/* Function name: CLK_Init */
/* Descriptions: 时钟初始化函数 */
/* input parameters: 无 */
/* output parameters: 无 */
/* Returned value: 无 */
static void CLK_Init(void)
CLK_DeInit();
CLK_MasterPrescalerConfig(CLK_MasterPrescaler_HSIDiv1);
/* Function name: GPIO_Init_my */
/* Descriptions: IO初始化函数 */
static void GPIO_Init_my(void)
GPIO_Init(GPIOA,GPIO_Pin_2|GPIO_Pin_3,GPIO_Mode_Out_PP_Low_Slow); //悬空未用
GPIO_Init(GPIOB,POWER_BD,GPIO_Mode_Out_PP_Low_Slow); //默认断电
GPIO_Init(GPIOB,POWER_BT,GPIO_Mode_Out_PP_Low_Slow); //取消未用
GPIO_Init(GPIOB,MSEL,GPIO_Mode_Out_PP_Low_Slow); //取消未用,Wifi模式选择
GPIO_Init(GPIOB,NRESET,GPIO_Mode_Out_PP_Low_Slow); //取消未用,Wifi复位
GPIO_Init(GPIOB,BD_NRESET,GPIO_Mode_Out_PP_Low_Slow); //北斗复位信号,默认复位状态
GPIO_Init(GPIOB,RESETB,GPIO_Mode_Out_PP_Low_Slow); //取消未用,蓝牙复位
GPIO_Init(GPIOB,SDA2|SCL2,GPIO_Mode_Out_OD_HiZ_Slow); //电池电量用
GPIO_Init(GPIOC,SDA|SCL,GPIO_Mode_Out_OD_HiZ_Slow); //温度传感器
GPIO_Init(GPIOC,GPIO_Pin_2,GPIO_Mode_In_PU_No_IT); //串口接收
GPIO_Init(GPIOC,GPIO_Pin_3,GPIO_Mode_Out_PP_High_Slow); //串口发送
GPIO_Init(GPIOD,GPIO_Pin_All,GPIO_Mode_Out_PP_Low_Slow); //取消未用,Wifi供电
/* Function name: USART_Config */
/* Descriptions: 串口初始化函数 */
static void USART_Config(void)
CLK_PeripheralClockConfig(CLK_Peripheral_USART, ENABLE);
USART_DeInit();
USART_Init((uint32_t)9600, USART_WordLength_8D, USART_StopBits_1,
USART_Parity_No, (USART_Mode_TypeDef)(USART_Mode_Rx | USART_Mode_Tx));
USART_Cmd(ENABLE);
USART_ITConfig(USART_IT_TXE,DISABLE);//关闭串口发送中断
USART_ITConfig(USART_IT_TC,DISABLE);//关闭串口发送完中断
USART_ITConfig(USART_IT_RXNE,ENABLE);//打开串口接收中断
/* Function name: UART1_SendByte */
/* Descriptions: 发送单字节 */
/* input parameters: data:待发送数据 */
void USART_SendByte(uint8_t data)
USART_SendData8((unsigned char)data);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(USART_FLAG_TXE) == RESET);
/* Function name: UART1_SendString */
/* Descriptions: 发送字符串 */
void USART_SendString(uint8_t* Data,uint16_t len)
uint16_t i=0;
for(;i<len;i++)
USART_SendByte(Data);
/* Function name: Delay_ms */
/* Descriptions: 延时函数 */
/* input parameters: 延时时间 */
void Delay_ms(uint32_t nCount)
uint16_t i=0,j=0;;
for(i=0;i<nCount;i++){
for(j=0;j<1100;j++){
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval : None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/*********************************END OF FILE**********************************/
