[Cortex-M0技术交流] STM32F030f4p6汇编ADC
2427|3
 楼主| yjmwxwx 发表于 2016-12-5 00:05 | 显示全部楼层 |阅读模式
简单玩一下ADC,胡乱初始化一下,测v refint 电压。
DR
  1.          .thumb
  2.          .syntax unified
  3. .section .data
  4.                 .equ STACKINIT,          0x20000300
  5. .section .text
  6. vectors:
  7.         .word STACKINIT
  8.         .word _start + 1
  9.         .word _nmi_handler + 1
  10.         .word _hard_fault  + 1
  11.         .word _memory_fault + 1
  12.         .word _bus_fault + 1
  13.         .word _usage_fault + 1
  14. _start:
  15. shizhong:
  16.         ldr r0, = 0x40021000 [url=home.php?mod=space&uid=72445]@[/url] rcc_cr
  17.         ldr r1, = 0x15683
  18.         str r1, [r0]
  19. gsszbz:
  20.         ldr r2, [r0]
  21.         ldr r1, = 0x20000
  22.         tst r1, r2           @HSE时钟标志位
  23.         bne rccchushihua
  24.         b gsszbz
  25. rccchushihua:
  26.         ldr r0, = 0x40022000   @FLASH访问控制
  27.         movs r1, # 0x32
  28.         str r1, [r0]           @FLASH缓冲 缓冲开启
  29.         ldr r0, = 0x40021004
  30.         ldr r1, = 0x110000    [url=home.php?mod=space&uid=72445]@[/url] HSE-PLL-6倍频
  31.         str r1, [r0]
  32.         ldr r0, = 0x40021000
  33.         ldr r1, = 0x1035683     @ PLL开
  34.         str r1, [r0]
  35. chaxun:
  36.         ldr r2, [r0]
  37.         ldr r1, = 0x2000000     @ PLL锁定标志位
  38.         tst r1, r2
  39.         bne rccgg               @ 等待PLL锁定
  40.         b chaxun
  41. rccgg:
  42.         ldr r1, = 0x11000a      @ PLL作为系统时钟
  43.         str r1, [r0, # 0x04]
  44.
  45.         @0x34时钟控制寄存器 2 (RCC_CR2)
  46.         movs r1, # 0x01
  47.         str r1, [r0, # 0x34]  @ HSI开14M时钟
  48. dengdai14mshizhongwending:
  49.         ldr r1, [r0, # 0x34]
  50.         lsls r1, r1, # 30     @ 左移30位
  51.         bpl dengdai14mshizhongwending  @ 等待14M时钟稳定
  52.
  53. waisheshizhong:         @ 外设时钟
  54.         @+0x18外设时钟使能寄存器 (RCC_APB2ENR)
  55.         @ (0)SYSCFGEN(9)ADC(11)TIM1(12)SPI(14)USART1
  56.         @ (16)TIM15 (17)TIM6(18)TIM17 (22)DBGMCU
  57.         ldr r1, = 0x200
  58.         str r1, [r0, # 0x18]
  59.
  60.         ldr r0, = 0x40021014    @ AHB外部时钟
  61.         ldr r1, = 0x60014       @ 开时钟
  62.         str r1, [r0]
  63.         @ DMA(0)SRAM(2)FLITF(4)CRC(6)PA(17)
  64.         @PB(18)PC(19)PD(20)PF(22)TSCEN(24)
  65.         ldr r0, = 0x4002101c
  66.         ldr r1, = 0x132
  67.         str r1, [r0]
  68. adcchushihua:
  69.         ldr r0, = 0x40012400  @ adc基地址
  70.         ldr r1, = 0x80000000
  71.         str r1, [r0, # 0x08]  @ ADC 控制寄存器 (ADC_CR)  @adc校准
  72. dengadcjiaozhun:
  73.         ldr r1, [r0, # 0x08]
  74.          movs r1, r1
  75.         bmi dengadcjiaozhun   @ 等ADC校准
  76. kaiadc:
  77.         ldr r1, [r0, # 0x08]
  78.         movs r2, # 0x01
  79.         orrs r1, r1, r2
  80.         str r1, [r0, # 0x08]
  81. dengdaiadcwending:
  82.         ldr r1, [r0]
  83.         lsls r1, r1, # 31
  84.         bpl dengdaiadcwending @ 等ADC稳定
  85. tongdaoxuanze:
  86.         ldr r1, = 0x20000
  87.         str r1, [r0, # 0x28]    @ 通道选择寄存器 (ADC_CHSELR)
  88.         ldr r1, = 0x2000        @ 13 连续转换
  89.         str r1, [r0, # 0x0c]    @ 配置寄存器 1 (ADC_CFGR1)
  90.         movs r1, # 0x05         @
  91.         str r1, [r0, # 0x14]    @ ADC 采样时间寄存器 (ADC_SMPR)
  92.         ldr r1, = 0x400000      @ V REFINT 通道开启
  93.         ldr r2, = 0x308
  94.         str r1, [r0, r2]    @ 通用配置寄存器 (ADC_CCR)
  95.         ldr r1, [r0, # 0x08]
  96.         movs r2, # 0x04         @ 开始转换
  97.         orrs r1, r1, r2
  98.         str r1, [r0, # 0x08]    @ 控制寄存器 (ADC_CR)
  99.
