[51单片机] protues 仿真HDG12864L-4显示不了
2693|1
 楼主| busike 发表于 2016-12-21 14:59 | 显示全部楼层 |阅读模式
各位大虾,偶单片机菜鸟,学习液晶屏驱动程序,用protues 仿真HDG12864L-4显示不了,附上图片及程序请大虾指教
* 文件名:DISPLAY_LCD12864_image_p.c
* 说  明:用HDG12864L-4仿真显示图片
#include <reg52.h>
#include<intrins.h>
#define   uchar  unsigned char
#define   uint   unsigned int
#define   LCD_DAT   P2         //定义LCD数据端口
sbit A0=P0^0;                   //数据/命令控制端口                  1数据  0命令
sbit E=P0^2;                   //时钟使能端口   1使能
sbit RW=P0^1;                           //读写操作 1读  0写
/* 宋体12(小四);  此字体对应的点阵为:宽x高=16x16  */
code uchar IMAGE_STYLE[]={/*--  调入了一幅图像:这是您新建的图像  --*/
/*--  宽度x高度=128x64  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x80,0x90,0xD0,0x78,0xF8,0xF8,0xF8,0xF0,0xF0,0xF0,0xE0,0xE0,
0xE0,0xA0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x06,0x0F,0x0F,0x07,0x0F,0x0F,0x0F,0xCF,0xFF,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xDD,0x9F,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0xF0,0x78,0xF8,0xF0,0xE0,0xC0,0xC0,0x80,
0xC0,0xE0,0xE0,0xF0,0xFC,0xFE,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFD,0x3B,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x40,0x20,0x80,
0x00,0x00,0x00,0x00,0x00,0xF8,0xFF,0xFF,0xFC,0x9C,0x3C,0x3D,0x3F,0x7F,0xFD,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xE1,0xC3,0x87,
0x05,0x01,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFE,0xE3,0xF1,
0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01,0x1F,0x1F,0x78,0xF0,0x00,0x00,0x00,0x01,
0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFE,0xFE,0xFC,0xF8,0xF0,0xE0,0x80,0x80,0x80,0xC0,0xE0,0xFF,0xDF,0x7F,0x1F,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x1F,0x7F,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0x7F,0x7F,0x1F,0x07,0xBF,0xFF,0x3F,0x1F,0x05,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x03,
0x07,0x07,0x07,0x07,0x06,0x06,0x06,0x06,0x0E,0x0E,0x0E,0x1F,0x1F,0x07,0x9F,0xFF,
0xFF,0x7B,0x61,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x18,0x18,0x1C,0x1E,0x07,0x03,0x01,
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
    for(y=0;y<80;y++) ;
* 函  数:从并行口输入要显示的数据
* 参  数:dat 要显示的数据
* 返回值:无
void write_data(uchar dat)
        A0=1;
        RW=0;
        _nop_();
    _nop_();
    LCD_DAT=dat; //输入要显示的数据
        E=1;
    _nop_();
    _nop_();
    E=0;
* 函  数:从并行口输入命令
* 参  数:command 要输出的命令
* 返回值:无
void write_cmd(uchar command)
        A0=0;
        RW=0;
    LCD_DAT=command; //输入要显示的数据
        _nop_();
    _nop_();
        E=1;
    _nop_();
    _nop_();
    E=0;
* 函  数:清屏
* 参  数:空
* 返回值:无
void clear_screen(void)
   uchar i,j;
   for(i=0;i<8;i++)
      write_cmd(0xB0|i); //写入页地址
      write_cmd(0x00); //写入列低位起始地址
      write_cmd(0x10); //写入列高位起始地址
      for(j=0;j<128;j++)//128列清零
          write_data(0x00);
* 函  数:设定页地址
* 参  数:page 页地址,有效范围0~7
* 返回值:无
void set_page(uchar page)
   uchar tmp = 0;
   tmp = page&0x07; //确定输入值为0-7
   tmp = tmp|0xB0;  //获得页地址
   write_cmd(tmp);  //写入页地址
* 函  数:设定列地址
* 参  数:column 列地址,有效范围0~127
* 返回值:无
void set_column(uchar column)
   uchar col_h, col_l;
   column = column&0x7f; //确定输入数值在0-127
   col_h = column&0xf0;  //取列地址高四位
   col_h = col_h>>4;
   col_l = column&0x0f;  //取列地址低四位
   col_h = col_h|0x10;
   col_l = col_l|0x00;
   write_cmd(col_h);  //写入地址低四位
   write_cmd(col_l);  //写入地址低四位
* 函  数:设定行地址
* 参  数:row 行地址
* 返回值:无
void set_row(uchar row)
   write_cmd(row|0x40);
* 函  数:开关显示设置
* 参  数:state 1:开显示  0:关显示
* 返回值:无
void LCD_open(uchar state)
   state = state|0xAE; //开:0xAF; 关:0xAE
   write_cmd(state); //写入状态
* 函  数:液晶初始化
* 参  数:空
* 返回值:无
void LCD_init(void)
   write_cmd(0xE2);    //复位
   write_cmd(0xAf);    //液晶显示开
   write_cmd(0xA2);    //lcd bias set
   write_cmd(0xA1); //反向显示(即从左到右显示)字的方向:0xA0/0xA1
   write_cmd(0xc0);  //字体上下颠倒显示 0xc0正向显示,0x80 颠倒显示   无此命令默认正向显示
   write_cmd(0xA4);          //所有的屏幕点开关,A4正常显示   A5所有点开            无此命令默认正常显示
   set_page(0);
   set_row(0);
   set_column(0);
* 函数:显示一个16X16的汉字
* 参数:page:显示的页(0~7)
*       column:显示的列(0~127)
*       *pt:显示字的首地址
* 返回值:无
void show_pic128(uchar page, uchar column)
   uchar i;
   set_page(page);   //设置页地址
   set_column(column);  //设置起始列
   for(i=0; i<128; i++)  //128列*8行图像
      write_data(IMAGE_STYLE[page*128+i]); //写数据
* 函  数:显示汉字
* 参  数:空
* 返回值:无
void display_image(void)
   uchar page = 0;
   uchar column = 0;
   for(page=0; page<8; page++)
     show_pic128(page, 0);
* 函  数:端口初始化函数
* 参  数:空
* 返回值:无
void port_init(void)
   DDRA = 0xFF;
   PORTA = 0x00;
   DDRB = 0xFF;
   PORTB = 0xFF;
   DDRC = 0xFF;
   PORTC = 0x00;
   DDRD = 0xFF;
   PORTD = 0xFF;
* 函  数:主函数,用HDG12864L-1的串行方式显示汉字
* 参  数:空
* 返回值:无
void main(void)
    LCD_init ();
        LCD_DAT=0X
        clear_screen();
    LCD_open(1);
    display_image();
    while(1)
        write_cmd(0xA6); //字体颜色反显   0xA6/0xA7
        delay(1000);
        write_cmd(0xA7);
        delay(1000);
 楼主| busike 发表于 2016-12-21 15:01 | 显示全部楼层
类似的程序仿真串行HDG12864L-1驱动是可以的
