一款新奇怪的新电源
2025|0
 楼主| ydxuwen 发表于 2008-7-12 13:18 | 显示全部楼层 |阅读模式
我们最近拿到一电源样机,<br />面板指标:input&nbsp;60-250ACV&nbsp;&nbsp;&nbsp;(不同于常规的85-265VAC)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Output&nbsp;DC&nbsp;&nbsp;1.5-22VDC&nbsp;&nbsp;2A<br />液晶显示,显示有:<br />&nbsp;&nbsp;SPEED,&nbsp;FOLLOW&nbsp;THROUGH,&nbsp;DUTY&nbsp;CYCLE,&nbsp;and&nbsp;VOLTAGE<br />没理解其意思,敬请各位高手给以指点<br />下面是网上查的信息:<br />The&nbsp;full&nbsp;turning&nbsp;power&nbsp;of&nbsp;the&nbsp;Power&nbsp;allows&nbsp;you&nbsp;to&nbsp;deliver&nbsp;a&nbsp;clean&nbsp;and&nbsp;stable&nbsp;voltage.&nbsp;<br />The&nbsp;full&nbsp;switching&nbsp;regulated&nbsp;power&nbsp;supply&nbsp;delivers&nbsp;the&nbsp;ability&nbsp;to&nbsp;fine&nbsp;tune&nbsp;your&nbsp;machine&nbsp;to&nbsp;the&nbsp;perfect&nbsp;setting.&nbsp;<br />The&nbsp;LCD&nbsp;Meter&nbsp;accurately,&nbsp;clearly,&nbsp;continuously&nbsp;displays&nbsp;<br />the&nbsp;four&nbsp;major&nbsp;electronic&nbsp;measurements&nbsp;from&nbsp;a&nbsp;tattoo&nbsp;machine:&nbsp;<br />SPEED,&nbsp;FOLLOW&nbsp;THROUGH,&nbsp;DUTY&nbsp;CYCLE,&nbsp;and&nbsp;VOLTAGE.&nbsp;<br />Instructions&nbsp;included.<br /><br />It&nbsp;will&nbsp;run&nbsp;any&nbsp;machine&nbsp;better&nbsp;than&nbsp;most&nbsp;other&nbsp;power&nbsp;supplies&nbsp;while&nbsp;the&nbsp;blue&nbsp;back-lit&nbsp;LCD&nbsp;clearly&nbsp;and&nbsp;accurately&nbsp;displays&nbsp;the&nbsp;four&nbsp;major&nbsp;electronic&nbsp;measurements&nbsp;from&nbsp;any&nbsp;machine.<br /><br />The&nbsp;speed&nbsp;of&nbsp;the&nbsp;machine&nbsp;is&nbsp;prominently&nbsp;displayed.&nbsp;Machine&nbsp;speed&nbsp;is&nbsp;the&nbsp;most&nbsp;important&nbsp;factor&nbsp;in&nbsp;how&nbsp;a&nbsp;machine&nbsp;works&nbsp;for&nbsp;you.&nbsp;Even&nbsp;a&nbsp;change&nbsp;of&nbsp;five&nbsp;cycles&nbsp;per&nbsp;second&nbsp;will&nbsp;change&nbsp;machine&nbsp;function&nbsp;-&nbsp;but&nbsp;is&nbsp;undetectable&nbsp;without&nbsp;a&nbsp;meter.<br /><br />The&nbsp;duty&nbsp;cycle&nbsp;display&nbsp;shows&nbsp;how&nbsp;much&nbsp;back&nbsp;spring&nbsp;pressure&nbsp;your&nbsp;machine&nbsp;has&nbsp;in&nbsp;relation&nbsp;to&nbsp;front&nbsp;spring&nbsp;hardness.&nbsp;This&nbsp;is&nbsp;vital&nbsp;to&nbsp;know&nbsp;when&nbsp;you&nbsp;are&nbsp;tuning&nbsp;a&nbsp;machine&nbsp;and&nbsp;will&nbsp;let&nbsp;you&nbsp;see&nbsp;at&nbsp;a&nbsp;glance&nbsp;if&nbsp;you&nbsp;need&nbsp;to&nbsp;change&nbsp;springs.<br /><br />The&nbsp;voltage&nbsp;is&nbsp;displayed&nbsp;to&nbsp;two&nbsp;decimal&nbsp;places.&nbsp;The&nbsp;follow&nbsp;through&nbsp;display&nbsp;shows&nbsp;how&nbsp;cleanly&nbsp;the&nbsp;contact&nbsp;points&nbsp;are&nbsp;opening&nbsp;and&nbsp;closing.&nbsp;The&nbsp;Cyclone&nbsp;Power&nbsp;Supply&nbsp;delivers&nbsp;clean,&nbsp;stable&nbsp;power&nbsp;with&nbsp;full&nbsp;current&nbsp;and&nbsp;thermal&nbsp;overload&nbsp;protection&nbsp;through&nbsp;a&nbsp;precision&nbsp;ten-turn&nbsp;voltage&nbsp;control.<br /><br />