  100.
  101. io_she_zhi:
  102. @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  103.         @a(0x48000000)b(0x48000400)c(0x48000800)d(0x48000c00)f(0x48001400)
  104.         @ 输入(00),通用输出(01),复用功能(10),模拟(11)
  105.         @偏移0x4 = 端口输出类型 @ (0 推挽),( 1 开漏)
  106.         @偏移0x8 = 输出速度  00低速, 01中速, 11高速
  107.         @偏移0xC = 上拉下拉 00无上下拉,  01 上拉, 10下拉
  108.         @偏移0x10 = 输入数据寄存器
  109.         @偏移0x14 = 输出数据寄存器
  110.         @偏移0x18 = 端口开  0-15置位
  111.         @偏移0x28 = 端口关
  112.         @0X20 = 复用低
  113.         @GPIO口0(0-3位)每个IO口占用4位
  114.         @ AF0 = 0X0000, AF1 = 0X0001, AF2 = 0X0010 AF3 = 0X0011, AF4 = 0X0100
  115.         @ AF5 = 0X0101, AF6 = 0X0111, AF7 = 0X1000
  116.         @0x24 = 复用高
  117.         @GPIO口8 (0-3位)每个IO口占用4位
  118.         @ AF0 = 0X0000, AF1 = 0X0001, AF2 = 0X0010 AF3 = 0X0011, AF4 = 0X0100
  119.         @ AF5 = 0X0101, AF6 = 0X0111, AF7 = 0X1000
  120. @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  121.         ldr r0, = 0x48000000   @ 端口模式
  122.         ldr r1, = 0x28000100  @ PA4
  123.         str r1, [r0]
  124. ledkaiguan:
  125.         ldr r3, = 0xfffff
  126.         movs r4, # 0x10
  127.         str r4, [r0, # 0x18]
  128. ledxunhuan:
  129.         subs r3, r3, # 1
  130.         bne ledxunhuan
  131.         str r4, [r0, # 0x28]
  132.         ldr r3, = 0xfffff
  133. ledxunhuan1:
  134.         subs r3, r3, # 1
  135.         bne ledxunhuan1
  136.         b ledkaiguan
  137.
  138.
  139. _nmi_handler:
  140.         bx lr
  141. _hard_fault:
  142.         bx lr
  143. _memory_fault:
  144.         bx lr
  145. _bus_fault:
  146.         bx lr
  147. _usage_fault:
  148.          bx lr
  149.
 楼主| yjmwxwx 发表于 2016-12-26 21:41 | 显示全部楼层
m0没硬件除法仿别人写了个软的。 ADC测热敏电阻把温度显示到数码管。 0到25度显示,精度没准,代码很垃圾。
  1.          .thumb
  2.          .syntax unified
  3. .section .data
  5.                 .equ shumaguanma,        0x20000000
  6. shumaguanmabiao:        .int 0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6
  7. wendubiao:     .int 2520,2500,2460,2430,2410,2370,2340,2310,2260,2230,2200,2160,2130,2090,2050,2010,1980,1940,1910,1860,1830,1790,1760,1720,1680,1650
  8.
  9. .section .text
  10. vectors:
  11.         .word STACKINIT
  12.         .word _start + 1
  13.         .word _nmi_handler + 1
  14.         .word _hard_fault  + 1
  15.         .word _memory_fault + 1
  16.         .word _bus_fault + 1
  17.         .word _usage_fault + 1
  18. _start:
  19. shizhong:
  20.         ldr r0, = 0x40021000 @ rcc_cr
  21.         ldr r1, = 0x15683
  22.         str r1, [r0]
  23. gsszbz:
  24.         ldr r2, [r0]
  25.         ldr r1, = 0x20000
  26.         tst r1, r2           @HSE时钟标志位
  27.         bne rccchushihua
  28.         b gsszbz
  29. rccchushihua:
  30.         ldr r0, = 0x40022000   @FLASH访问控制
  31.         movs r1, # 0x32
  32.         str r1, [r0]           @FLASH缓冲 缓冲开启
  33.         ldr r0, = 0x40021004
  34.         ldr r1, = 0x110000    @ HSE-PLL-6倍频
  35.         str r1, [r0]
  36.         ldr r0, = 0x40021000
  37.         ldr r1, = 0x1035683     @ PLL开
  38.         str r1, [r0]
  39. chaxun:
  40.         ldr r2, [r0]
  41.         ldr r1, = 0x2000000     @ PLL锁定标志位
  42.         tst r1, r2
  43.         bne rccgg               @ 等待PLL锁定
  44.         b chaxun
  45. rccgg:
  46.         ldr r1, = 0x11000a      @ PLL作为系统时钟
  47.         str r1, [r0, # 0x04]
  48.
