 T2, int32 T3); void mailbox_read(int16 i);
// Global variable for this example Uint32 ErrorCount; Uint32 PassCount; Uint32 MessageReceivedCount;
Uint32 TestMbox1 = 0; Uint32 TestMbox2 = 0; Uint32 TestMbox3 = 0;
void main(void) {
Uint16 j;
// eCAN control registers require read/write access using 32-bits. Thus we // will create a set of shadow registers for this example. These shadow // registers will be used to make sure the access is 32-bits and not 16. struct ECAN_REGS ECanaShadow;
// Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP280x_SysCtrl.c file. InitSysCtrl();
// Step 2. Initalize GPIO: // This example function is found in the DSP280x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // InitGpio(); // Skipped for this example
// For this example, configure CAN pins using GPIO regs here // This function is found in DSP280x_ECan.c InitECanGpio();
// Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT;
// Initialize PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP280x_PieCtrl.c file. InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP280x_DefaultIsr.c. // This function is found in DSP280x_PieVect.c. InitPieVectTable();
// Step 4. Initialize all the Device Peripherals: // This function is found in DSP280x_InitPeripherals.c // InitPeripherals(); // Not required for this example
// Step 5. User specific code, enable interrupts:
MessageReceivedCount = 0; ErrorCount = 0; PassCount = 0;
//InitECana(); // eCAN control registers require 32-bit access. // If you want to write to a single bit, the compiler may break this // access into a 16-bit access. One solution, that is presented here, // is to use a shadow register to force the 32-bit access.
// Read the entire register into a shadow register. This access // will be 32-bits. Change the desired bit and copy the value back // to the eCAN register with a 32-bit write.
// Configure the eCAN RX and TX pins for eCAN transmissions EALLOW; ECanaShadow.CANTIOC.all = ECanaRegs.CANTIOC.all; ECanaShadow.CANTIOC.bit.TXFUNC = 1; ECanaRegs.CANTIOC.all = ECanaShadow.CANTIOC.all;
ECanaShadow.CANRIOC.all = ECanaRegs.CANRIOC.all; ECanaShadow.CANRIOC.bit.RXFUNC = 1; ECanaRegs.CANRIOC.all = ECanaShadow.CANRIOC.all; EDIS;
// Disable all Mailboxes // Since this write is to the entire register (instead of a bit // field) a shadow register is not required. ECanaRegs.CANME.all = 0;
ECanaShadow.CANTRR.all = ECanaRegs.CANTRR.all; ECanaShadow.CANTRR.all=0xFF;
ECanaRegs.CANTRR.all = ECanaShadow.CANTRR.all;
// Mailboxs can be written to 16-bits or 32-bits at a time // Write to the MSGID field of TRANSMIT mailboxes MBOX0 - 15 ECanaMboxes.MBOX0.MSGID.all = 0x9555AAA0; ECanaMboxes.MBOX1.MSGID.all = 0x9555AAA1; ECanaMboxes.MBOX2.MSGID.all = 0x9555AAA2; ECanaMboxes.MBOX3.MSGID.all = 0x9555AAA3; ECanaMboxes.MBOX4.MSGID.all = 0x9555AAA4; ECanaMboxes.MBOX5.MSGID.all = 0x9555AAA5; ECanaMboxes.MBOX6.MSGID.all = 0x9555AAA6; ECanaMboxes.MBOX7.MSGID.all = 0x9555AAA7; ECanaMboxes.MBOX8.MSGID.all = 0x9555AAA8; ECanaMboxes.MBOX9.MSGID.all = 0x9555AAA9; ECanaMboxes.MBOX10.MSGID.all = 0x9555AAAA; ECanaMboxes.MBOX11.MSGID.all = 0x9555AAAB; ECanaMboxes.MBOX12.MSGID.all = 0x9555AAAC; ECanaMboxes.MBOX13.MSGID.all = 0x9555AAAD; ECanaMboxes.MBOX14.MSGID.all = 0x9555AAAE; ECanaMboxes.MBOX15.MSGID.all = 0x9555AAAF;
// Write to the MSGID field of RECEIVE mailboxes MBOX16 - 31 ECanaMboxes.MBOX16.MSGID.all = 0x9555AAA0; ECanaMboxes.MBOX17.MSGID.all = 0x9555AAA1; ECanaMboxes.MBOX18.MSGID.all = 0x9555AAA2; ECanaMboxes.MBOX19.MSGID.all = 0x9555AAA3; ECanaMboxes.MBOX20.MSGID.all = 0x9555AAA4; ECanaMboxes.MBOX21.MSGID.all = 0x9555AAA5; ECanaMboxes.MBOX22.MSGID.all = 0x9555AAA6; ECanaMboxes.MBOX23.MSGID.all = 0x9555AAA7; ECanaMboxes.MBOX24.MSGID.all = 0x9555AAA8; ECanaMboxes.MBOX25.MSGID.all = 0x9555AAA9; ECanaMboxes.MBOX26.MSGID.all = 0x9555AAAA; ECanaMboxes.MBOX27.MSGID.all = 0x9555AAAB; ECanaMboxes.MBOX28.MSGID.all = 0x9555AAAC; ECanaMboxes.MBOX29.MSGID.all = 0x9555AAAD; ECanaMboxes.MBOX30.MSGID.all = 0x9555AAAE; ECanaMboxes.MBOX31.MSGID.all = 0x9555AAAF;
