淘宝有商家销售 CC1310 DIE REV A版本的模块,请大家留个心眼。
1062|1
 楼主| crazybee 发表于 2016-11-24 13:15 | 显示全部楼层 |阅读模式
Note that current die Rev A material will still be limited to 863-930 MHz  only.
2) Removed limitation on frequency bands supported in CC1310. New frequency bands are supported for the CC1310 from die Rev B and onwards, starting with support for frequency bands in the 430-510 MHz range. This will allow customers to use the same device in a number of markets worldwide. Note that current die Rev A material will still be limited to 863-930 MHz only. SmartRF Studio 2.4.3 or later will detect die Rev A devices and issue an appropriate warning as to the applicable frequency range. Please remember to update SmartRF Studio accordingly.
这是TI公司公开声明。  我想DIE REV A版本有缺陷。
淘宝上追加的评论,商家居然可以删除。
dirtwillfly 发表于 2016-11-24 16:04 | 显示全部楼层
感谢分享
个人签名:MSN: ihuangwh@foxmail.com
149