  49.         @0x34时钟控制寄存器 2 (RCC_CR2)
  50.         movs r1, # 0x01
  51.         str r1, [r0, # 0x34]  @ HSI开14M时钟
  52. dengdai14mshizhongwending:
  53.         ldr r1, [r0, # 0x34]
  54.         lsls r1, r1, # 30     @ 左移30位
  55.         bpl dengdai14mshizhongwending  @ 等待14M时钟稳定
  56.
  57. waisheshizhong:         @ 外设时钟
  58.         @+0x18外设时钟使能寄存器 (RCC_APB2ENR)
  59.         @ (0)SYSCFGEN(9)ADC(11)TIM1(12)SPI(14)USART1
  60.         @ (16)TIM15 (17)TIM6(18)TIM17 (22)DBGMCU
  61.         ldr r1, = 0x200
  62.         str r1, [r0, # 0x18]
  63.
  64.         ldr r0, = 0x40021014    @ AHB外部时钟
  65.         ldr r1, = 0x60014       @ 开时钟
  66.         str r1, [r0]
  67.         @ DMA(0)SRAM(2)FLITF(4)CRC(6)PA(17)
  68.         @PB(18)PC(19)PD(20)PF(22)TSCEN(24)
  69.         ldr r0, = 0x4002101c
  70.         ldr r1, = 0x132
  71.         str r1, [r0]
  72. adcchushihua:
  73.         ldr r0, = 0x40012400  @ adc基地址
  74.         ldr r1, = 0x80000000
  75.         str r1, [r0, # 0x08]  @ ADC 控制寄存器 (ADC_CR)  @adc校准
  76. dengadcjiaozhun:
  78.          movs r1, r1
  79.         bmi dengadcjiaozhun   @ 等ADC校准
  80. kaiadc:
  81.         ldr r1, [r0, # 0x08]
  82.         movs r2, # 0x01
  83.         orrs r1, r1, r2
  84.         str r1, [r0, # 0x08]
  85. dengdaiadcwending:
  86.         ldr r1, [r0]
  87.         lsls r1, r1, # 31
  88.         bpl dengdaiadcwending @ 等ADC稳定
  89. tongdaoxuanze:
  90.         ldr r1, = 0x01
  91.         str r1, [r0, # 0x28]    @ 通道选择寄存器 (ADC_CHSELR)
  92.         ldr r1, = 0x2000        @ 13 连续转换
  93.         str r1, [r0, # 0x0c]    @ 配置寄存器 1 (ADC_CFGR1)
  94.         movs r1, # 0x05         @
  95.         str r1, [r0, # 0x14]    @ ADC 采样时间寄存器 (ADC_SMPR)
  96.         ldr r1, [r0, # 0x08]
  97.         movs r2, # 0x04         @ 开始转换
  98.         orrs r1, r1, r2
  99.         str r1, [r0, # 0x08]    @ 控制寄存器 (ADC_CR)
  100.
  101. io_she_zhi:
  111.         @偏移0x28 = 端口关
  112.         @0X20 = 复用低
  116.         @0x24 = 复用高
  122.         ldr r1, = 0x28005403
  123.         str r1, [r0]
  124.         movs r1, # 0
  125.         str r1, [r0, # 0x0c]
  126.         ldr r1, [r0, # 0x08]
  127.         ldr r2, = 0xfc00
  128.         orrs r1, r2
  129.         str r1, [r0, # 0x08]
  130. shiyan:
  131.         ldr r7, = 0xff
  132.         ldr r0, = 0x40012440
  133.         ldr r0, [r0]
  134.         ldr r1, = 3300
  135.         muls r0, r1
  136.         ldr r1, = 4096
  137.         mov r12, r0
  138.         mov r11, r1
  139.         bl chufa
  140.         mov r0, r12
  141.         ldr r2, = wendubiao
  142.         movs r4, # 0
  143. panduanwendu:
  144.         ldr r3, [r2, r4]
  145.         cmp r3, r0
  146.         bcc dedaowendu
  147.         adds r4, r4, # 4
  148.         b panduanwendu
  149. dedaowendu:
  150.         lsrs r4, # 2
  151.         mov r0, r4
  152.         ldr r1, = 8
  153.         ldr r2, = shumaguanma
  154.         bl zhuanshumaguanma
  155. CC1:
  156.         movs r6, # 8
  157.         lsls r6, # 2
  158.         bl xieshumaguan
  159.         subs r7, # 1
  160.         bne CC1
  161.         b shiyan
  162.
