[STM32F1] 2.4寸TFT驱动求助,不知道是什么驱动IC。
1651|2
 楼主| ss1969 发表于 2016-11-7 10:58 | 显示全部楼层 |阅读模式
小弟有个板子要搞一搞。。
2.4寸的lcd,标识型号FPC-T24QT10T2(搜不到。。。。)
37Pin,不带触摸(有上件位置没上),排除掉已知的pin之后,
剩下的pin非常像是FSMC驱动方式,包括NE1、D0~D15,NOE,NWE,A16都在,剩下一根我猜是reset
然后用确定没问题的(开发板可跑可驱动lcd)代码去试试
读出ID是0x0075
这就糊涂了 ,感觉是读错了,但是完全不知道怎么继续
贴下fsmc初始化和读ID代码:
  1. void MX_FSMC_Init(void)
  3.     FSMC_NORSRAM_TimingTypeDef Timing;
  4.
  5.     /** Perform the SRAM1 memory initialization sequence
  6.     */
  7.     hsram1.Instance = FSMC_NORSRAM_DEVICE;
  8.     hsram1.Extended = FSMC_NORSRAM_EXTENDED_DEVICE;
  9.     /* hsram1.Init */
  10.     hsram1.Init.NSBank = FSMC_NORSRAM_BANK1;
  11.     hsram1.Init.DataAddressMux = FSMC_DATA_ADDRESS_MUX_DISABLE;
  12.     hsram1.Init.MemoryType = FSMC_MEMORY_TYPE_SRAM;
  13.     hsram1.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_16;
  14.     hsram1.Init.BurstAccessMode = FSMC_BURST_ACCESS_MODE_DISABLE;
  15.     hsram1.Init.WaitSignalPolarity = FSMC_WAIT_SIGNAL_POLARITY_LOW;
  16.     hsram1.Init.WrapMode = FSMC_WRAP_MODE_DISABLE;
  17.     hsram1.Init.WaitSignalActive = FSMC_WAIT_TIMING_BEFORE_WS;
  18.     hsram1.Init.WriteOperation = FSMC_WRITE_OPERATION_ENABLE;
  19.     hsram1.Init.WaitSignal = FSMC_WAIT_SIGNAL_DISABLE;
  20.     hsram1.Init.ExtendedMode = FSMC_EXTENDED_MODE_DISABLE;
  21.     hsram1.Init.AsynchronousWait = FSMC_ASYNCHRONOUS_WAIT_DISABLE;
  22.     hsram1.Init.WriteBurst = FSMC_WRITE_BURST_DISABLE;
  23.     /* Timing */
  24.     #if 0
  25.     Timing.AddressSetupTime = 2;
  26.     Timing.AddressHoldTime = 15;
  27.     Timing.DataSetupTime = 5;
  28.     Timing.BusTurnAroundDuration = 0;
  29.     Timing.CLKDivision = 16;
  30.     Timing.DataLatency = 17;
  31.     Timing.AccessMode = FSMC_ACCESS_MODE_A;
  32.     #else
  33.
  34.     Timing.AddressSetupTime = 10;
  35.     Timing.AddressHoldTime = 10;
  36.     Timing.DataSetupTime = 15;
  37.     Timing.BusTurnAroundDuration = 10;
  38.     Timing.CLKDivision = 16;
  39.     Timing.DataLatency = 17;
  40.     Timing.AccessMode = FSMC_ACCESS_MODE_B;
  41.     #endif
  42.     /* ExtTiming */
  43.
  44.     if (HAL_SRAM_Init(&hsram1, &Timing, NULL) != HAL_OK)
  45.     {
  46.         Error_Handler();
  47.     }
  48.
  49.     /** Disconnect NADV
  50.     */
  51.
  52.     __HAL_AFIO_FSMCNADV_DISCONNECTED();
  53.
  54. }
读ID代码
  1. uint16_t lcdReadReg(uint8_t LCD_Reg)
  3.     uint16_t d;
  4.
  5.     *(__IO uint16_t*)(Bank1_LCD_C) = LCD_Reg;
  6.     d = *(__IO uint16_t*)(Bank1_LCD_D);
  7.
  8.     return d;
  9. }
  10.
  11. void LCD_Init(void)
  12. {
  13.     lcdReset();
  14.
  15. //  lcdWriteCmd(0x00, 0x0001);
  16.     HAL_Delay(50); // delay 50 ms
  17.     DeviceCode = lcdReadReg(0x0000);
  18.     xprintf("LCD ID:0x%04x\r\n", DeviceCode); //打印LCD ID
  19. 。。。
  20. }
airwill 发表于 2016-11-7 19:42 | 显示全部楼层
楼主不错啊, 很仔细, 引脚功能都猜出来了, 支持一下
如果只是玩玩, 那就用着编程玩玩吧
找专用做液晶的商家, 多找几家, 或许会遇到知道的人.
 楼主| ss1969 发表于 2016-11-7 20:01 | 显示全部楼层
如果只是玩玩, 那就用着编程玩玩吧
找专用做液晶的商家 ...
基本上确认是FSMC没错,然后用IO模拟了一下FSMC,读出的id也是0x0075
看过了好几个qvga的驱动,似乎都是先读id的,不知道有没有特例
因为某些你知我知的原因,只能用这个板子,不然的话,哎,换新的tft早就搞定啦!
