- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 3 $
- * $Date: 15/02/06 10:22a $
- * @brief
- * Transmit and receive data in UART RS485 mode.
- * This sample code needs to work with UART_RS485_Slave.
- * @note
- * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M058S.h"
- #define PLL_CLOCK 50000000
- #define RXBUFSIZE 128
- #define MATCH_ADDRSS 0xC0
- #define UNMATCH_ADDRSS 0xB1
- /* Define functions prototype */
- extern char GetChar(void);
- int32_t main(void);
- void RS485_SendAddressByte(uint8_t u8data);
- void RS485_SendDataByte(uint8_t *pu8TxBuf, uint32_t u32WriteBytes);
- void RS485_9bitModeMaster(void);
- /* RS485 Transmit Control (Address Byte: Parity Bit =1 , Data Byte:Parity Bit =0) */
- /* Set UART parity as MARK and ship baud rate setting */
- UART_SetLine_Config(UART0, 0, UART_WORD_LEN_8, UART_PARITY_MARK, UART_STOP_BIT_1);
- /* Send data */
- UART_WRITE(UART0, u8data);
- /* Wait Tx empty */
- UART_WAIT_TX_EMPTY(UART0);
- /* Set UART parity as SPACE and ship baud rate setting */
- UART_SetLine_Config(UART0, 0, UART_WORD_LEN_8, UART_PARITY_SPACE, UART_STOP_BIT_1);
- /* Send data */
- UART_Write(UART0, pu8TxBuf, u32WriteBytes);
- /* RS485 Transmit Test */
- void RS485_9bitModeMaster()
- int32_t i32;
- uint8_t g_u8SendData[RXBUFSIZE] = {0};
- printf("\n");
- printf("+-------------------------------------------------------------+\n");
- printf("| Pin Configure |\n");
- printf("| _______ _______ |\n");
- printf("| | | | | |\n");
- printf("| |Master |--- TXD(P3.1) <====> RXD(P3.0) ---| Slave | |\n");
- printf("| | |--- RTS(P0.3) <====> RTS(P0.3) ---| | |\n");
- printf("| |_______| |_______| |\n");
- printf("| |\n");
- printf("| Please enable semihosted to show messages on debug session.|\n");
- printf("| Keil users must define DEBUG_ENABLE_SEMIHOST in both C/C++ |\n");
- printf("| and Asm preprocessor symbols. |\n");
- printf("| IAR users must define DEBUG_ENABLE_SEMIHOST in both C/C++ |\n");
- printf("| Compiler and Assembler preprocessor symbols. |\n");
- The sample code is used to test RS485 9-bit mode and needs
- two Module test board to complete the test.
- Master:
- 1.Set AUD mode and HW will control RTS pin. LEV_RTS is set to '0'.
- 2.Master will send four different address with 10 bytes data to test Slave.
- 3.Address bytes : the parity bit should be '1'. (Set UA_LCR = 0x2B)
- 4.Data bytes : the parity bit should be '0'. (Set UA_LCR = 0x3B)
- 5.RTS pin is low in idle state. When master is sending,
- RTS pin will be pull high.
- Slave:
- 1.Set AAD and AUD mode firstly. LEV_RTS is set to '0'.
- 2.The received byte, parity bit is '1' , is considered "ADDRESS".
- 3.The received byte, parity bit is '0' , is considered "DATA". (Default)
- 4.AAD: The slave will ignore any data until ADDRESS match ADDR_MATCH value.
- When RLS and RDA interrupt is happened,it means the ADDRESS is received.
- Check if RS485_ADD_DETF is set and read UA_RBR to clear ADDRESS stored in rx_fifo.
- NMM: The slave will ignore data byte until disable RX_DIS.
- Check the ADDRESS is match or not by user in UART_IRQHandler.
- If the ADDRESS is match,clear RX_DIS bit to receive data byte.
- If the ADDRESS is not match,set RX_DIS bit to avoid data byte stored in FIFO.
- printf("\n");
- printf("| RS485 Function Test (9-bit Master) |\n");
- printf("| The function will send address with 128 data bytes to test |\n");
- printf("| RS485 9-bit mode. Please connect TX/RX to another board and |\n");
- printf("| wait its ready to receive. |\n");
- printf("| Press any key to start... |\n");
- printf("+-------------------------------------------------------------+\n\n");
- GetChar();
- /* Set RS485-Master as AUD mode */
- /* Enable AUD mode to HW control RTS pin automatically */
- /* You also can use GPIO to control RTS pin for replacing AUD mode*/
- UART_SelectRS485Mode(UART0, UART_ALT_CSR_RS485_AUD_Msk, 0);
- /* Set RTS pin active level as high level active */
- UART0->MCR &= ~UART_MCR_LEV_RTS_Msk;
- UART0->MCR |= UART_RTS_IS_HIGH_LEV_ACTIVE;
- /* Set TX delay time */
- UART0->TOR = 0x2000;
- /* Prepare Data to transmit */
- for(i32 = 0; i32 < RXBUFSIZE; i32++)
- g_u8SendData[i32] = i32 & 0xFF;
- /* Send address and data for test */
- printf("Send Address 0x%x and data 0~127\n", MATCH_ADDRSS);
- RS485_SendAddressByte(MATCH_ADDRSS);
- RS485_SendDataByte(g_u8SendData, RXBUFSIZE);
- printf("Transfer Done\n");
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD and TXD */
- SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
- SYS->P3_MFP |= (SYS_MFP_P30_RXD | SYS_MFP_P31_TXD);
- /* Set P0 multi-function pins for UART0 RTS */
- SYS->P0_MFP = SYS->P0_MFP & (~SYS_MFP_P03_Msk) | SYS_MFP_P03_RTS;
- void UART0_Init()
- /* Init UART */
- /* Reset UART0 */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* MAIN function */
- int main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for testing */
- UART0_Init();
- /* SAMPLE CODE */
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
- printf("\n\nUART Sample Program\n");
- /* UART RS485 sample master function */
- RS485_9bitModeMaster();
- while(1);