  163. zhuanshumaguanma:@ 16进制转数码管码
  164.                 @ R0要转的数据, R1长度,R2结果表首地址
  165.         push {r0-r7,lr}
  166.         ldr r7, = shumaguanmabiao
  167.         movs r5, # 10
  168.         mov r11, r5
  169. xunhuanqiuma:
  170.         mov r12, r0
  171.         bl chufa
  172.         mov r4, r12
  173.         muls r4, r5
  174.         mov r6, r4
  175.         subs r3, r0, r6
  176.         lsls r3, # 2
  177.         ldr r6, [r7, r3]
  178.         str r6, [r2]
  179.         adds r2, r2, # 4
  180.         mov r0, r12
  181.         subs r1, # 1
  182.         bne xunhuanqiuma
  183.         pop {r0-r7,pc}
  184.
  185. xieshumaguan: @ r6=位数 @数码管码
  186.         push {r0-r7,lr}
  187.         ldr r1, = 0xfefefefe
  188.         movs r2, # 0x01
  189.         movs r7, # 0
  190.         ldr r5, = shumaguanma
  191. shumaguanshuaxin:
  192.         ldr r3, [r5, r7]
  193.         lsrs r4, r1, # 24
  194.         lsls r4, r4, # 8
  195.         orrs r4, r4, r3
  196.         mov r12, r4
  197.         bl xie595
  198.         rors r1, r2
  199.         adds  r7, r7, # 4
  200.         cmp r7, r6
  201.         bcc shumaguanshuaxin
  202.         pop {r0-r7,pc}
  203.
  204. xie595: @ R12=要写的数据
  205.         push {r0-r7,lr}
  206.         movs r0, # 0x40
  207.         movs r7, # 0x80
  208.         movs r6, # 0x20
  209.         mov r5, r12
  210.         movs r3, # 16   @16位
  211.         ldr r2, = 0x48000000 @ gpioa
  212.         movs r1, # 0x01
  213. xunhuan595:
  214.         str r7, [r2, # 0x18]
  215.         bl yanshi
  216.         tst r5, r1
  217.         bne xie595_0
  218.         str r0, [r2, # 0x28]
  219.         b suocun595
  220. xie595_0:
  221.         str r0, [r2, # 0x18]
  222. suocun595:
  223.         bl yanshi
  224.         lsrs r5, # 1
  225.         str r7, [r2, # 0x28]
  226.         bl yanshi
  227.         subs r3, r3, # 1
  228.         bne xunhuan595
  229.         str r6, [r2, # 0x18]
  230.         bl yanshi
  231.         str r6, [r2, # 0x28]
  232.         bl yanshi
  233.         pop {r0-r7,pc}
  234. yanshi:
  235.         push {r0-r7,lr}
  236.         ldr r0, = 10
  237. yanshi1:
  238.         subs r0, # 1
  239.         bne yanshi1
  240.         pop {r0-r7,pc}
  241.
  242. chufa:        @软件除法
  243.         @ r12 除以 R11
  244.         push {r0-r7,lr}
  245.         mov r6, r12
  246.         cmp r6, # 0
  247.         beq chufafanhui
  248.         mov r7, r11
  249.         cmp r7, # 0
  250.         beq chufafanhui
  251.         movs r0, # 0
  252. chufaxunhuan:
  253.         mov r12, r6
  254.         bl jianceweishu
  255.         mov r2, r12
  256.         mov r12, r7
  257.         bl jianceweishu
  258.         mov r3, r12
  259.         subs r2, r3, r2
  260.         mov r4, r7
  261.         lsls r4, r2
  262.         mov r3, r4
  263.         cmp r6, r3
  264.         bcc dd1
  265.         b dd2
  266. dd1:
  267.         subs r2, r2, # 1
  268.         lsrs r3, # 1
  269. dd2:
  270.         subs r6, r6, r3
  271.         movs r3, # 1
  272.         lsls r3, r2
  273.         orrs  r0, r3
  274.         cmp r6, r7
  275.         bcs chufaxunhuan
  276.         mov r12, r0
  277. chufafanhui:
  278.         pop {r0-r7,pc}
  279. jianceweishu:
  280.         push {r0-r7,lr}
  281.         movs r0, # 0
  282.         mov r1, r12
  283. jianceweishu1:
  284.         bmi weishufanhui
  285.         adds r0, r0, # 1
  286.         lsls r1, # 1
  287.         b jianceweishu1
  288. weishufanhui:
  289.         mov r12, r0
  290.         pop {r0-r7,pc}
  291. _nmi_handler:
  292.         bx lr
  293. _hard_fault:
  294.         bx lr
  295. _memory_fault:
  296.         bx lr
  297. _bus_fault:
  298.         bx lr
  299. _usage_fault:
  300.         bx lr
  301.
 楼主| yjmwxwx 发表于 2017-1-8 17:27 | 显示全部楼层
STM32F030F4P6  TIM14   SPWM  正弦波
大约50HZ
  1. .thumb
  2.          .syntax unified
  3. .section .data
  5.                 .equ zhengxianbiaozhizhen, 0x20000500
  6. zhengxianbiao:                 .int 0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9c,0x9d,0x9e,0x9f,0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,0xae,0xaf,0xb0,0xb1,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xba,0xbb,0xbc,0xbd,0xbe,0xbf,0xc0,0xc1,0xc2,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xc9,0xca,0xcb,0xcc,0xcd,0xce,0xcf,0xcf,0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xda,0xdb,0xdc,0xdd,0xde,0xde,0xdf,0xe0,0xe1,0xe2,0xe2,0xe3,0xe4,0xe5,0xe6,0xe6,0xe7,0xe8,0xe9,0xe9,0xea,0xeb,0xec,0xec,0xed,0xee,0xef,0xef,0xf0,0xf1,0xf2,0xf2,0xf3,0xf4,0xf5,0xf5,0xf6,0xf7,0xf7,0xf8,0xf9,0xf9,0xfa,0xfb,0xfb,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0x100,0x101,0x101,0x102,0x103,0x103,0x104,0x105,0x105,0x106,0x106,0x107,0x108,0x108,0x109,0x109,0x10a,0x10b,0x10b,0x10c,0x10c,0x10d,0x10d,0x10e,0x10f,0x10f,0x110,0x110,0x111,0x111,0x112,0x112,0x113,0x113,0x114,0x114,0x115,0x115,0x116,0x116,0x117,0x117,0x118,0x118,0x119,0x119,0x119,0x11a,0x11a,0x11b,0x11b,0x11c,0x11c,0x11c,0x11d,0x11d,0x11e,0x11e,0x11e,0x11f,0x11f,0x120,0x120,0x120,0x121,0x121,0x121,0x122,0x122,0x122,0x123,0x123,0x123,0x124,0x124,0x124,0x124,0x125,0x125,0x125,0x126,0x126,0x126,0x126,0x127,0x127,0x127,0x127,0x128,0x128,0x128,0x128,0x128,0x129,0x129,0x129,0x129,0x129,0x12a,0x12a,0x12a,0x12a,0x12a,0x12a,0x12a,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12c,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12b,0x12a,0x12a,0x12a,0x12a,0x12a,0x12a,0x12a,0x129,0x129,0x129,0x129,0x129,0x128,0x128,0x128,0x128,0x128,0x127,0x127,0x127,0x127,0x126,0x126,0x126,0x126,0x125,0x125,0x125,0x125,0x124,0x124,0x124,0x123,0x123,0x123,0x123,0x122,0x122,0x122,0x121,0x121,0x120,0x120,0x120,0x11f,0x11f,0x11f,0x11e,0x11e,0x11d,0x11d,0x11d,0x11c,0x11c,0x11b,0x11b,0x11b,0x11a,0x11a,0x119,0x119,0x118,0x118,0x117,0x117,0x116,0x116,0x116,0x115,0x115,0x114,0x114,0x113,0x113,0x112,0x112,0x111,0x110,0x110,0x10f,0x10f,0x10e,0x10e,0x10d,0x10d,0x10c,0x10b,0x10b,0x10a,0x10a,0x109,0x109,0x108,0x107,0x107,0x106,0x106,0x105,0x104,0x104,0x103,0x102,0x102,0x101,0x100,0x100,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xfa,0xf9,0xf8,0xf8,0xf7,0xf6,0xf6,0xf5,0xf4,0xf3,0xf3,0xf2,0xf1,0xf1,0xf0,0xef,0xee,0xee,0xed,0xec,0xeb,0xeb,0xea,0xe9,0xe8,0xe7,0xe7,0xe6,0xe5,0xe4,0xe4,0xe3,0xe2,0xe1,0xe0,0xe0,0xdf,0xde,0xdd,0xdc,0xdc,0xdb,0xda,0xd9,0xd8,0xd7,0xd7,0xd6,0xd5,0xd4,0xd3,0xd2,0xd2,0xd1,0xd0,0xcf,0xce,0xcd,0xcc,0xcc,0xcb,0xca,0xc9,0xc8,0xc7,0xc6,0xc6,0xc5,0xc4,0xc3,0xc2,0xc1,0xc0,0xbf,0xbe,0xbe,0xbd,0xbc,0xbb,0xba,0xb9,0xb8,0xb7,0xb6,0xb6,0xb5,0xb4,0xb3,0xb2,0xb1,0xb0,0xaf,0xae,0xad,0xac,0xac,0xab,0xaa,0xa9,0xa8,0xa7,0xa6,0xa5,0xa4,0xa3,0xa2,0xa2,0xa1,0xa0,0x9f,0x9e,0x9d,0x9c,0x9b,0x9a,0x99,0x98,0x97,0x96,0x96,0x95,0x94,0x93,0x92,0x91,0x90,0x8f,0x8e,0x8d,0x8c,0x8b,0x8a,0x8a,0x89,0x88,0x87,0x86,0x85,0x84,0x83,0x82,0x81,0x80,0x80,0x7f,0x7e,0x7d,0x7c,0x7b,0x7a,0x79,0x78,0x77,0x76,0x76,0x75,0x74,0x73,0x72,0x71,0x70,0x6f,0x6e,0x6e,0x6d,0x6c,0x6b,0x6a,0x69,0x68,0x67,0x66,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x60,0x5f,0x5e,0x5d,0x5c,0x5b,0x5a,0x5a,0x59,0x58,0x57,0x56,0x55,0x55,0x54,0x53,0x52,0x51,0x50,0x50,0x4f,0x4e,0x4d,0x4c,0x4c,0x4b,0x4a,0x49,0x48,0x48,0x47,0x46,0x45,0x45,0x44,0x43,0x42,0x41,0x41,0x40,0x3f,0x3e,0x3e,0x3d,0x3c,0x3b,0x3b,0x3a,0x39,0x39,0x38,0x37,0x36,0x36,0x35,0x34,0x34,0x33,0x32,0x32,0x31,0x30,0x2f,0x2f,0x2e,0x2d,0x2d,0x2c,0x2c,0x2b,0x2a,0x2a,0x29,0x28,0x28,0x27,0x26,0x26,0x25,0x25,0x24,0x23,0x23,0x22,0x22,0x21,0x21,0x20,0x1f,0x1f,0x1e,0x1e,0x1d,0x1d,0x1c,0x1c,0x1b,0x1a,0x1a,0x19,0x19,0x18,0x18,0x17,0x17,0x16,0x16,0x16,0x15,0x15,0x14,0x14,0x13,0x13,0x12,0x12,0x11,0x11,0x11,0x10,0x10,0xf,0xf,0xf,0xe,0xe,0xd,0xd,0xd,0xc,0xc,0xc,0xb,0xb,0xa,0xa,0xa,0x9,0x9,0x9,0x9,0x8,0x8,0x8,0x7,0x7,0x7,0x7,0x6,0x6,0x6,0x6,0x5,0x5,0x5,0x5,0x4,0x4,0x4,0x4,0x4,0x3,0x3,0x3,0x3,0x3,0x2,0x2,0x2,0x2,0x2,0x2,0x2,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x2,0x2,0x2,0x2,0x2,0x2,0x2,0x3,0x3,0x3,0x3,0x3,0x4,0x4,0x4,0x4,0x4,0x5,0x5,0x5,0x5,0x6,0x6,0x6,0x6,0x7,0x7,0x7,0x8,0x8,0x8,0x8,0x9,0x9,0x9,0xa,0xa,0xa,0xb,0xb,0xb,0xc,0xc,0xc,0xd,0xd,0xe,0xe,0xe,0xf,0xf,0x10,0x10,0x10,0x11,0x11,0x12,0x12,0x13,0x13,0x13,0x14,0x14,0x15,0x15,0x16,0x16,0x17,0x17,0x18,0x18,0x19,0x19,0x1a,0x1a,0x1b,0x1b,0x1c,0x1c,0x1d,0x1d,0x1e,0x1f,0x1f,0x20,0x20,0x21,0x21,0x22,0x23,0x23,0x24,0x24,0x25,0x26,0x26,0x27,0x27,0x28,0x29,0x29,0x2a,0x2b,0x2b,0x2c,0x2d,0x2d,0x2e,0x2e,0x2f,0x30,0x31,0x31,0x32,0x33,0x33,0x34,0x35,0x35,0x36,0x37,0x37,0x38,0x39,0x3a,0x3a,0x3b,0x3c,0x3d,0x3d,0x3e,0x3f,0x40,0x40,0x41,0x42,0x43,0x43,0x44,0x45,0x46,0x46,0x47,0x48,0x49,0x4a,0x4a,0x4b,0x4c,0x4d,0x4e,0x4e,0x4f,0x50,0x51,0x52,0x52,0x53,0x54,0x55,0x56,0x57,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5d,0x5e,0x5f,0x60,0x61,0x62,0x63,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6a,0x6b,0x6c,0x6d,0x6e,0x6f,0x70,0x71,0x72,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7b,0x7c,0x7d,0x7e,0x7f,0x80,0x81,0x82,0x83,0x84,0x85,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f,0x90,0x90,0x91,0x92,0x93,0x94,0x95,0x96,
  7. .section .text
  8. vectors:
  9.         .word STACKINIT
  10.         .word _start + 1
  11.         .word _nmi_handler + 1
  12.         .word _hard_fault  + 1
  13.         .word 0
  14.         .word 0
  15.         .word 0
  16.         .word 0
  17.         .word 0
  18.         .word 0
  19.         .word 0
  20.         .word _svc_handler +1
  21.         .word 0
  22.         .word 0
  23.         .word _pendsv_handler +1
  24.         .word 0    @_systick +1               @ 15
  25.         .word 0     @ _wwdg +1          @ 0
  26.         .word 0     @_pvd +1            @ 1
  27.         .word 0     @_rtc +1            @ 2
  28.         .word 0     @_flash +1          @ 3
  29.         .word 0     @ _rcc + 1          @ 4
  30.         .word 0      @_exti0_1  +1      @ 5
  31.         .word 0      @ _exti2_3 +1      @ 6
  32.         .word 0       @_exti4_15 +1     @ 7
  33.         .word 0                         @ 8
  34.         .word 0         @_dma1_1  +1    @ 9
  35.         .word 0    @_dma1_2_3 +1        @ 10
  36.         .word 0       @_dma1_4_5 +1     @ 11
  37.         .word 0      @_adc1 +1          @ 12
  38.         .word 0       @_tim1_brk_up +1  @ 13
  39.         .word 0        @ _tim1_cc +1    @ 14
  40.         .word 0         @_tim2 +1       @ 15
  41.         .word 0          @_tim3 +1      @ 16
  42.         .word 0                         @ 17
  43.         .word 0                                @ 18
  44.         .word _tim14 +1    @ 19
  45.         .word 0                         @ 20
  46.         .word 0         @_tim16 +1      @ 21
  47.         .word 0         @_tim17 +1      @ 22
  48.         .word 0          @_i2c   +1     @ 23
  49.         .word 0                         @ 24
  50.         .word 0           @_spi   +1    @ 25
  51.         .word 0                         @ 26
  52.         .word 0         @_usart1 +1     @ 27
  53.
  54. _start:
  55. shizhong:
  56.         ldr r0, = 0x40021000 @ rcc
  57.         ldr r2, = 0x40022000   @FLASH访问控制
  58.         movs r1, # 0x32
  59.         str r1, [r2]           @FLASH缓冲 缓冲开启
  60.         ldr r1, = 0x110002     @HSE-PLL 6
  61.         str r1, [r0, # 0x04]
  62.         ldr r1, = 0x1090001
  63.         str r1, [r0]
  64. dengrc:
  65.         ldr r1, [r0]
  66.         lsls r1, # 30
  67.         bpl dengrc
  68. dengjingzhen:
  69.         ldr r1, [r0]
  70.         lsls r1, # 14
  71.         bpl dengjingzhen
  72. dengpll:
  73.         ldr r1, [r0]
  74.         lsls r1, # 6
  75.         bpl dengpll
  76.         @0x34时钟控制寄存器 2 (RCC_CR2)
  77.         movs r1, # 0x01
  78.         str r1, [r0, # 0x34]  @ HSI开14M时钟
  79. dengdai14mshizhongwending:
  80.         ldr r1, [r0, # 0x34]
  81.         lsls r1, r1, # 30     @ 左移30位
  82.         bpl dengdai14mshizhongwending  @ 等待14M时钟稳定
  83. chushihuaneicun:        @ 设置内存里的变量
  84.         ldr r0, = zhengxianbiaozhizhen @ 正弦波指针
  85.         movs r1, # 0
  86.         str r1, [r0]
  87. waisheshizhong:         @ 外设时钟
  88.         @+0x14 #0(DMA),2(SRAM),4(FLITF),6(CRC),17(PA)
  89.         @18(PB),19(PC),20(PD),22(PF)
  90.         @+0x18 #0(SYSCFG),5(USART6),9(ADC),#11(TIM1)
  91.         @12(SPI), @14(USART1),16(TIM15),17(TIM16),
  92.         @18(TIM17),22(DBGMCU)
  93.         @+0X1C # 1(TIM3),4(TIM6),5(TIM7),8(TIM14),11(WWDG),
  94.         @14(SPI2),17(USART2),18(USART3),19(USART4),20(USART5)
  95.         @21(I2C1),22(I2C2),23(USB),28(PWR)
  96.         ldr r0, = 0x40021000
  97.         ldr r1, = 0x60005
  98.         str r1, [r0, # 0x14]
  99.         ldr r1, = 0x100
  100.         str r1, [r0, # 0x1c]
  101. waishezhongduan:        @外设中断
  102.         @0xE000E100    0-31 写1开,写0没效
  103.         @0XE000E180    0-31 写1关,写0没效
  104.         @0XE000E200    0-31 挂起,写0没效
  105.         @0XE000E280    0-31 清除, 写0没效
  106.         ldr r0, = 0xe000e100
  107.         movs r1, # 0x01
  108.         lsls r1, # 19 @ tim14
  109.         str r1, [r0]
  110. tim14chushihua:
  111.         ldr r0, = 0x40002000
  112.         movs r1, # 3
  113.         str r1, [r0, # 0x28]
  114.         ldr r1, = 300
  115.         str r1, [r0, # 0x2c]
  116.         ldr r1, = 0x60
  117.         str r1, [r0, # 0x18]
  118.         ldr r1, = 0x01
  119.         str r1, [r0, # 0x20]
  120.                                 [url=home.php?mod=space&uid=43626]@ldr[/url] r1, = 65535
  121.                                 [url=home.php?mod=space&uid=96593]@str[/url] r1, [r0, # 0x34]
  122.         movs r1, # 0x01
  123.         str r1, [r0, # 0x0c]
  124.         ldr r1, = 0x81
  125.         str r1, [r0]
  126.
  127. io_she_zhi:
  128. @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  129.         @a(0x48000000)b(0x48000400)c(0x48000800)d(0x48000c00)f(0x48001400)
  130.         @ 输入(00),通用输出(01),复用功能(10),模拟(11)
  131.         @偏移0x4 = 端口输出类型 @ (0 推挽),( 1 开漏)
  132.         @偏移0x8 = 输出速度  00低速, 01中速, 11高速
  133.         @偏移0xC = 上拉下拉 00无上下拉,  01 上拉, 10下拉
  134.         @偏移0x10 = 输入数据寄存器
  135.         @偏移0x14 = 输出数据寄存器
  136.         @偏移0x18 = 端口开  0-15置位
  137.         @偏移0x28 = 端口关
  138.         @0X20 = 复用低
  139.         @GPIO口0(0-3位)每个IO口占用4位
  140.         @ AF0 = 0X0000, AF1 = 0X0001, AF2 = 0X0010 AF3 = 0X0011, AF4 = 0X0100
  141.         @ AF5 = 0X0101, AF6 = 0X0111, AF7 = 0X1000
  142.         @0x24 = 复用高
  143.         @GPIO口8 (0-3位)每个IO口占用4位
  144.         @ AF0 = 0X0000, AF1 = 0X0001, AF2 = 0X0010 AF3 = 0X0011, AF4 = 0X0100
  145.         @ AF5 = 0X0101, AF6 = 0X0111, AF7 = 0X1000
  146. @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  147.         ldr r0, = 0x48000000 @ gpio_a
  148.         ldr r1, = 0x28000200 @ pa4
  149.         str r1, [r0]
  150.         ldr r1, = 0x40000
  151.         str r1, [r0, # 0x20]
  152. zhengxuanbo:
  153.         b zhengxuanbo
  154. _nmi_handler:
  155.         bx lr
  156. _hard_fault:
  157.         bx lr
  158. _svc_handler:
  159.         bx lr
  160. _pendsv_handler:
  161.         bx lr
  162. _tim14:
  163. tim14ting:
  164.         push {r0-r7,lr}
  165.         ldr r0, = zhengxianbiao
  166.         ldr r2, = zhengxianbiaozhizhen
  167.         ldr r5, = 0x40002000
  168.         ldr r3, [r2]
  169.         ldr r1, [r0, r3]
  170.         str r1, [r5, # 0x34]
  171.         ldr r4, = 4092
  172.         cmp r3, r4
  173.         bcc tim14fanhui
  174.         movs r3, # 0
  175.         b tim14fanhui
  176. tim14fanhui:
  177.         adds r3, r3, # 4
  178. tim14fanhui1:
  179.         str r3, [r2]
  180.         movs r0, # 0
  181.         str r0, [r5, # 0x10]
  182.         pop {r0-r7,pc}
  183.
springvirus 发表于 2017-2-16 15:29 | 显示全部楼层
这个版面已关闭了,很少有人进来了
